Edwardoconnor(at)mac.com Guest
Posted: Sat Feb 25, 2006 7:52 am Post subject: Fuel Tank Bulletin |
I installed Van's Capacitance fuel quanity system and elected not to
cut the access hole in the root ribs since they were not necessary. Now
it looks like I will have to remove the tank to comply with this and I
am just days from first flight. Bummer. May wait a while to comply. The
idea of removing the tanks and cracking that brand new paint job and
reprosealing after all of this and making a tank access plate and
sealing it up just doesn't sound like any fun. I like the bore scope
idea. I know they make one that could be used considering where I have
seen them placed in the human body. It could fit through the tank drain
hole and inspect the AN fittings.
SSoule(at)pfclaw.com Guest
Posted: Sat Feb 25, 2006 8:22 am Post subject: Fuel tank bulletin |
Hello,
This bulletin requires removal of the fuel tanks. Does anyone have advice
about how to remove wing tanks after the plane has been painted? I can see
the need to scribe the skin overlap area to break cleanly the paint line
between the wing skin and the tank skin, but can't we expect that paint has
wicked into and under the skin, thus effectively gluing the tank to the
wing?
I would appreciate any advice for those who have removed their fuel tanks. I
had mine off before the plane was painted and it wasn't too hard, but I
don't want to make a mess of my nice new paint job.
Steve Soule
Highgate, Vermont
N227RV, RV-6A
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version 5.5.2657.73">
Fuel tank bulletin
Hello,
This bulletin requires removal of the fuel tanks. Does anyone have advice about how to remove wing tanks after the plane has been painted? I can see the need to scribe the skin overlap area to break cleanly the paint line between the wing skin and the tank skin, but can't we expect that paint has wicked into and under the skin, thus effectively gluing the tank to the wing?
I would appreciate any advice for those who have removed their fuel tanks. I had mine off before the plane was painted and it wasn't too hard, but I don't want to make a mess of my nice new paint job.
Steve Soule
Highgate, Vermont
N227RV, RV-6A
Posted: Sat Feb 25, 2006 8:38 am Post subject: Fuel tank bulletin |
jhstarn(at)verizon.net Guest
Posted: Sat Feb 25, 2006 8:42 am Post subject: Fuel Tank Bulletin |
At last the sound of common sense & reason in a sea of mass hysteria. Now
this is something that can be done for YOUR own protection. We'll do both
BUT a look see via the drain hole will work until we get ALL the stuff on
hand, in the hanger to do the complete job Van has requested. Pro Seal,
gasket material, new screws anyone ??? 8*) KABONG HRII N561FS
''I like the bore scope idea. I know they make one that could be used
considering where I have seen them placed in the human body. It could fit
through the tank drain hole and inspect the AN fittings."
rv8ch
Posted: Sat Feb 25, 2006 10:27 am Post subject: Fuel tank bulletin |
| Quote: | According to the service bulletin, you don't need to remove the tanks. Of
course, trying to remove those screws, etc. in the 3" (?) gap between the
fuselage and wing tanks ain't gonna be fun or easy.
Do yourself a favor, and get some torx screws from microfasteners.
You only need an inch to get them off. Of course, allen screws
would work just as well. I've got pics here, if you are
interested in what they look like.
http://www.rv8.ch/article.php?story=2004082222240152
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
shempdowling2(at)earthlin Guest
Posted: Sat Feb 25, 2006 10:51 am Post subject: Fuel Tank Bulletin |
2 boroscopes
http://da.harborfreight.com/cpisearch/web/search.do
Shemp/Jeff Dowling
RV-6A, N915JD
265 hours
Chicago/Louisville
dbris200(at)sbcglobal.net Guest
Posted: Sat Feb 25, 2006 11:48 am Post subject: Fuel tank bulletin |
Good point, but when I built my 6 I painted the tanks separately and
used stainless screws it install them. Removal is a 1/2 hour job (after
they're empty). And, in my opinion they look just as good or better than
painted screws, and are much more serviceable.
BTW, I'd like to watch someone try to remove the inverted pickup with
the tanks installed! I think Van's is out to lunch on that one.
Dave -6 So Cal
Stephen J. Soule wrote:
Hello,
wing?
Steve Soule
Highgate, Vermont
N227RV, RV-6A
Fuel tank bulletin
Hello,
Steve Soule
Highgate, Vermont
N227RV, RV-6A
Posted: Sat Feb 25, 2006 12:29 pm Post subject: Fuel tank bulletin |
Dave,
I used unpainted screws, so that's not the problem. I was thinking that even
when the screws are out, the tank will still be stuck to the wing with
paint. I wondered if anybody had practical advice about how to pry the tank
apart from the wing.
