Experimental vs. ELSA
mdnanwelch7(at)hotmail.co
PostPosted: Fri Dec 14, 2007 8:05 am    Post subject: Experimental vs. ELSA Reply with quote
Oh Wise Ones,
Can someone enlighten me to what the advantage(s) are of licensing a plane as ELSA, compared to the regular experimental catagory? I must admit, I failed to recognize the difference.
Currently, I am building a MkIII. I have a plain old private pilot's license which allows me to fly my Cessna 172 (which is for sale in Trade a Plane). As far as I cared, I was just going to license this MkIII as "experimental". If I could license it as ELSA (it's probably too late for me now, anyway)
does that mean I could let my pilot's license "transform" into a "sport license" if I don't get a bi-annual physical?
I would appreciate some basic clarification. Thanks
Mike Welch Kolb MkIII
Don't get caught with egg on your face. Play Chicktionary!
http://club.live.com/chicktionary.aspx?icid=chick_wlhmtextlink1_dec
PostPosted: Fri Dec 14, 2007 9:13 am    Post subject: Experimental vs. ELSA Reply with quote
Mike W:
I am no expert on this, and do not follow the regs closely as pertains to
it.
However, the way I understand the system, if you do not take your next
scheduled Class III Medical and you have a Private ticket, you are
automatically a Sport Pilot if you have a valid drivers license. And, you
can fly your experiemental MKIII as a Sport Pilot.
If you take the medical and flunk it, then you have to jump through all the
hoops and prove to the FAA that you are medically fit to fly again, and you
do not automatically become a Sport Pilot.
I asked my old country doc who gives me my flight physical, to let me know
if he thinks I am not going to pass my next Class III, and I won't fill out
the Med History and flunk it. He told me not to worry, I wasn't going to
flunk the Class III any time soon.
Take care,
slyck(at)frontiernet.net
PostPosted: Fri Dec 14, 2007 9:52 am    Post subject: Experimental vs. ELSA Reply with quote
Mike, not a "wise one" (maybe a wise***) but you already have a
light sport license by default.
As long as you drive airplanes under 1320 lbs and no more than two
seats you can dispense
with the useless flight physical. Unfortunately you still have to
comply with the biennial flight review.
The ELSA hocus pocus has something to do with using the plane for
commercial purposes
which doesn't appear to be largely in Kolb territory. Stick with
experimental.
BB
On 14, Dec 2007, at 11:01 AM, Mike Welch wrote:
Oh Wise Ones,
Dana
PostPosted: Fri Dec 14, 2007 10:37 am    Post subject: Experimental vs. ELSA Reply with quote
plane as ELSA, compared to the regular experimental catagory?... If I
If you're building it now, you can't license it as ELSA. ELSA is only for
"grandfathered" fat ultralights, and new approved LSA kits. E-AB is your
only option. However, if it meets the LSA requirements (2 seats, weight,
etc.), a sport pilot can fly it, as can a Private with no medical
(exercising the privileges of a Sport Pilot).
-Dana
Southern DOS: Y'all reckon? (Yep/Nope)
NeilsenRM(at)comcast.net
I'm not a expert on the regulations but I didn't renew my medical when it
came due and I have since gotten a biannual flight review in a 172. Since I
now fly only LSA "airplanes" I have no need to get a medical but can get one
if I ever decide to fly anything else and I don't risk loosing everything if
I have a bad medical. I still have a private pilot license so there is no
paper work required but I'm not current (as a private Pilot) due to the lack
of a medical. The private license gives me a bunch of advantages when flying
a LSA. I can fly any LSA make and model without being type certified, I can
fly into controlled airspace without an additional endorsement, I can fly
the faster LSAs without additional ratings , and I can get my biannual in
any LSA or most any GA aircraft I choose to fly.
About the only down side (that I can think of) of not having a medical is
that I can't fly at night. It seems like that is a limitation of the LSA
category.
This is the way I remember it.
Rick Neilsen
Redrive VW powered MKIIIC
Russ Kinne
PostPosted: Fri Dec 14, 2007 10:46 am    Post subject: Experimental vs. ELSA Reply with quote
As a card-carrying greybeard, I had concerns about blowing the Class
II medical, but just passed it. The Doc said if she found anything
disqualifying, she'd simply stop; and mark the form "airman did not
finish exam". The forms are all numbered and she has to turn it in
-- but at least you wouldn't have flunked the physical. Talk it over
first!
