kitfox heater
eskflyer
PostPosted: Thu Nov 29, 2007 11:36 am    Post subject: kitfox heater Reply with quote
I am in need of 1 heater that was for the kitfox for the 582 . I f anyone has one and wants to part with it give me a call at 580-695-8778 or email at eskflyer(at)yahoo.com
FLY FUN FLY LOW FLY SLOW
John Perry
Kitfox 2 N718PD
582 cbox 2:62-1 IVO IFA
1220 Full Lotus
dave
PostPosted: Fri Nov 30, 2007 2:21 am    Post subject: Re: kitfox heater Reply with quote
I have two planes to make heaters for in the next week.
Both will be exhaust heater with a heat muff. If you want pics , let me know. One is a 532 and the other is a 503. Actually make that 3 planes as I have a tuned pipe on my 582 now and my old heater won't work unless I change back to stock rotax pipe. I will try one for mine too.
Also you can put a scoop or oil bottle on back of rad to get some heat from radiator but it will not be enough once temps fall below 20.
And a bonus is if you want carb heat and you are using hot air from exhaust heat muff this is a great time to make it . I only see Bings icing on 582 usually in the 30 to 35F temp range. I get it several times every year. 503 get it even less as it does not have a rotary valve and allows some air/fuel mix to pulse back out of the carb and seems to keep it warmer.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
akflyer
PostPosted: Wed Dec 05, 2007 9:00 am    Post subject: Re: kitfox heater Reply with quote
Hey Dave will you post up a few pics of the heat muff? I am getting ready to make one for my avid and dont feel the need to re-invent the wheel if you have come up with something that works well.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Tom Jones
PostPosted: Sat Dec 08, 2007 5:16 pm    Post subject: Re: kitfox heater Reply with quote
I flight tested my Cabin Heater today. It didn't hardly put out any heat at all. It is an exhaust muff on a 503 Rotax. Size of the muff is 9" X 10". There are nine pot scrubbers in the muff. 2" scat duct ram air and same size ducting to between the rudder pedals. Any suggestions to try on this one to make it work better or should I return to the drawing board? Pictures attached.
 Filesize:  315.22 KB
 Viewed:  1030 Time(s)
 Filesize:  307.98 KB
 Viewed:  1007 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
MichaelGibbs(at)cox.net
PostPosted: Sat Dec 08, 2007 5:35 pm    Post subject: kitfox heater Reply with quote
Tom sez:
heat at all.
How would you described the air flow through your tubing, Tom? Was
it blowing like a tornado or was it more like a gentle breeze?
Assuming that your muffler got nice and hot, my first suspicion is
that the air is spending too little time in contact with the heat
source.
Mike G.
N728KF
Phoenix, AZ
Lynn Matteson
PostPosted: Sat Dec 08, 2007 6:17 pm    Post subject: kitfox heater Reply with quote
I'm the furthest from real knowledgeable on heaters...I'm still
working on mine...but from what I've seen and learned, you should
have a larger outlet than an inlet. Also, with your setup, it would
be possible to put some baffles inside the muff so that the air has
to make some turns, like a labyrinth, which will make the air slow
and thereby picking up heat. If you look at your setup, the air can
flow from inlet to outlet passing through only 3 pot scrubbers. You
could install two divider baffles which would force the air to pass
through 3 scrubbers, make a 180° turn, go through 3 more scrubbers,
make another 180° turn, and go through the final 3 scrubbers, then
through the outlet. By this time the air will be heated and therefore
expanded, hence the need for making the outlet larger. I made the
mistake of making my ins and outs the same size, and this was pointed
out to me.
I made two small 3" x ~6" muffs that wrap around my Jabiru exhaust
pipes (~1400° F) and I still don't have sufficient heat. It's a
matter of slowing down the air to allow for heat transfer, yet enough
flow to do some good. I figured my exhaust pipes would be the best
source, but I'm starting to think that the muffler, with it's larger
area, would be a better, even if cooler, source of heat. Can you make
your muff larger, like build it so it wraps completely around the
muffler, or do you have cowl clearance problems?
Lynn Matteson (flying cool in Michigan) : )
Grass Lake, Michigan
flying w/440+ hrs
Tom Jones
Classic IV, Phase one
Ellensburg, WA
Lynn
Kitfox IV-Jabiru 2200
N369LM
thesupe(at)hotmail.com
PostPosted: Sat Dec 08, 2007 8:09 pm    Post subject: kitfox heater Reply with quote
I was flying my Avid today on skis in northern Mn, High temp today was +4 F. Inside the plane it was about 40. I have the Jabiru engine and made a box/heatmuff that fit around the muffler. The box has baffles inside it so the air comes in the bottom center, goes to the ends of the box, then the next baffle forces the air to go to the center of the box, there it goes up to the top level of the box and goes to the ends of the box where I have the outlets that go to the firewall openings. I have a 120 MM 12 volt computer fan that blows into the bottom of the heat muff, but just the air pressure in the cowl will move the air through the heat muff. I had to take the oil cooler off to get my oil temps up, and I was picking up the warmed air off the cooler. With that setup, it would almost cook you out of the plane with the fan on. If anyone want to see a pic or two, I could send it to them, but I don't know how to post a pic to the list. Jim Chuk Avid MK IV
[quote] From: lynnmatt(at)jps.net
Subject: Re: Re: kitfox heater
Date: Sat, 8 Dec 2007 21:16:40 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
out to me.
flying w/440+ hrs
> --> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
> Tom Jones
> 503 Rotax, 72 inch Two blade Warp
> Ellensburg, WA
You keep typing, we keep giving. Download Messenger and join the i’m Initiative now. Join in!
