grantr
Posted: Mon Dec 03, 2007 6:59 am Post subject: Wing pins and other hardware |
I have my trailer setup so I can get my MK III in and out easily. I ran the plane around the yard yesterday. The 503 seems to run well. It started right up and ran good on the taxing around the yard.
I want to do a few things to it before I take it to my instructor/ test pilot.
I want to change the fuel filter and rebuild the fuel pump and change the spark plugs.
I also want to buy some new AN hardware for some of the things like the wing attachment pins.
Are these the right type of pins for the wing pins? I don't want to get the wrong ones and have one break!! That would be deadly:(
http://www.aircraftspruce.com/catalog/hapages/clevispins.php
What are the best places online to order AN parts and other stuff like wheels brakes gauges and Rotax parts?
Grant
jindoguy(at)gmail.com Guest
Posted: Mon Dec 03, 2007 7:31 am Post subject: Wing pins and other hardware |
Easiest place to make sure you get the right parts is:
http://www.tnkolbaircraft.com/
Rick
On Dec 3, 2007 8:59 AM, grantr < grant_richardson25(at)yahoo.com (grant_richardson25(at)yahoo.com)> wrote:
[quote]--> Kolb-List message posted by: "grantr" < grant_richardson25(at)yahoo.com (grant_richardson25(at)yahoo.com)>
Grant
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Mon Dec 03, 2007 8:46 am Post subject: Re: Wing pins and other hardware |
Put a Stratomaster E1 engine monitor instrument on your X-mass wish list $199
I just put one in my Ultrastar to save panel real estate and it does
CHT, EGT, RPM, Hobbs and FUEL level....plus Alarms on all these things and a dummy alarm light/flashing display item to direct your attention to any problem.
It is completely configurable for sensors, limits, alarms etc etc.
It will do more (multiple CHT's, EGT's, oil presure, Oil Temp, Water temps etc) but that is all I need for now.....these things are fantastic and cost LESS than all the instruments is replaces! Plus its just one 3.5" standard instrument hole used.
The Fuel level sender is hooked up to the Oil-Presure lead....my own modification and works great plus I have a low fuel alarm setting as a bonus.
I'm delighted by what this thing does.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
KolbFlyerJim(at)aol.com Guest
Posted: Mon Dec 03, 2007 2:08 pm Post subject: Wing pins and other hardware |
HI Grant
Another good sourse of AN hardware is WagAero in Lyons Wisconson shipping is usually the same day if you order before 10:00 am C.D.T DoNot use C.P.S.
Jim
WhiskeyVictor36(at)aol.co Guest
Posted: Mon Dec 03, 2007 5:28 pm Post subject: Wing pins and other hardware |
In a message dated 12/3/2007 5:09:27 P.M. Eastern Standard Time, KolbFlyerJim(at)aol.com writes:
Jim,
Just wondering why. What reason?
Bill Varnes
Original Kolb FireStar
Audubon NJ
Check out AOL Money & Finance's list of the hottest products and top money wasters of 2007.
grantr
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Tue Dec 04, 2007 7:49 am Post subject: Wing pins and other hardware |
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
rowedenny(at)windstream.n Guest
Posted: Tue Dec 04, 2007 8:07 am Post subject: Wing pins and other hardware |
California Power Systems, long time UL parts and accessory company. Look em
up on line or call 1800 air wolf.
I have found Aircraft Spruce and LEAF "Leading Edge AirFoils" to have better
service and prices.
Denny Rowe
Posted: Tue Dec 04, 2007 2:48 pm Post subject: Wing pins and other hardware |
California Power Systems An ultralight parts source.
Jim
Posted: Tue Dec 04, 2007 2:49 pm Post subject: Wing pins and other hardware |
Thanks Denny
Posted: Tue Dec 04, 2007 3:12 pm Post subject: Wing pins and other hardware |
Hi Bill
The people at C.P.S are ARROGANT and RUDE and don't care about there costumers. Mike should worry about his costumers more than profits. I will never buy from them again.Buy From L.E.A.F. (Leading Edge Airfoils) They care about there costumers.
Jim
UltraStar N2613M
