jonboede(at)hotmail.com Guest
Posted: Thu Nov 29, 2007 11:27 am Post subject: Freon & on & on & on |
So, before I do something stoopid (again)...
I got a nice Freon leak detector on eBay for $50... detects all things halogenated at leak rates as low as 3gm/year.
And practically everything in the museum has some kind of pneumatic system on it -- from the CJ up through the MI-24 to the MiG-23. So getting "good" at finding leaks would have plenty of application.
I am under the delusion that putting a shot of Freon into said system and sniffing with the leak detector is a good way to find all the leaks.
But, being the non-chemist that I am, I thought I'd ask around first before I do something ignorant.
I read through the list of refrigerants and it looks like R-23 (trifluoromethane / Fluoroform) or R-503 (R-13/R-23 mix) has a sufficiently high vapor pressure (about 4.4 MPa) at room temperature that I can pump some of the Freon into an empty nitrogen pony bottle, bump it up with nitrogen and then run the whole system up to a pretty good pressure without the Freon turning into a liquid.
Anybody have any objections to all this? Is running CFCs or HFCs into aluminum tubing a bad idea?
In some systems (e.g. L-39) the nitrogen system also supplies head pressure to the hydraulic system. Is mixing CFCs/HFCs and MIL-5606 a bad idea?
Suggestions?
Jon
cliff(at)gesoco.com Guest
Posted: Thu Nov 29, 2007 11:52 am Post subject: Freon & on & on & on |
Most leak detectors do not react with the freon (a very inert gas), but
actually detect the ultrasonic sound the leak makes.
Cheers,
Cliff
Jon Boede wrote:
| Quote: | So, before I do something stoopid (again)...
bad idea?
Suggestions?
Jon
Clifford Coy
Director of Maintenance
Border Air Ltd
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: callto:Cliff.Coy <callto:cliff.coy>
brian-1927(at)lloyd.com Guest
Posted: Thu Nov 29, 2007 4:54 pm Post subject: Freon & on & on & on |
On Nov 29, 2007, at 11:25 AM, Jon Boede wrote:
all the leaks.
It should work.
| Quote: | But, being the non-chemist that I am, I thought I'd ask around
into a liquid.
Ha, I hadn't thought of the CFC going to liquid at operating
pressure. Good point.
| Quote: | Anybody have any objections to all this? Is running CFCs or HFCs
It won't hurt a thing. What do you think they do in the condenser
coil of your A/C?
| Quote: | In some systems (e.g. L-39) the nitrogen system also supplies head
a bad idea?
CFCs are inert. They won't react with the hydraulic fluid. Air with
its 20% O2 is a lot more reactive, especially under pressure, which
is why they use N2 instead of air.
Brian Lloyd 3191 Western Drive
brianl AT lloyd DOT com Cameron Park, CA 95682
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
On Nov 29, 2007, at 11:52 AM, Cliff Coy wrote:
but actually detect the ultrasonic sound the leak makes.
There are both types, i.e. chemical and sonic.
Posted: Thu Nov 29, 2007 5:04 pm Post subject: Freon & on & on & on |
Brian! Sorry... I just could not resist!
You said: "There are both types, i.e. chemical and sonic".
Didn't you mean: "There are both types, i.e. chemical and ULTRAsonic".
I just know I'm going to love this answer!
Your bud,
Mark
Posted: Thu Nov 29, 2007 5:23 pm Post subject: Freon & on & on & on |
On Nov 29, 2007, at 5:04 PM, Bitterlich, Mark G CIV Det Cherry Point,
MALS-14 64E wrote:
Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
ULTRAsonic".
Sonic. Vibrations in the air. Frequency is not the issue. If you want
to use the word "ultrasonic" to mean that the vibrations are outside
the range of normal human hearing, that's fine with me. Regardless,
one works by detecting the molecules of some CFC and the other works
by detecting the vibrations in the air caused by the escaping high-
pressure gas, i.e. by detecting a sound.
Posted: Thu Nov 29, 2007 6:07 pm Post subject: Freon & on & on & on |
On Nov 29, 2007, at 8:294 PM, Brian Lloyd <brian-1927(at)lloyd.com> wrote:
| Quote: | Sonic. Vibrations in the air. Frequency is not the issue. If you want
Brian, I was just messing with you honestly. But..... Being somewhat
particular in the vein of accuracy as we both tend to be at times... In
fact to the point of sometimes verging on anal, at least in my case
(yes, I admit it!)
First of all, I agree that your description is in fact perfectly
accurate with a minor exception, that being:
"Sonic: Vibrations in the air. Frequency is not the issue."
Quoting Merriam Webster:
Sonic: having a frequency within the audibility range of the human ear
-used of waves and vibrations
Ultrasonic: having a frequency above the human ear's audibility limit
of about 20,000 hertz -used of waves and vibrations
Gaseous leak detectors that do not rely on chemical detection but rather
waves of sound coming from compressed air leaks most typically operate
in the Ultrasonic range since the sound said leaks produce are maximum
in this range, and further detection above sonic makes them easier to
isolate.
So Sir, small point as it remains... Frequency is the issue. Because
the sound detector used is not sonic, but in fact ultrasonic. If you
take the detector from one of these devices it in fact typically has a
headset and a microphone. If you speak into the mike, you will not hear
a darn thing coming out of your headset per se. Compress your mouth and
blow air out and the story changes! I've used them all of my adult life.
I agree that your description is in fact perfectly accurate
Hey... You would have nailed me if the roles were reversed! And
yes.. It is a ridiculous point.
Mark Bitterlich
Posted: Thu Nov 29, 2007 9:10 pm Post subject: Freon & on & on & on |
And there are the ones that were left aboard the Concorde. Those were SUPERsonic leak detectors.
[quote] Subject: RE: Freon & on & on & on
Date: Thu, 29 Nov 2007 21:07:04 -0500
To: yak-list(at)matronics.com
--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
(yes, I admit it!)
isolate.
Mark Bitterlich
