Illuminated Switches
kearney(at)shaw.ca
PostPosted: Fri Dec 14, 2007 9:30 am    Post subject: Illuminated Switches Reply with quote
Hi
As I plan my panel, I thought it would be nice to use illuminated switches in some applications. I came across some MilSpec switches but I suspect they would be very expensive.
Does anyone have a good source for switches that would be appropriate for panel use (other than the typical toggle switches).
Cheers
Les Kearney
#40643
C-GCWZ (Resereved)
Jim Berry
PostPosted: Fri Dec 14, 2007 10:48 am    Post subject: Re: Illuminated Switches Reply with quote
Look at the Honeywell AML available from Stein for $61.50, and probably others. LED lighted, and can be color coded and/or engraved. Pricey, but very nice.
Jim Berry
40482
Finishing forever
sam(at)fr8dog.net
PostPosted: Fri Dec 14, 2007 11:23 am    Post subject: Illuminated Switches Reply with quote
I used the small AML 34's my panel. Downside is there about $50.00 each with engraving.
[img]cid:part1.07050705.07080004(at)fr8dog.net[/img]
Les Kearney wrote:
<![endif]--> <![endif]-->
Hi
Cheers
Les Kearney
#40643
C-GCWZ (Resereved)
_popupControl();
 Filesize:  40.58 KB
 Viewed:  592 Time(s)
kearney(at)shaw.ca
PostPosted: Fri Dec 14, 2007 1:21 pm    Post subject: Illuminated Switches Reply with quote
Hi Jim
It looks like I will be using at AML's. The milspec switches I found were
$400+ each and had some very nice switch guards. I would have been tempted
to use at least one of them but for my bus master but they couldn't handle
the amperage I need. Damn!
Cheers
Les Kearney
#40643
C-GCWZ (reserved)
Ted French
PostPosted: Fri Dec 14, 2007 1:34 pm    Post subject: Illuminated Switches Reply with quote
Les
See: http://www.action-electronics.com/pdf/gcsw16.pdf
Look at the one at the bottom of this page. The light is independant of the switch. I wired mine so the panel lights bring it on fairly dim, but when switched on, they go full bright. Also available from Stein with white light instead of green.
See my panel at: http://www3.telus.net/elfrench/Panel_Feb_26_2007.jpg
Ted French C-FXCS
RV-10 Flying
[quote] --
Ted French
RV-10 fuselage
kearney(at)shaw.ca
PostPosted: Fri Dec 14, 2007 2:45 pm    Post subject: Illuminated Switches Reply with quote
Hi Ted
Those are very nice switches. Much nicer than the usual throw switches. Thanks for the link.
Cheers
Les
PS: Did I see your plane in a recent copy of COPA?. Where are you based?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted French
Sent: December-14-07 2:34 PM
Subject: RE: RV10-List: Illuminated Switches
Les
Ted French C-FXCS
RV-10 Flying
dougpflyrv(at)aol.com
PostPosted: Fri Dec 14, 2007 3:05 pm    Post subject: Illuminated Switches Reply with quote
HERE ARE SOME ROCKER SWITCHES..........
DP
http://www.aerocraftparts.com/Categories.aspx?Category=38940ec0-b260-4e9f-a23c-b80ff8e89c67
Ted French
PostPosted: Sat Dec 15, 2007 11:26 am    Post subject: Illuminated Switches Reply with quote
Yup
The 10;s for sale. Too much plane for solo flying....
Ted
[quote] --
Ted French
RV-10 fuselage
Ted French
PostPosted: Sat Dec 15, 2007 11:28 am    Post subject: Illuminated Switches Reply with quote
Yup
The 10;s for sale.. Too much plane for solo flying. I'm in Kelowna BC
Ted
[quote] --
Ted French
RV-10 fuselage