Steve
tandk_howell(at)comcast.n Guest
Posted: Sat Feb 25, 2006 12:30 pm Post subject: Fuel tank bulletin |
I haven't built my tanks yet, so shouldn't have a problem complying with
this SB. But I do have a question. Step 16 of the SB says to check the
AN818-4D vent line coupling for proper torque before reinstalling the T-408
cover plate. That's no guarantee that it's not going to fall off in the
future. I plan on buttering the vent line coupling nut with Proseal after it
has been torqued. The question is, how good would Proseal be for "locking"
the coupling nut, or should some other kind of fuel-resistant Loctite be
used?
Ken Howell
Glenwood Maryland
RV-7 Wings
rv8ch
Posted: Sat Feb 25, 2006 12:57 pm Post subject: Fuel tank bulletin |
| Quote: | ... Step 16 of the SB says to check the
used?
It seems like proseal would keep a nut on, but I'm not sure I
see the need to do this to the fuel tank vent line. In the
very unlikely even that it comes off, it might be annoying,
but it should not ruin your whole day.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
ptrotter
Joined: 10 Jan 2006 Posts: 28 Location: Westchester County, NY
Posted: Sat Feb 25, 2006 1:24 pm Post subject: Fuel tank bulletin |
I was speaking to Scott at Van's yesterday about something else and I
mentioned the SB. He said he watched one of the guys there remove the flop
tube from a tank on the wing and it wasn't difficult. We'll see what others
find. Fortunately my wings are not installed yet.
Paul
_________________ Paul Trotter
RV-8 82080 Fuselage Kit
N801PT (reserved) |
Ed Anderson
Posted: Sat Feb 25, 2006 1:52 pm Post subject: Fuel tank bulletin |
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
Posted: Sat Feb 25, 2006 2:53 pm Post subject: Fuel tank bulletin |
It has been a long time since I built my tanks, but my memory (and the
drawing in the Service Bulletin) show the pick-up being attached to the
access plate, so you won't need to safety anything inside the tank.
Posted: Sat Feb 25, 2006 3:06 pm Post subject: Fuel tank bulletin |
Maybe that was on a -7. On my -6 there isn't enough room to get your
hand between the wing and fuselage, let alone enough to reach inside the
tank to break the proseal loose on the flop tube. Anyway, on my
airplane, it's easy to remove the tanks, draining them is the hard part
- wait - I could just FLY the fuel out!
Dave
Paul Trotter wrote:
Ed Anderson
Posted: Sat Feb 25, 2006 3:10 pm Post subject: Fuel tank bulletin |
Matthews, NC
Posted: Sat Feb 25, 2006 3:27 pm Post subject: Fuel tank bulletin |
Steve,
Just use a razor blade along the edge of the tank. The paint will not
have run under the edge enough to cause it to stick unless the painter
REALLY loaded it up with wet paint.
Dave
Dave,
Steve
ptrotter
Posted: Sat Feb 25, 2006 3:40 pm Post subject: Fuel tank bulletin |
You don't take the flare nut off. You remove the entire assembly including
the bulkhead fitting by removing the nut on the outside of the tank and
breaking the proseal loose. Then you fix the assembly outside the tank and
reinstall it with new proseal. The only issue I can see is how hard it is
to break lose the proseal since there is limited movement in the bulkhead
fitting if you put an anti-rotation bracket in.
Paul
N801PT (reserved) |
Posted: Sat Feb 25, 2006 3:58 pm Post subject: Fuel tank bulletin |
Kyle Boatright wrote:
There may be some confusion about the 'reach' required because of the
difference between standard & flop tube pickups.
I don't know for sure about the -6, but the -7 has the flop tube
installed on a fitting through the leading edge reinforcement angle.
That's a pretty long reach & would mean getting your elbow between the
fuse & wing, turning into the tank, then turning again toward the
leading edge & reaching forward to the leading edge to do your
tightening & safety wiring.
lhelming(at)sigecom.net Guest
Posted: Sun Feb 26, 2006 4:46 am Post subject: Fuel tank bulletin |
This a good reason to paint your fuel tanks separately when detached from
the wing. Then mount on the wing after it is painted and use either painted
or unpainted screws.
Indiana Larry, RV7 SunSeeker 90+ hours flying
"Please use the information and opinions I express with responsibility, and
at your own risk."
dlpier(at)lamar.colostate Guest
Posted: Sun Feb 26, 2006 7:43 pm Post subject: Fuel tank bulletin |
There have been at least 2 accidents due to the loose flare nut fitting. I
totaled my RV-6 31/2 years ago due to this problem. There was 6.5 gallons
left in the tank, not 3.5. I informed Vans about it and never received a
reply. There was a short note in the RVator 2-3 years ago addressing this
problem. It was done by a contributor, not Van's staff. I prosealed the nuts
on my current RV-9.
Don Piermattei
RV-9 90411
Donald L. Piermattei DVM, PhD
5000 E County Rd 92
Carr, CO 80612
970/568-9047
Fax 970/568-7279
