Singleton Tail Wheel Mod
fklein(at)orcasonline.com
PostPosted: Tue Nov 27, 2007 4:50 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Graham et al,
As I contemplate installation of this mod, I recall having the good
fortune of meeting William Mills at Sun 'n Fun. William gave me a list
of 4 things to do to ensure trouble free XS monowheel operations, one
of which was a recommendation to change the geometry of the Steering
Horn included with Graham's mod. I'm looking for counsel from anyone w/
direct monowheel experience using the Singleton tail wheel mod as well
as from Graham, the designer.
The Singleton steering horn has a distance of 4" between the holes in
the "horns". William recommended to me that I fabricate a new steering
horn which spreads the horns a bit so that the distance between the
horn-holes becomes 6".
William used the term, "spread", because he was clear that the distance
between the centerlines of the horn-holes and the two mounting holes
must remain the same as that of the Singleton steering horn.
I'm not clear as to just what the implications of such a change would
be; however, William was convinced that such a change would enhance
directional control during t/o's and land'gs. So I'm asking whether or
not this is a subject with which others have grappled, and whether or
not a definitive conclusion has been reached. (?)
All comments would be much appreciated,
Fred
A194
believed to be clean.
DanBish
PostPosted: Tue Nov 27, 2007 8:46 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Hi Fred,
Can't say I have experience with the operation of the mod yet, but I've posted some photos of it in the gallery if that'll help.
http://www.europaowners.org/modules.php?set_albumName=album169&op=modload&name=gallery&file=index&include=view_album.php
Dan
Visit - www.EuropaOwners.org
PostPosted: Tue Nov 27, 2007 9:50 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Outstanding documentation and workmanship Dan...thanks, Fred
davedeford(at)comcast.net
PostPosted: Tue Nov 27, 2007 10:57 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Fred,
We installed Graham's tailwheel mod on N135TD and found it too touchy for
our liking. Rather than extending the steering horn on the tailwheel, we
moved the attachment points for the tailwheel cables closer to the pivot
point on the control arm at the rear of the fuselage. Our steering
sensitivity is now similar to the factory setup, about the same as what you
would get with William's recommendation. We have had it this way for about
6 years and are happy with the performance.
Dave
[quote] --
josok-e(at)ukolo.fi
PostPosted: Wed Nov 28, 2007 12:22 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Have the mod, and some experience, about 50 hours and +120 landings, all on concrete/asphalt. No problem whatsoever, i like it. Choose the mod, because i noticed that i was literally standing on the pedals, during an exiting landing with the club's super cub. Would not like to apply that load to the standard lower hinge.
Before the first flight Graham supplied me with a wider drive plate, and there is easily enough authority with it.
Jos Okhuijsen
davidjoyce(at)doctors.org
PostPosted: Wed Nov 28, 2007 3:01 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Fred,
I fitted the standard Singleton mod from new, and now have 500+ hrs with it.
I like both the appearance and the performance, and have never felt the need
to contemplate altering it
Regards, David Joyce G-XSDJ
rlborger(at)mac.com
PostPosted: Wed Nov 28, 2007 4:40 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Fred,
Not having flown N914XL yet, (Maybe sometime within the next 6 - 8 weeks?) I can't speak from direct experience. But it has been reported that, using the provided geometry from the provided parts, the steering can be a bit overly sensitive. I have one of the wider (6" between drive holes vs. 4") tail wheel control horns which I intend to install prior to putting the aircraft on the trailer. The individual who provided the wider control horn says it does wonders for the landing handling by making the steering less sensitive.
One of Tommy's Little Toots is also overly sensitive on landing. We are preparing to move the tailwheel drive cable attachment points outboard and inch or so to see if it helps there as well.
Dave DeFord's suggestion would also work if you still have decent access to the interior mod assembly. I don't, so I'm going with the wider tailwheel horn.
Hope this helps,
Bob Borger
On Tuesday, November 27, 2007, at 07:03PM, "Fred Klein" <fklein(at)orcasonline.com> wrote:
Graham et al,
Fred
A194
PostPosted: Wed Nov 28, 2007 7:17 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Jos,
When you say "wider drive plate", do you know the distance between the
centers of the holes on the horns?
Thanks...and many happy landings!
Fred
nwcmc(at)tiscali.co.uk
PostPosted: Wed Nov 28, 2007 7:27 am    Post subject: Singleton Tail Wheel Mod Reply with quote
for our liking.<
I found the mod to be very worthwhile. Its sensitivity is dependant on
the tension of the tailwheel springs so it is important to set those to
your liking.
The only factory mod from the Classic the the XS which I don't like is
the rudder horn. The original pushrod is much neater and stronger with
no extra drag. I know of at least one XS builder who retrofitted the
pushrod. Putting the tailwheel springs inside the fuselage likewise
improves things.
Nigel Charles
rparigor(at)suffolk.lib.n
PostPosted: Wed Nov 28, 2007 7:55 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Hi Nigel
"Its sensitivity is dependent on the tension of the tailwheel springs so
it is important to set those to your liking."
