ron.mcgann(at)baesystems. Guest
Posted: Mon Dec 03, 2007 8:16 pm Post subject: Slick Start |
G'day all,
Vans has finally received their back ordered Unison Slick Start systems. Was curious as to how many are going with this option and whether anyone has a wiring diagram/installation manual so I can prepare for the installation.
Ron
[quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
billderou(at)yahoo.com Guest
Posted: Tue Dec 04, 2007 1:32 pm Post subject: Slick Start |
I've got one on my aircraft wired to a retard breaker magneto. Works well. Only problem I have had is the Slick Start seems to have caused a ringing on the P-lead that interfered with my GRT EIS 6000 counting ticks. Solved the problem by moving the tach sensor to the other mag.
I recall that they were going to redesign this unit and I wonder if the delivery problems were a result of this engineering/manufacturing effort. You may have the new design. Anyway, I will look for a wiring diagram.
Bill DeRouchey
billderou(at)yahoo.com (billderou(at)yahoo.com)
N939SB, flying
"McGANN, Ron" <ron.mcgann(at)baesystems.com> wrote:
[quote] G'day all,
Ron
[quote]"Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks [quote][b]
Posted: Tue Dec 04, 2007 1:43 pm Post subject: Slick Start |
Thanks Bill,
On a related subject, I have dual mags and was going to add a tacho source select switch (left/right) for the GRT EIS 6000. Is this something that others have done/recommend? How effective is a mag check at run-up without this switch?
TIA
Ron
187 finishing
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Wednesday, 5 December 2007 8:00 AM
Subject: Re: Slick Start
Bill DeRouchey
N939SB, flying
| Quote: | G'day all,
Ron
| Quote: | "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks
| "Warning:
your computer."
Dave(at)AirCraftersLLC.co Guest
Posted: Tue Dec 04, 2007 2:21 pm Post subject: Slick Start |
Here's what you need for the tach signal, assuming you're using two tach switches and not a key switch.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Tuesday, December 04, 2007 1:41 PM
Subject: RE: Slick Start
Thanks Bill,
TIA
Ron
187 finishing
| Quote: | From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Bill DeRouchey
N939SB, flying
| Quote: | G'day all,
Ron
| "Warning:
your computer."
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
 Download |
| Filename: |
Mag_Switch_for_electric_tach.pdf |
6.41 KB |
| Downloaded: |
290 Time(s) |
Posted: Tue Dec 04, 2007 5:06 pm Post subject: Slick Start |
Ron-
From only my own experience .... I simply listen to the engine for smoothness and a small rpm drop and ignore the fact that the rpm reads zero. My sub-conscious can spot a miss within 10 milliseconds of the event and awake me from the dead in another 10 milliseconds. But thats just me.
If you feel more comfortable with the switch then do it. I was seeing a problem with the EIS reporting (with an alert) the engine running at 3000, 3200, 3550 rpm. Usually I saw this in a decent and believed I was decending too fast or something was wrong with my governor. Then I saw the alert flying the pattern when the engine could not have possibly been overrevving. Looked at the P-leads with an oscilloscope and the two P-leads had vastly different patterns. With the Slick Start it looked like ringing and the other mag looked more like I expected to see. Recently changed the sensor to the mag without the Slick Start and I have not seen the over rev since, but I would feel more comfortable with this fix if I had another 10 hours, or so, on the aircraft since it happened randomly.
So, go ahead and add the switch but if you see an overrev and it is pointing to the Slick Start mag then change it to the other mag to verify the problem. It would be good to get more input on this problem and the switch could be a great debugging tool.
[quote] Thanks Bill,
TIA
Ron
187 finishing
Bill DeRouchey
N939SB, flying
| Quote: | G'day all,
Ron
or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks |
| "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its [quote][b]
Tim Olson
Posted: Tue Dec 04, 2007 6:32 pm Post subject: Slick Start |
I feel the same way as Bill. The mag and the Lightspeed have
different pulse counts for RPM, so I set my EIS up for the
lightspeed. It works great, but I don't get to see what
my mag drop is when running on just the mag. Even with a switch,
one would read different than actual, due to the pulse count
difference. To me, I see it as no big deal. When you run on
just the lightspeed, you only drop 10-20 RPM. When you run on
just the mag, you can tell pretty easily if it's running smooth
or dropping a big drop. The most important thing is that the
rpm doesn't drop a ton and it runs smooth, and you can hear that
by ear easily. Besides that, with a lightspeed I haven't had
a single iota of problems with my top plugs, and with fine wire
plugs, my bottoms are staying very clean too...so fouling
hasn't been an issue.
Bill DeRouchey wrote:
| Quote: | Ron-
just me.
happened randomly.
*/"McGANN, Ron" <ron.mcgann(at)baesystems.com>/* wrote:
Thanks Bill,
TIA
Ron
187 finishing
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*Bill DeRouchey
*Sent:* Wednesday, 5 December 2007 8:00 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Slick Start
Bill DeRouchey
billderou(at)yahoo.com <mailto:billderou(at)yahoo.com>
N939SB, flying
G'day all,
installation.
Ron
* .matronics.com/contribution p://www.matronics.com/Navigator?RV10-List ics.com *
rv10builder(at)bellsouth. Guest
Posted: Tue Dec 04, 2007 6:40 pm Post subject: Slick Start |
I needed to wrap up the engine installation so I gave up on SS since I
was hearing several more months. I swapped out my retard breaker mag for
a impulse coupled mag. Too bad...
AeroElectric Connection article on wiring attached.
Brian Sutherland
Nashville, TN 40308
(still finishing!)
McGANN, Ron wrote:
G'day all,
Ron
"Warning:
your computer."
 Download |
| Filename: |
ShowerOfSparks.pdf |
306.76 KB |
| Downloaded: |
391 Time(s) |
wvu(at)ameritel.net Guest
Posted: Tue Dec 04, 2007 8:22 pm Post subject: Slick Start |
I have dual Slicks, both have couplers. No Slick Start. EIS tach is
connected to only the left mag. I listen for mag drop on the other. No
issues so far.
Anh
N591VU
tdawson-townsend(at)auror Guest
Posted: Wed Dec 05, 2007 6:11 am Post subject: Slick Start |
We wanted SlickStart for our Bendix retard (shower of sparks) magneto, but low and behold, as part of Slick’s “redesign” of the SlickStart, they dropped the SS1002 model, which was for Bendix (non-Slick) magnetos. Now they only support Slick mags, at least for retard magnetos.
Most dealers don’t stock SlickStart (instead shipping from factory), or had expended their stock, but after much searching, I found possibly the only remaining SS1002 Slick Start module in the world, in Germany. Installing it soon . . .
TDT
40025
I love wheelpants!
Tim Dawson-Townsend
Aurora Flight Sciences
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
