david_a_g_johnson(at)btin Guest
Posted: Mon Dec 31, 2007 3:00 am Post subject: Prop flange extension |
I'm building a 601XL, Jabiru 3300, Sensenich composite prop and FWF kit from USJabiru.
The instructions and the Homebuilthelp video all refer to fitting a prop flange extension, but I don't have one, should it have been supplied with either the engine, or the FWF kit? Neither of the packing lists refer to it.
Why is an extension needed and where can I get one?
Any advice would be appreciated.
Dave Johnson
(In the UK)
skyridersbn(at)yahoo.com Guest
Posted: Mon Dec 31, 2007 4:12 am Post subject: Prop flange extension |
I would suggest contact the supplier(s) and ask them. It could have just been an oversight on their part. If it's not needed, they will be able to let you know why. Just a thought.
psm(at)ATT.NET Guest
Posted: Mon Dec 31, 2007 4:24 am Post subject: Prop flange extension |
Hi Dave,
I too received the FWF from UsJabiru. The prop flange extension was wrapped in bubble wrap. Total package size is around 6 inches around by 3 inches tall.
I suggest you check your pile of bubble wrap to see if one of the pieces is a lot heavier than the others. If you didn't get the part, I'm sure Pete will supply it to you.
Happy Hunting,
Paul
XL fuselage
At 02:59 AM 12/31/2007, you wrote:
[quote]I'm building a 601XL, Jabiru 3300, Sensenich composite prop and FWF kit from USJabiru.
The instructions and the Homebuilthelp video all refer to fitting a prop flange extension, but I [b]
Posted: Mon Dec 31, 2007 7:44 am Post subject: Prop flange extension |
I have the same aircraft and setup. QBK. It came with the extension.
Steve
