bertrv6(at)gmail.com Guest
Posted: Fri Dec 07, 2007 9:45 am Post subject: Radio question |
Bob:
I have tried to contact you thru this, but no luck. I guess i had the wrong
e-mail? Some one fro the list gave me this one. Hope you receive it.
I want to add a second radio to my rv6a, but because lack of space I cannot
install an Audio panel.
Question is, if I add another radio, I am thinking of the
MicroAir...small and not
too expensive) Is there any Switch or way that I cfould use both radios, that is
switch from one to another, just as when you have the Audio Panel??
I have now the Kin's radio 125..
Thanks for your reply
Bert
billp(at)wwpc.com Guest
Posted: Fri Dec 07, 2007 10:46 am Post subject: Radio question |
Bert,
The KX-125 has an audio mixer in it. You need to add a couple of Single
Pole Single Throw switches to select which receive audio's you want to
hear and a Double Pole Double Throw switch to select which radio the Mic
and PTT is hooked up to. You don't need any electronics outside what the
KX-125 already has.
You need the KX-125 install manual to see all the wiring.
- Bill
Bert Murillo wrote:
Bob:
Bert
list(at)toddheffley.com Guest
Posted: Sun Dec 09, 2007 6:15 pm Post subject: Radio question |
Sir,
I would like to offer a different idea to adding a second com to your
airplane.
While the reply that the KX125 has audio amp capability may be true -
I have wired such an application my self - I would like to offer you
an alternative.
you might consider a hand held radio as a second com in a VFR installation.
Here is my thinking.
You can purchase a better radio for a lower price in the handheld
versions. Just simple economics. More demand for handhelds, better
competition in the market= more value.
A second com that is wired to "a few switches" is subject to the same
failures as the first com. Mic jack loose, stuck key line, depleted
battery, Over-voltage. screw loose on the what-ever-bus.....
For a second radio, a quality handheld, MOUNTED to the panel, with a
REAL antenna, a fresh set of batteries (or two), and a mic and phone
jack that are easy to get to, provides a more independent backup than
a second installed radio.
This idea is not helpful for a rusted heldheld radio with 5 loose
cables, dead batteries, rolling around in a pick-up back at the
airport.
And lastly, I am the poor slob (Avionics Technician) that ends up
troubleshooting "A few switches" with no prints.
Just something to consider, sorry about the rant.
todd
mlas(at)cox.net Guest
Posted: Mon Dec 10, 2007 5:45 am Post subject: Radio question |
The only problem I see is the lower power output of the handheld (less
then 1 watt). If you're flying an airplane that flies slow and you
normally call the airport at 5-15 miles out, it should be fine. But I
find that trying to make transmissions at distances of more then 15
miles within 4000 feet of the ground are hit and miss. Just a thought!
