		jrstone(at)insightbb.com Guest
				 Posted: Thu Dec 13, 2007 8:36 am    Post subject: Oil capacity |
				Can someone tell me how much oil an O-540 E4  B5 engine should hold?
  My engine will only keep about 8.5 quarts (dipstick  reading when cool) and deposits the rest on the belly and tail.
  Mods to the engine are:  Fuel Injection, 10:1  pistons, inverted oil system
  Aircraft: Harmon Rocket II
  Jim
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Hr2pilot(at)aol.com Guest
				 Posted: Thu Dec 13, 2007 9:07 am    Post subject: Oil capacity |
				If it likes 8 qt's let it run there.
  John  Harmon
 D & J Harmon Co., Inc.
 2201 Coy Avenue
 Bakersfield, CA  93307
 661-396-3570
 661-396-3574 FAX
 web: www.harmonso2generators.com
 See AOL's top rated recipes and easy ways to stay in shape for winter.
		smokyray(at)yahoo.com Guest
				 Posted: Thu Dec 13, 2007 1:58 pm    Post subject: Oil capacity |
				Mine likes just a hair over 6 qts, any more and it throws it overboard...
   RR
 Jim Stone <jrstone(at)insightbb.com> wrote:
   [quote]          Can someone tell me how much oil an O-540 E4 B5 engine should hold?
   Be a better friend, newshound, and  [quote][b]
				 Posted: Thu Dec 13, 2007 2:17 pm    Post subject: Oil capacity |
				Thanks John.
  Jim
  [quote]   ---
		T.gummo(at)verizon.net Guest
				 Posted: Thu Dec 13, 2007 4:21 pm    Post subject: Oil capacity |
				IO-540 J4A5 - no upgrades
  I put in ten quarts during oil changes.  After a  short engine run to replace oil in the cooler, etc.  I see 9 qts on the  dipstick.  More and it goes straight to the belly.
  Tom Gummo
 Apple Valley, CA
 Harmon  Rocket-II
  N-561FS, 360 hours, giant
  http://mysite.verizon.net/t.gummo/index.html
  [quote]   ---
				 Posted: Thu Dec 13, 2007 7:13 pm    Post subject: Oil capacity |
				Thanks Tom
  [quote]   ---
				 Posted: Thu Dec 13, 2007 7:19 pm    Post subject: Oil capacity |
				Rob
  6?  wow that seems low.  Which engine do  you have?
  You are making me feel better.
  Jim
  [quote]   ---
		russ(at)wernerworld.com Guest
				 Posted: Thu Dec 13, 2007 7:34 pm    Post subject: Oil capacity |
				Jim,
  Mine is a C4B5.  Following a change, it takes 11-12  quarts to get to a level of 9 on the stick (after running it).  If the tail  is lifted to level flight attitude, it indicates 10.  The C4B5 is made to  sit nearer level which explains the increase.  I also have the inverted  system.
  Russ
				 Posted: Fri Dec 14, 2007 2:01 pm    Post subject: Oil capacity |
				Jim, I have a C4B5 non inverted with a spin on filter. With no air/oil separator it throws it out above 6 qts doing acro. If I raise the tail it will show 7. My neighbor builds IO540s for airboats and agrees 6 qts is plenty. Any more and you"re adding 50wt humidity to the air...
 Smokey's iPhone
 On Dec 13, 2007, at 7:32 PM, "Wernerworld" <russ(at)wernerworld.com (russ(at)wernerworld.com)> wrote:
 [quote]  Jim,
  Russ
