bent gear
indyaviator(at)gmail.com
PostPosted: Wed Dec 26, 2007 5:08 pm    Post subject: bent gear Reply with quote
Hello all,
I remember seeing a picture of a jig someone made for straightening bent aluminum gear legs. Unfortunately, I have found myself in need of such a device. Anyone know where to find pics or plans??
Bryan Dever
henry.voris
PostPosted: Wed Dec 26, 2007 5:27 pm    Post subject: Re: bent gear Reply with quote
Bryan,
I can't remember who posted these... It was not me... but I had to straighten my gear too, so I picked up these photos from the list.
Good Luck!
 Filesize:  62.38 KB
 Viewed:  532 Time(s)
 Filesize:  60.44 KB
 Viewed:  541 Time(s)
Henry
Firefly Five-Charlie-Bravo
planecrazzzy
PostPosted: Wed Dec 26, 2007 7:07 pm    Post subject: Re: bent gear Reply with quote
Hey, That's my "Quick" press...
I stopped over somebody's house on my way home with my gear leg...
I was going to use his "press".....He wasn't home.
So I Slapped this thing together....it Worked great...
and I haven't needed it again !
Gotta Fly...
Mike & "Jaz" in MN
PS It was a 12 ton jack
 Filesize:  59.87 KB
 Viewed:  544 Time(s)
Gear looks fine now....
 Filesize:  365.65 KB
 Viewed:  570 Time(s)
 Filesize:  61.61 KB
 Viewed:  558 Time(s)
PostPosted: Wed Dec 26, 2007 7:19 pm    Post subject: bent gear Reply with quote
Thanks guys!! That's the pic I remember.
Bryan Dever
On Dec 26, 2007 10:07 PM, planecrazzzy <planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)> wrote:
[quote]--> Kolb-List message posted by: "planecrazzzy" < planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)>
Gotta Fly...
Mike & "Jaz" in MN
http://forums.matronics.com/viewtopic.php?p=154462#154462
http://forums.matronics.com//files/axle_press_003_165.jpg
http://forums.matronics.com//files/hpim0105_163.jpg
http://forums.matronics.com//files/axle_press_001_461.jpg
slyck(at)frontiernet.net
PostPosted: Wed Dec 26, 2007 9:13 pm    Post subject: bent gear Reply with quote
If I had two of those legs bent the same I would turn them upside
down (rotate 180)
and use them that way.
I bent one leg on my second flight when the poorly tuned carb starved
the engine
at 50' on short final and I had to dive it to save what I could.
Used my neighbor's press.
-Then I saw Harbor Freight had a sale on a hydraulic pipe bender and
bought one.
Haven't had to use it yet.
BB
On 26, Dec 2007, at 8:27 PM, henry.voris wrote:
Bryan,
Good Luck!
Henry
http://forums.matronics.com/viewtopic.php?p=154446#154446
http://forums.matronics.com//files/axle_press_002_978.jpg
http://forums.matronics.com//files/axle_press_004_358.jpg
apilot(at)surewest.net
PostPosted: Fri Dec 28, 2007 6:56 pm    Post subject: bent gear Reply with quote
For all of you gear leg benders (myself included), remember that 7075-T6 aluminum will not take too many bends. They will take one or two if the bends are not severe. Past that and who knows? I care an extra one which is predrilled for the left gear, just in case I hit a chuck hole. As for full stall landings, the VGs solved that problem. Now, I do not have to learn to do it right. Vic (Sacramento) N4201G
MKIIIX040
PostPosted: Sat Dec 29, 2007 7:57 am    Post subject: bent gear Reply with quote
Hey Vic (Sacramento) N4201G
Vic ( Maine) N740VP
How do VG's effect your landings?
Getting my inspection by the FAA within 2 weeks. eeeeeeHa!
MKIIIX040
912UL
JetPilot
PostPosted: Mon Dec 31, 2007 8:51 am    Post subject: Re: bent gear Reply with quote
The effects of VG's make for much more forgiving landings. The plane does not tend to quit flying and drop suddenly like before. That combined with much more controllable slow approaches, and reduced stall makes them a huge safety advantage for Kolbs. If I ever have an engine out on my MK-III, approaching 10 MPH slower, and landing in a field at 30 MPH instead of 40 is a HUGE advantage. It could make the difference between stopping or not, and not dropping hard could make the difference between flipping over on my back or not.
