matthew(at)n523rv.com Guest
sportav8r(at)aol.com Guest
Posted: Fri Jan 06, 2006 8:03 am Post subject: Canopy Care and Cleaning |
mick-matronics(at)rv8.ch Guest
Not sure where I read it, but it seemed authoritative at the
time. They recommended rinsing the canopy off with water
from a garden hose, just to get the big stuff, then using
plexus and microfiber cloths.
That's my plan until I find a better method. I've still got
the original protective plastic on my canopy.
I use this system with our club's pipers, and it works pretty
well. It seems like the more I use plexus and the microfiber
cloths, the better the windscreen and windows look.
Mickey
dan(at)rvproject.com Guest
| Quote: | What cloth types are builders using to wipe the canopy with that doesn't
leave
scratches? Shami cloth? California Car Duster? Diapers?
Bare hands and water!
That's the first thing I use if my canopy is really dusty or has caked on
bugs that I accidentally left sitting for several days. I spray or drizzle
water on the canopy, then I wipe it with my clean hand. Remove any rings
from your fingers, obviously. The dust and grit comes right off on your
hand and doesn't scratch. Frequently while doing this I clean my wiping
hand so I'm not pushing clumps of crap around.
After this process, I let what's left of the water evaporate, and then I
clean the canopy normally with a micro-fiber towel and Plexus. I don't
think the cleaner is all that critical as long as you know it won't harm the
plexi, and as long as you use something like a micro-fiber or flannel cloth
that won't scratch.
) ( Dan
RV-7 N714D
http://www.rvproject.com
SSoule(at)pfclaw.com Guest
Posted: Fri Jan 06, 2006 8:06 am Post subject: Canopy Care and Cleaning |
Matthew,
I use microfiber cloth and Plexus. Wash the cloth after a few canopy
cleanings.
Stephen Soule
RV-6A N227RV
eanderson(at)carolina.rr. Guest
Posted: Fri Jan 06, 2006 8:52 am Post subject: Canopy Care and Cleaning |
There is a soft silicon? blade (sometimes called a California Wiper) that is
great for canopies. Wet the canopy then the blade floats on a thin layer of
water while pushing the rest in front of it picking up dust, debris, etc and
floats off the canopy. Just clean the blade with a cloth (I use my fingers)
before each swipe and I have found it to be very quick and safe. Can be
found in most auto stores.
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
don.wentz(at)intel.com Guest
Posted: Fri Jan 06, 2006 4:10 pm Post subject: Canopy Care and Cleaning |
I use old T shirts and Pledge, 11 years on a -6 tip up, works great.
Dw
lhelming(at)sigecom.net Guest
Posted: Fri Jan 06, 2006 7:46 pm Post subject: Canopy Care and Cleaning |
Here is what I am doing. When it is dusty, or has dirt or bugs on it I
sprinkle with a garden pressure sprayer and wet it down with just plain
water. Then use a clean old tee shirt and drag it across the glass to
remove water along with the dust and dirt particles WITHOUT applying any
pressure to the glass that might scratch it. If you need to do this a
second time, do so by rewetting and dragging. You want to get the dirt/dust
off primarily. Then when the grit if off, spray on the plexus or whatever
and work it in well using a clean cotton flannel and let it film up . After
dry, use another clean cotton flannel and remove the film. Basically, I
want to keep from rubbing any grit into the glass that will create tiny
micro scratches that cause the haze look over time. A trusted friend uses
Nu Finish car polish instead of Plexus. His results look fine also.
Indiana Larry, RV7 Tip Up SunSeeker 78 hours
"Please use the information and opinions I express with responsibility, and
at your own risk."
leave
What products are builders using to do the actual cleaning? Some old
posts
indicated Pledge, Maguires #10, Windex w/ Vinegar.
What products should one absolutely avoid??
I've suggested to Ken at Van's to write up and article, so any information
I get
from the group I will forward to Ken for reference.
Matthew