My impression is if tailwheel drive springs are loose, it would be like
driving a car with a worn rack and pinion?? You can do it, it will not be
as sensitive as one with no play, but then again you will not be able to
maintain precise directional control due to hysteresis.
Please explain why loosing the springs would be more desirable to having
precise control over tailwheel by rudder inputs and if too touchy then
tame down by shorter drive moment arm or longer driven moment arm?
Ron Parigoris
PostPosted: Wed Nov 28, 2007 8:47 am    Post subject: Singleton Tail Wheel Mod Reply with quote
be as sensitive as one with no play, but then again you will not be able
to maintain precise directional control due to hysteresis.
tame down by shorter drive moment arm or longer driven moment arm?<
I would think Graham Singleton is the best person to explain. However I
will give you my thoughts and you can decide whether they have any
merit.
If the springs are too tight the tailwheel will be too powerful at
higher speeds when the rudder should be controlling. If you reduce the
gearing by using longer arms you will increase the already large turning
circle when at taxying speeds. Whatever arm length you use it is
important to line up the sleaving tubes reasonably accurately before
fixing them into the fuselage. There has been one case of excessive
cable wear due to the cables rubbing against the tubes at extremes of
travel. Obviously if they are too loose the steering becomes
ineffective. I seem to remember Graham giving some guidance as to spring
tension and it worked OK for me. If you have the springs too tight you
might as well do without them altogether. When they are at the right
setting it is possible to tighten the turn on taxi by applying a burst
of power whilst applying full rudder. This causes the outboard spring to
extend tightening the turn. This has to be done carefully to avoid a
full ground loop but works well when needing to do a 180 degree turn at
the end of a narrow runway.
Others with more hours on their Europas than I have agree that the setup
seems to work so I would only change things if Graham advised it or
significant handling or engineering problems developed.
Nigel Charles
josok-e(at)ukolo.fi
PostPosted: Wed Nov 28, 2007 1:39 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Fred
I will have to go to the airport and measure. I heard that the change has been made after Andy refused to test fly an original Singleton mod, because of lack of authority. I am sure Graham can help with the dimensions of the narrow and wider drive plates? Graham?
Jos Okhuijsen
Troy Maynor
PostPosted: Wed Nov 28, 2007 6:58 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
To Fred ,
I am confuse about the labels you used in the follow quote of yours.
The "horn holes" are on the Singleton steering horn, right? Which "mounting
holes"? I am being dense I know. But forgive me please.
To Dave,
You said:
<<Rather than extending the steering horn on the tailwheel, we
would get with William's recommendation.>>
What was the advantage of this over doing it outside where you can have
better access? Did you just drill a couple holes and that was it? I too have
Graham's mod and had forgotten this had been suggested a few years or months
ago.
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Paint,(some) interior,engine install, (some) wiring.
Weaverville, NC USA
winmail.dat
 Filename:  winmail.dat
 Filesize:  2.29 KB
 Downloaded:  398 Time(s)
PostPosted: Wed Nov 28, 2007 8:39 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
"mounting
Troy,
Sorry for having been confusing to you; let me try to clarify what I
meant.
The Singleton steering horn has a total of 4 holes; one in each horn
for the cables, and 2 which are used to mount the steering horn on the
tail wheel mount.
If you draw a centerline between the two cable attachment holes which
are 4" apart and a second centerline between the two mounting holes,
there will be a measurable distance between the 2 centerlines.
What William was saying was that, whereas he was recommending that the
4" distance between the 2 cable attachment holes be increased to 6",
that measurable distance between the 2 centerlines should remain the
same. Thus when William said "spread" the horns, he was suggesting
that the angle between the horrn on the right and the horn on the left
would increase...rather than achieving the 6" distance by merely
elongating the respective horns.
I hope this clarified my previous post.
Fred
PostPosted: Wed Nov 28, 2007 11:20 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Troy,
The point of drilling new holes in the drive arm, rather than
extending the horn on the tailwheel, was to minimize the spread of the
cables where they exit the rear of the fuselage. The change in angle is
already pretty large (greater than the FAA's recommended maximum for a
fairlead) with Graham's original horn, and it looked as if it would be worse
with a larger spread on the horn. (The appearance is somewhat nicer as
well.) If you could find the right spots to drill holes in the rear
fuselage to route the tailwheel drive cables straight from the drive arm,
this would not be a factor. After 6 years and 500 hours, the fairleads have
not worn through.
We drilled the new holes in the drive arm at about 2/3 of the
spacing of the original holes. This left plenty of clearance on the
starboard side for a shackle to connect the tailwheel cable, but a port-side
shackle would have interfered with the rudder pushrod (which was not
changed). Instead, we fastened a short strip of metal to the hole with a
clevis pin, and then secured the port-side tailwheel cable to the aft end of
the strip, bent downward (in the direction the cable goes) to clear the
rudder pushrod.
