jimumble(at)myway.com Guest
Posted: Sun Dec 02, 2007 3:30 am Post subject: Ultrastar engin recommendation |
Hi ultralight fliers of the Ultra stars
Im new on the board ,have been flying a while bought my ultra star so Im not very technical about the specks
Could some one tell me what size engine could I put on it or should I stick with cuyuna ulII02 Has N# would like a
4 stroke prop. size and recommendations Thanks Jimmy ps I see another jim so Im jimmy
No banners. No pop-ups. No kidding.
Make My Way your home on the Web - http://dell.myway.com[/b]
d-m-hague(at)comcast.net Guest
Posted: Sun Dec 02, 2007 6:01 am Post subject: Ultrastar engin recommendation |
At 06:30 AM 12/2/2007, jim wrote:
| Quote: | Im new on the board ,have been flying a while bought my ultra star so Im not very technical about the specks
4 stroke prop. size and recommendations Thanks Jimmy ps I see another jim so Im jimmy |
Hi Jimmy, the Cuyuna is quite adequate for the Ultrastar, it's what I have on mine. The Cuyuna is probably the lightest of the suitable engines, but if yours in N-numbered you're not concerned about making 103 weight. Quite a few are flying around with Rotax 447's too., and I've heard of at least one with a Subaru engine, but you definitely will pay a large weight penalty for a 4-stroke. Cuyuna's are the least expensive to work on but there are a lot of people out there who are familiar with the Rotax. I suppose you could put a 1/2 VW engine on an Ultrastar but I've never heard of it being done.
My Cuyuna is nearly new but if it I needed to replace it my short list would probably be another Cuyuna or perhaps the Simonini Victor 1+ (2 stroke, single cylinder, dual ignition).
-Dana
Drink wet cement, and get completely stoned! [quote][b]
worrybear(at)verizon.net Guest
Posted: Sun Dec 02, 2007 6:48 am Post subject: Ultrastar engin recommendation |
Jimmy, I lost my cuyuna on my Ultrastar in July and spent a lot of time trying to figure out alternatives to the UL202. The 447 or 503 were the only viable options I could come up with and even those would require motor mount modifications to use the gear box instead of the cuyuna belt drive. Mounting any 4 cycle seemed to be impossible. My suggestion would be rebuild the cuyuna.
Dan Walter
Ultrastar and Druine Turbulent
Palmyra, Pa.
Posted: Sun Dec 02, 2007 5:06 pm Post subject: Ultrastar engin recommendation |
Hi Dan Thanks
Im thinking I don't want to mess with the structure,so would like to use the cuyuna . How long have you been flyen it
--- On Sun 12/02, Dan Walter < worrybear(at)verizon.net > wrote:
[quote]From: Dan Walter [mailto: worrybear(at)verizon.net]
Date: Sun, 02 Dec 2007 09:40:19 -0500
Subject: Re: Ultrastar engin recommendation
Dan Walter
Palmyra, Pa.
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Mon Dec 03, 2007 8:29 am Post subject: Re: Ultrastar engin recommendation |
Mine also has the UL-202 that I fixed after a seizure (Engine not me ) but the early models also had a Cuyuna 430, which I also have as a spare.
Parts are still easy to get for the Cuyuna 202 and fixing one is pretty easy.
You need 30-40 HP and if weight is not limited to 254 lbs I would personally try a light 4 stroke like a 1/2 VW.
The UL-202 weighs about 58lbs, the 430 about 65lbs and a 1/2 VW about 95 lbs and produce 35, ~35 and ~40 HP respectively.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