Mike W:
pertains to it.
next scheduled Class III Medical and you have a Private ticket, you
are automatically a Sport Pilot if you have a valid drivers
license. And, you can fly your experiemental MKIII as a Sport Pilot.
all the hoops and prove to the FAA that you are medically fit to
fly again, and you do not automatically become a Sport Pilot.
me know if he thinks I am not going to pass my next Class III, and
I won't fill out the Med History and flunk it. He told me not to
worry, I wasn't going to flunk the Class III any time soon.
Take care,
Thom Riddle
PostPosted: Sat Dec 15, 2007 6:25 am    Post subject: Re: Experimental vs. ELSA Reply with quote
Mike,
I'm not sure Matt's system allows attachment of .pdf files, but if it does, you can see the attached .pdf file that does a good job of explaining the differences among the ELSA, SLSA, and Exp. A/B rules for flight, training, maintenance etc. If Matt's system does not allow this type of attachment let me know and I'll send it to you directly. This should eliminate the speculation on the differences.
LSA_SP rules table.pdf
 Filename:  LSA_SP rules table.pdf
 Filesize:  59.83 KB
 Downloaded:  414 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Ralph B
PostPosted: Sat Dec 15, 2007 7:04 am    Post subject: Re: Experimental vs. ELSA Reply with quote
-Dana
E-LSA is for any Light Sport eligible aircraft including experimentals. If you built it, you can register it E-AB or E-LSA. E-AB allows the builder to inspect his own plane himself, whereas the E-LSA requires taking a 16- hour course to inspect your plane or any other E-LSA's that you own. The deadline for registering E-LSA is January 31st, 2008. The EAA has petitioned the FAA to extend the deadline to June 30th if you have your registration by the deadline. One advantage of E-LSA over E-AB is the plane may be worth more at the time of sale, because the buyer can inspect it without an A&P as E-AB would require. There is no deadline for E-AB registration, so if you miss the E-LSA deadline, you can register it E-AB.
Ralph B
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
bransom(at)ucdavis.edu
PostPosted: Sat Dec 15, 2007 11:23 am    Post subject: Experimental vs. ELSA Reply with quote
I was under the impression that "grandfathered" could include fat
ultralights built (and registered, inspected) up through Jan 31, 2008.
So in theory if an owner/builder completed an LSA plane today, mailed in
the registration request forms today, and got inspected, certified
before Jan 31, he'd have an ELSA plane. Not a likely scenario given the
short time remaining. Experimental Amateur Built has no deadline and
the plane could be LSA like or bigger, faster, slower, whatever.
As to pro/con of E-AB vs E-LSA airplane (separate from the pilot rating)
the differences are minor. Either can get its annual inspection by the
builder (with Repairman's certificate for that airplane), but if not
that person, the E-LSA can also be done by someone who has passed a 16
hour course on LSAircraft inspection, or by A&P. For the E-AB, if not
builder/Repairman it must be an A&P. So, long term and secondary
owners, annual inspections might be a little cheaper/easier for the
E-LSAircraft. One other issue according to EAA is that a E-AB would
likely see the normal 40 hour initial flight test area restriction,
compared to something like a 5 hour for E-LSA, and there have been some
grandfathered, previously flying ultralights getting 0 hour restriction
based on their already having many flight hours.
-Ben
> a plane as ELSA, compared to the regular experimental catagory?... If
for "grandfathered" fat ultralights, and new approved LSA kits. E-AB
is your only option. However, if it meets the LSA requirements (2
seats, weight, etc.), a sport pilot can fly it, as can a Private with
no medical (exercising the privileges of a Sport Pilot).
-Dana
jb92563
PostPosted: Mon Dec 17, 2007 8:51 am    Post subject: Re: Experimental vs. ELSA Reply with quote
Another option if you believe you might not pass a class 3 medical, but want to still fly E-AB is to register your unregistered aircraft as a E-AB glider "type".
As long as it is not being "type" approved you can call anything you built a glider.
You will however require a private glider license with self launch endorsement to fly it and would limit the resale value due to it requiring a private glider lic but Private Glider has a "Self declared" medical so you do not even need a drivers license.
Once it is registered AND COA'd you can not change it to another type.
Certainly a niche but perhaps might suit some pilots needs in odd situations.
Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
PostPosted: Mon Dec 17, 2007 9:24 am    Post subject: Experimental vs. ELSA Reply with quote
Ray
I'm don't understand why you would want to do this. The E-AB is a aircraft
registration that includes most categories including the LSA category which
doesn't require a medical. I legally fly my E-AB Kolb MKIIIC without a
medical.
Also the other day someone talked about 16 hour course that allows you to
maintain your ELSA aircraft. The key word is "your" airplane. I think there
is a longer course that allows you to work on other peoples ELSA & LSA with
less than a A&E certification?
Rick Neilsen
Russ Kinne
PostPosted: Mon Dec 17, 2007 1:17 pm    Post subject: Experimental vs. ELSA Reply with quote
Richard
Now I'm confused. you write
" I legally fly my E-AB Kolb MKIIIC without a medical."
I didn't think this was legal. Did you just let the medical lapse?
I've been told if you fail to PASS a medical, you can't fly a thing,
but if it expires you can still fly ELSA & gliders.
What's the straight scoop? I sure don't know, but I'd like to.
Russ Kinne
PostPosted: Mon Dec 17, 2007 1:45 pm    Post subject: Experimental vs. ELSA Reply with quote
I didn't think this was legal. > Russ Kinne
MKIII falls into the SP category, I believe, along with a lot of other
experimental homebuilts. A J3 is GA, but you can fly it with SP license.
Correct me if I am thinking wrong.;
PostPosted: Mon Dec 17, 2007 2:24 pm    Post subject: Experimental vs. ELSA Reply with quote
That's right I legally fly a E-AB that falls in the LSA category without a
medical. I let my medical lapse but can if I choose to fly a GA aircraft
again I can get a medical and use all my private pilot privileges again. I
let my medical lapse about 18 months ago and got my biannual check ride in a
C172 shortly after. Before the LSA rules went into effect my instructor
would check to make sure my medical was up to date or at least scheduled. He
did remind me I wasn't legal in anything other than a LSA airplane. Your
right I were to fail a medical I would be all done flying. It's one less
hoop I have to jump through and no chance of a fail.
Rick Neilsen
planecrazzzy
PostPosted: Mon Dec 17, 2007 2:25 pm    Post subject: Re: Experimental vs. ELSA Reply with quote
When I was getting my Tailwheel endoresment in a PA-12 , there was a guy getting his SP in a J-3 ( he was doing his X-country at the time )
Gotta Fly...
Mike & "Jaz" in MN
Building Buttercup
http://groups.yahoo.com/group/Buttercup-STOL/
a58r(at)verizon.net
PostPosted: Mon Dec 17, 2007 2:49 pm    Post subject: Experimental vs. ELSA Reply with quote
Re: Biennial
What do you say to an instructor (very new) that would not give a biennial because guy doesn't have a medical! Says a 172 isn't a Sport, and w/o medical that's all guy can fly. Catch 21.9? Let the games/threads begin.
regards,
Bob N.    FireFly 070 Old Kolb
PostPosted: Mon Dec 17, 2007 3:06 pm    Post subject: Experimental vs. ELSA Reply with quote
BN, find a less ignorant instructor.  Last time I knew, any time at least one guy sitting up front is legalanyone can fly the plane.  My kids used to fly my aeronca, the younger one did quite well.
If you can afford to charter a bizjet you can crank it around too. -hence the summer trade in T6 rides.
(frankly I wouldn't be comfortable stressing any of that ancient WWII machinery, no matter how pretty
the paint job)  T-33s and T-34s come to mind.
BB
On 17, Dec 2007, at 5:48 PM, Bob Noyer wrote:
[quote]Re: Biennial
regards,
Thom Riddle
PostPosted: Mon Dec 17, 2007 3:52 pm    Post subject: Re: Experimental vs. ELSA Reply with quote
BB is correct about the BFR in the sense that if there is only one pilot that is current and legal in the aircraft being used for the BFR, then that person must be the official PIC for that flight. Therefore, a Sport Pilot who has never set foot in anything other than an LSA type aircraft can legally get his/her BFR in a C-172 if the instructor agrees to be the PIC for that flight. Some CFIs will and others won't and there is no law that requires any particular CFI to do that if they don't want to.
Of course this has nothing at all to do with the subject "Experimental vs. ELSA".
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