Guy Buchanan
PostPosted: Sat Dec 08, 2007 8:16 pm    Post subject: kitfox heater Reply with quote
Thoughts:
1. Though the inside (muffler skin) is hot, the outside is not, so
you'll only get air 1/2 as hot as you expect. Note that there's more
"cold" skin area than "hot" skin area since the cold has a larger diameter.
2. The "most direct" path from intake to exit requires very little
contact, "percentage wise" with the hot surface.
3. Virtually any air exchange at the edges will "cool" the muff.
Suggestions:
1. Coat the inside of the muff with the stick-on fiberglass/ foil
insulation. (ACS - "Heat Barrier - Adhesive Backed" PN 08-00630.) The
stuff's about 3/32" thick. This will insulate the outer skin,
preventing cooling of the pot scrubbers.
2. Install an angle to baffle flow. I think one running parallel the
muffler just "downstream" of the intake, forcing the incoming flow to
turn laterally to the outboard 2/3 of the muff would help a lot. This
angle MUST seal against the muffler.
3. Speaking of seal, figure out some kind of high temp seal for the
edges and angle baffle. I don't think you need RTV, I'm betting
there's a nice rubberish seal for metal edges that can handle the
800F or so the muffler sees. (Worst case you could figure out how to
use the spam can cowl baffle seal material.) (I checked McMaster and
they have some edge trim, (page 3619,) but it's silicone and good to
only 450F. You could try it, though.)
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
john(at)leptron.com
PostPosted: Sat Dec 08, 2007 9:28 pm    Post subject: kitfox heater Reply with quote
The first way to heat better is to use Lowell's louvers system to control
the air going to the radiator and oil cooler, way cool stuff.
john
dave
PostPosted: Sun Dec 09, 2007 1:07 am    Post subject: Re: kitfox heater Reply with quote
Tom,
I think part of the problem is that you need a larger air inlet. My old one which I had on Rotax muffler same as yours was about 3/4 inch height and the total length of the muffer ( about 15 " maybe ) I have the round Kitfox cowl and it allows more than plenty of air into the cowl. Number of pot scrubbers 9? Well i doubt that i had more thna 4 or 5 in mine and I had a long door spring 16" long attach to each side of heat muff and stuffed inside. This acted as a retainer to hold the pot scrubbbers, yes they are only at the entrance of hte heat muff.
Oops just found this -- i forgot i did this http://www.cfisher.com/heatmuff/
I never ended up making heat muffs this week as I had a Kitfox come in for some work and on the way here the owner had a clevis pin come out on the bar that holds the wing to vertical stab while in motion on a trailer the wing started to swing out and did some damage. Almost done now and I did run it yesterday outside, it has a heater with a fan in the cabin and seem to really blow out the heat.
Here is how mine worked .
http://forums.matronics.com/viewtopic.php?t=21994
Went out for flight a while ago this AM .
OAT -13 C (9F )
Cabin temp flying 10 to 12 C ( 50 to 54 F )
So basically Heating give me approx a boost in cabin temps about 40 to 45F
increase on a overcast day and not bone chilling but still well below
freezing.
Tom Jones
PostPosted: Sun Dec 09, 2007 6:07 am    Post subject: Re: kitfox heater Reply with quote
Thanks folks, these all sound like good logical suggestions to improve the heater.
Mike, the air flow is more like a gentle breeze. A cool gentle breeze. OAT air temperature was 29 Degrees F and I estimate inside was about 45 but I think most of that warmth was from the sun.
I'll make some mods and hope I can test again tomorrow. It's supposed to snow today.
Keep the ideas coming if you have some more anyone.
Tom Jones
Classic IV
Ellensburg, WA
PostPosted: Sun Dec 09, 2007 6:32 am    Post subject: kitfox heater Reply with quote
If your engine is fan cooled, (503) you have hot air comming off of the heads now, I would duct that air through a muffler heatbox to warm the air further. The engine fan moves quite a bit of air, I would just watch the CHTs to make sure I wasn't restricting the air to much and getting the engine to warm. If you are useing outside cold air, you have to warm it up that much more to do you any good. I would get a carbon monoxide detector card also. Jim Chuk Avid Mk IV Chisholm Mn
Subject: Re: kitfox heater
Date: Sun, 9 Dec 2007 06:07:03 -0800
Tom Jones
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=151280#151280
Get the power of Windows + Web with the new Windows Live. Power up!
Tom Jones
PostPosted: Sun Dec 09, 2007 6:52 am    Post subject: Re: kitfox heater Reply with quote
Jim, tapping into the warm air from the engine has been in the back of my mind but I haven't figured out a way to do it without butchering up the fan cowl. It is a good option that I may fall back on if I can't get the exhaust muff system up to speed.
Tom Jones
Classic IV
Ellensburg, WA
dave
PostPosted: Sun Dec 09, 2007 9:04 am    Post subject: Re: kitfox heater Reply with quote
Tom,
I checked earlier in shop- I had 3 pot scrubbers in heat muff.
will post some pics for you later.
A gentile breeze if all you need but you need it hot not cool and it should get real hot. I would venture to guess that you have slowed the air but you are not collecting the heat. enough. When you finally tune it in you gonna be quite happy.
Remember I have coming in about 6 or more sq inches inlet and you only have one SCAT tube. Although you are getting air fact remains that you still need to get that air hotter.
503 air outlet by plugs is used very successfully by the Challenger guys as well.
dave
PostPosted: Mon Dec 10, 2007 2:46 am    Post subject: Re: kitfox heater Reply with quote
Ok I posted a few pics and info on how I made a cabin heat muff from a Rtoax 582 http://www.cfisher.com/heatmuff1/
Mine works well and the heat coming into cabin is HOT not warm.