With the overwhelming evidence of the benefits and large number of very positive reports about VG's on Kolbs, its hard to understand why anyone would not have them. They are only 100 bucks, and a couple hours to install from:
www.landshorter.com
Mike Bigelow
Kolb MK-III Xtra, 912-S
PostPosted: Mon Dec 31, 2007 9:42 am    Post subject: bent gear Reply with quote
www.landshorter.com
Mike Bigelow
Mike:
How much time did you put on your Kolb before you started flying it with
VGs?
What kind of results did you get without and with VGs?
With all those pros, there must be a few cons.
Learn how to land your Kolb without VGs.
Get rid of the porcupine look.
Streamline maintenance by making it much easier to wash the wings.
I don't have the porcupine look and still don't like washing wings.
PostPosted: Mon Dec 31, 2007 10:18 am    Post subject: bent gear Reply with quote
My VGs cost about $8.00 for alum roof flashing. About day to fab and a day to install. Should have spent several days locating them. THey are easy to locate to reduce stalll speed and difficult to locate to keep from losing cruise speed. My Classic now lands very much like the early Citabria with the 115 hp engine. Also, similar to a Kitfox in the grass.
PostPosted: Mon Dec 31, 2007 10:32 am    Post subject: bent gear Reply with quote
Gents, regardless of the little differences we might have in our Kolbs,
let us be grateful for the choice we made to own one at all.
Any time you may be tempted by one of those $80,000 airplanes, remember
the advantages of the Kolb:
1. no payments
2. $65000 (in my case) saved
-which (at) 4% = $2600 year free money
= 790 gallons of gas
=316 hours of fun flying
(or XXXX gallons of beer)
3. make your own parts from old lawn chairs, duct tape
4. free annual
5. no physical
6. add your own point here
BB
> www.landshorter.com
> Mike Bigelow
Mike:
with VGs?
smlplanet(at)msn.com
PostPosted: Mon Dec 31, 2007 4:51 pm    Post subject: bent gear Reply with quote
I seen your comments about the VG's, could you give me some more information on them, ( how they are made and locations).
I have a Classic 111 /912UL also which I got N numbered 2 weeks ago. I don't have that much time in it plus had done several changes and modifications to it. I had a commercial pilot and who also flies a tow plane for hand glider ( 50-100 per week end ) test fly it. He said it handled fine and then we took it up (duel ) it see how it handled, flew GREAT and everything seemed to be in adjusted properly.
He called a friend of mine that night and commented on how well the plane flew and handled. He has flown a lot of different types of planes but not a Kolb Mark 111 and was really surprised. Now I am looking at the VG's to help with the 900' airstrip I have at home.
Subject: Re: Re: bent gear
Date: Mon, 31 Dec 2007 10:18:11 -0800
--> Kolb-List message posted by: <apilot(at)surewest.net>
My VGs cost about $8.00 for alum roof flashing. About day to fab and a day to install. Should have spent several days locating them. THey are easy to locate to reduce stalll speed and difficult to locate to keep from losing cruise speed. My Classic now lands very much like the early Citabria with the 115 hp engine. Also, similar to a Kitfox in the grass.>
PostPosted: Mon Dec 31, 2007 5:05 pm    Post subject: bent gear Reply with quote
Ross:
What kind of changes and modifications did you do to your mkIII?
MKIII
Richard Pike
PostPosted: Mon Dec 31, 2007 10:02 pm    Post subject: bent gear Reply with quote
Well there is one drawback - the curmudgeon factor.
For which there is apparently no solution...
Richard Pike
MKIII N420P (420ldPoops)
John Hauck wrote:
<snip>
Mike:
with VGs?
<snip>
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
planecrazzzy
PostPosted: Tue Jan 01, 2008 5:58 am    Post subject: Re: bent gear Reply with quote
I had to "look that up"
It gave me a chuckle...
Gotta Fly...
Mike & "Jaz" in MN
[quote="Richard Pike"]Well there is one drawback - the curmudgeon factor.
Richard Pike
