Posted: Tue Dec 18, 2007 12:47 pm Post subject: Cooling tube on lightspeed ignition box? |
Hey all –
I was monkeying around with the install of my LSE ignition box and in the instructions it says:
On 6-cylinder systems, cooling air should be supplied to the box via the cooling port on the 15-pin connector side of the ignition module. For 6-cyl. systems that do not have a cooling port, contact LSE for this modification. Cooling is not required for 4-cyl. systems.
I’m wondering how others routed cooling air into this small (3/8” ish) tube on the side of the unit? any suggestions?
Thanks!
cj
www.perfectlygoodairplane.net
zackrv8
Posted: Tue Dec 18, 2007 7:01 pm Post subject: Re: Cooling tube on lightspeed ignition box? |
CJ,
I bought a 3 port blower fan from Stein. I will use the other ports for the Avionics LRU's and one for the Lightspeed.
Zack
_________________ RV8 #80125
RV10 # 40512 |
bcondrey
Posted: Wed Dec 19, 2007 6:13 am Post subject: Cooling tube on lightspeed ignition box? |
Chris,
I made an adapter to reduce the standard 5/8” cooling tube down to 3/8 out of some sort of poly tubing that I found at a home improvement store. Seemed to work pretty well.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston
Sent: Tuesday, December 18, 2007 2:47 PM
Subject: Cooling tube on lightspeed ignition box?
Hey all –
Thanks!
cj
0123456789012345
drfred(at)suddenlinkmail. Guest
Posted: Wed Dec 19, 2007 9:39 am Post subject: Cooling tube on lightspeed ignition box? |
zackrv8 wrote:
Zack:
I'm getting ready to start assembly of the panel and associated boxes.
Any chance you could take a pic of your installation? Trying to get
placement of items solidified in my mind.
Fred
40515. On the gear, starting wheel pants.
PILOTDDS(at)aol.com Guest
Posted: Sat Dec 22, 2007 3:22 pm Post subject: Cooling tube on lightspeed ignition box? |
For those of us with older lightspeeds Klaus wants them returned for internal updates as well as a provision for cooling tubes.I should have put those boxes where they were easier to get to.
See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) [quote][b]
mritter509(at)msn.com Guest
Posted: Sat Dec 22, 2007 4:13 pm Post subject: Cooling tube on lightspeed ignition box? |
What's the definition of an "older Lightspeed"? I've had my Plasma 111 going on three years.
Mark
RV-10/N410MR
170 hours
<html><div></div></html>
| Quote: | From: PILOTDDS(at)aol.com
Date: Sat, 22 Dec 2007 18:22:13 -0500
Subject: Re: Cooling tube on lightspeed ignition box?
See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) | Quote: |
blank>http://www.matronics.com/contribution
get=_blank>http://www.matronics.com/Navigator?RV10-List
p://forums.matronics.com
| Share life as it happens with the new Windows Live. Share now!
Posted: Sat Dec 22, 2007 4:34 pm Post subject: Cooling tube on lightspeed ignition box? |
If it didnt come with a provision for a cooling tube you are effected.Three years is about the timeline, although Klaus was not specific to the date.
