fstringham
Posted: Sun Dec 09, 2007 4:44 pm Post subject: Z 13-8 P-mag wiring |
I am now to the point of wiring up my dual p-mags per Z 13-8. I am not quite sure of connection points P-Mag to the S700-2-10 switch. As viewed from the screw side of the P-Mag plug they are numbered 1 through 6 Left to right according to the P-Mag install manual. So my question is on the Z13-8 diagram the green/orange/red /black would correspond to which numbers on P-mag install diagram. They have #1 black as the ground...#4 orange connects to your ignition ON/OFF (ground) p-lead switch....#5 red connects to your main 12 volt aircraft buss through a dedicated circuit breaker (not provided) using 18 gauge wire. E-MAGs should use a 5-amp
breaker, and P-MAGs should use a 3-amp switchable breaker.”6” green is a courtesy (optional) connection to provide a digital tack signal.
So it appears to me the function/position of Z13-8 to P-Mag manual are the same the question in my mind is are the numbers the same????? as the water drips from behind my ear!!!!!!!
Also Bob is there any new info on the p-mag wiring potential changes................
Thanks inadvance for your help.
Frank (at) sgu RV7A light at the end of thwe tunnel...hopeing it isn't a big ole train!!!!!!!!!!!!!!!
aurbo(at)ak.net Guest
Posted: Sun Dec 09, 2007 5:37 pm Post subject: Z 13-8 P-mag wiring |
Frank,
I wouldn't expect any answers back from Bob on this question but here is the answer your looking for.
#'s 1 & 4 are both grounds. The #1 grounds to the panel, The #4 is the ground (kill) for the mag.
#5 is the red wire that goes to power.
# 6 is the org wire that gores to the Tach.
BUT: I would suggest you don't follow the Z-13 in wiring the E/P mags. The Emagair folks don't use that system why would you?
I started to use the Z figures to wire the E/P mags and changed my mind. They are not wired the way the Emagair folks recommend if you wire them that way. But it was hard to divert from using the Z figures as I was attached to them But in this case the Z figure offers no advantage versus using the Emagair system and is in fact more confusing, at least to me. The Z figure uses the same parts count as the Emagair system and doesn't require a "hidden" switch to disable the mags. The Emagair system just uses on off toggles which are hard to screw up.
Mike Ice
baffles and cowling
nuckolls.bob(at)cox.net Guest
Posted: Sun Dec 09, 2007 9:37 pm Post subject: Z 13-8 P-mag wiring |
orange connects to your ignition ON/OFF (ground) p-lead switch.....#5 red
breaker, and P-MAGs should use a 3-amp switchable breaker."6" green is a
Figure Z-13/8 has been updated at:
http://aeroelectric.com/articles/Rev11/AppZ_R11L.pdf
http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z13-8m.dwg
( -Thomas Paine 1776- )
fstringham
Posted: Mon Dec 10, 2007 6:51 am Post subject: Z 13-8 P-mag wiring |
Mike
Thanks for the info........
Frank (at) SGU RV7A.................NDY................but real close!!!!!!!!!!!!!!!
[quote] Date: Sun, 9 Dec 2007 16:31:01 -0900
Subject: Re: Z 13-8 P-mag wiring
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass EC_BODY.hmmessage {font-size:10pt;font-family:Tahoma;} Frank,
Mike Ice
baffles and cowling
fstringham
Posted: Mon Dec 10, 2007 6:56 am Post subject: Z 13-8 P-mag wiring |
Thanks Bob........it looks like a pretty easy wiring exchange from the old 13/8 to the now acceptable scheme......Thanks for all your efforts in behalf of we DIY guys and gals!!!!!!!
Frank (at) SGU RV7A ...........NDY.........BUT REAL CLOSE !!!!!!!!!!!!!!!!!!
> Date: Sun, 9 Dec 2007 23:35:32 -0600
Quote: | To: aeroelectric-list(at)matronics.com
Subject: RE: AeroElectric-List: Z 13-8 P-mag wiring
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Posted: Mon Dec 10, 2007 7:38 am Post subject: Z 13-8 P-mag wiring |
At 07:53 AM 12/10/2007 -0700, you wrote:
Quote: | Thanks Bob........it looks like a pretty easy wiring exchange from the old
My pleasure sir. But know that last night's posting
was pre-mature. Too many beers with the chili!
Go back and get the latest drawings posted as of a
few minutes ago.
sportav8r(at)gmail.com Guest
Posted: Mon Dec 10, 2007 10:25 am Post subject: Z 13-8 P-mag wiring |
I think you've reversed the functionality of the E- and P- mags, Bob. P is the self-powering type, and E is the externally-powered-only model, so they appear to be reversed on Z-13/8 labels. That's the way I remember it, anyway.
-Bill B
On Dec 10, 2007 10:37 AM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
few minutes ago.
fstringham
Posted: Mon Dec 10, 2007 11:16 am Post subject: Z 13-8 P-mag wiring |
Bob
To much Beer with Chili could make the mind a bit fuzzy I would suspect......I was given a wake up call at 2:00 AM sunday morning to bail my youngest child (26 going on 15) out of the county pokkie for DUI/Speeding. Booking Sarg's said he isn't drunk.........so why the citation. It is a great way to keep those real Bad ?????? Saint George Kids out of Hurricane City late at night. Ya and it will cost about $1000.00 to get the auto out of impound/fight the DUI in court/and maybe my bail for killing the kid!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!So lets put this little mistake in perspective.
Bob, wiring my airplane, choosing instruments, wiring materials, and help with my crazy ????????????????? was given by you....most times gently sometimes with a douse of Hey Frank wake up and smell the coffee!!! So again THANKS
Frank (at) SGU RV7A .....NDY........But CLOSE
> Date: Mon, 10 Dec 2007 09:37:15 -0600
few minutes ago=================
Posted: Mon Dec 10, 2007 8:44 pm Post subject: Z 13-8 P-mag wiring |
At 12:19 PM 12/10/2007 -0500, you wrote:
Quote: | I think you've reversed the functionality of the E- and P- mags, Bob. P
it, anyway.
-Bill B
Actually, either Emag product can be wired either
way. If you power the device from a switched bus
(any bus but a battery bus) then you don't necessarily
need to shut off ship's power when the engine is stopped.
Current drain in the non-running state is tens of milliamps.
If you want to run the ignition from a battery bus (my
favorite source) then it's necessary to disconnect the
power source when the aircraft is powered down so that
you don't run the battery down.
My preference is to minimize total numbers of switches
so it seems most practical to use the 2-10 so that
both power and control of the ignition system can
be accomplished from the same device. If you run
the p-mag from a switched bus and control it with
a single pole switch, then the occasional test of
the internal power source can be accomplished by
momentarily powering down the bus that supplies
ship's power to the ignition system. Hence the
suggestion that the P-Mag be powered from the main
bus and the E-Mag be powered from the battery bus.