This change was made after the airplane was flying, by removing the
drive arm through the inspection hole, adding the holes and metal extension
strip, and reinstalling the arm. We had made quite a few flights off of
pavement with the original setup, keeping the springs lightly compressed per
Graham's recommendation. We felt that the springs were delaying the steering
response (which was quite sensitive as well), making it harder to get just
the right amount of rudder input without overshoot.
Dave DeFord
N135TD
you
have Graham's mod and had forgotten this had been suggested a few years or
months ago.
Troy Maynor
johnwigney(at)alltel.net
PostPosted: Thu Nov 29, 2007 6:53 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Hi Fred,
I endorse David's comments. I also fitted the Singleton mod from new
and I have 570 + hrs. It has served me very well and I have never seen
the need to alter the standard setup.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
ORIGINAL MESSAGE
Subject: Re: Singleton Tail Wheel Mod
Fred,
stranfaer(at)btinternet.c
PostPosted: Thu Nov 29, 2007 8:18 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Just thought I would let you all know the reason that Graham has not made
comment on this thread, he has been away all week, I do know he will be back
sometime during the day on friday.
It would be reasonable to expect a comment fairly soon after his return Wink
rgds
David Joyce (the other one)
raimo.toivio(at)rwm.fi
PostPosted: Thu Nov 29, 2007 11:28 am    Post subject: Singleton Tail Wheel Mod Reply with quote
Fred and all,
would you like to tell us also
the rest 3 things to ensure
XS MW trouble free operations?
I understand the benefits of the
Graham´s tailwheel mod but
personally I have been totally
happy w factory original tailwheel
assembly. And Jos is right - it is
wise to use rudder pedals only gently
to avoid overstress the mechanism.
For example when doing steep turns
I push the pedal only little and let it go
to the stop "by itself" w/o any significant
force.
Few days ago I performed some icetests
like landing and groundhandling. There
was no problem and so I was tempted to
make some fun and aplied full rudder
and some power on the very slippery apron area:
voilá my Europa was making fast & nice
pirouettes in it´s place and it looked like
http://upload.wikimedia.org/wikipedia/commons/1/1c/Korpi_kiira.jpg
(this was a gift for all Europa gentlemen).
Raimo
OH-XRT Europa XS Mono #417, 47 hrs & 110 landings
37500 Lempaala
Finland
tel + 358 3 3753 777
fax + 358 3 3753 100
gsm + 358 40 590 1450
www.rwm.fi
PostPosted: Thu Nov 29, 2007 4:36 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Raimo,
Happy to do so; from my notes of a conversation with William Mills at
Sun 'n Fun, 2007; also present was Terry Greaves; William made the
following recommendations:
1. Add weight in tail to get the CG at the aft limit,
2. Modify Graham Singleton's tail wheel mod (as per previous post),
3. Outrigger Rod Lengths: delay drilling the bolt holes into the wheel
brackets until the very end of your build; ensure that the O/R rods are
long enough so both wheels touch on level ground.
4. Make initial flights on grass.
Fred
PS: Thanks everyone for the thoughtful discussion of the tail wheel
issue. Too many years ago when I was considering building a Q-200, the
mantra was "Don't build in isolation!" and I recall making two short
trips to visit another builder to learn the special joys of hot-wiring
foam; such visits, a monthly newsletter, and Oshkosh forums were the
extent of the ability to share information. How different things are
today, w/ nearly instantaneous global feedback on any question which
arises from a variety of informed sources thanks to the internet, the
Europa Club, and folks like SteveD and Matt Draille.
grahamsingleton(at)btinte
PostPosted: Thu Nov 29, 2007 5:03 pm    Post subject: Singleton Tail Wheel Mod Reply with quote
Ron & All
sorry I wasn't here earlier. Been away doing a Mod 73 and a PFA (LAA!)
seminar on how to inspect.
I designed the original mod to have the same geometry as the old Classic
steering (to give a useful turning circle on the ground.) Completing a
180 deg turn on the runway at Wombleton e.g.! but set the spring tension
to allow overiding the tailwheel springs with rudder deflection for
crosswind control. IOW the wheel would be in trail even with full rudder
deflection. Many of us have learnt to handle most conditions like this
but it does require instant response to yaw on the ground.
Experience has shown that having better tailwheel authority on the
ground is an advantage so a few people have tried 5 inches between the
cable attach points and found it works better (Jos) and one or two 6
inches, ( Brian Fogg) I think 6" is good but does increase the turning
circle a bit so you couldn't 180 at Wombleton. You'd need to persuade
the owner to widen the runway!
A couple of people (Tony Higgins) have used 6" and moved the attach
points rearwards like the factory configuration. (instead of the Vee I
use) The factory config. gives more authority at the extremes of the
range but has the disadvantage that the springs tend to pull the rudder
to one side or the other. Mine gives even spring tension across the
range of movement.
Graham
rparigor(at)suffolk.lib.ny.us wrote:
Hi Nigel
Ron Parigoris
Graham Singleton
Tel: +441629820187
Mob: +447739582005
