Headliner rework
jwt(at)roadmapscoaching.c
PostPosted: Fri Feb 24, 2006 6:37 pm    Post subject: Headliner rework Reply with quote
Tim,
What final fabric or material did you use for your headliner? Did you worry
about fire retardant material? How did you finish the edges around the
windows, etc. I am looking for materials now since I am about to attach my
canopy.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
QB Canopy and window trimming
LarryRosen
PostPosted: Fri Feb 24, 2006 7:12 pm    Post subject: Headliner rework Reply with quote
Not Tim but....
I am using a light gray fabric (Marathon Collection Gray Mix) from Abby
at Flightline Interiors <http://my.execpc.com/~erdmannb/index.htm>. The
material is flame resistant. The specs say:
Flame Resistance
ASTM E-84 Class 1
CAL 117-E Passes
MVSS 302 Passes
UFAC Class 1
Motor Vehicle Safety Standards (MVSS) Flamability Test #302
Every yard of Marathon production receives the superior flame retardant
(FR) finish so it passes the MVSS 302 FR test which makes it suitable
for automotive aftermarket and transportation applications.
For the window edge treatment Abby's instructions say:
"The edge around the windows will need to be trimmed with a utility
knife or razor blades. To finish the edges you can use a hot soldering
iron to seal and smooth it. This will also prevent any fraying. We
recommend sealing the edge above the baggage door too."
Larry Rosen
<http://lrosen.nerv10.com>
John Testement wrote:
Tim,
canopy.
John Testement
40321
Richmond, VA
Larry Rosen
#40356
N205EN (reserved)
<http>
Tim(at)MyRV10.com
PostPosted: Fri Feb 24, 2006 8:54 pm    Post subject: Headliner rework Reply with quote
All of those fabrics she sells should be at least flame resistant
to some point. Probably none of them are aviation certified,
but you can make your own judements on what's acceptable in
that regard. Sometimes it's just an on-paper certification
difference, sometimes maybe it's not.
But, just like Larry said, I soldered the edges with a fine-tip
iron.
Larry Rosen wrote:
Not Tim but....
Flame Resistance
ASTM E-84 Class 1
CAL 117-E Passes
MVSS 302 Passes
UFAC Class 1
Larry Rosen
> <jwt(at)roadmapscoaching.com>
> Tim,
> worry
> attach my
> canopy.
> John Testement
> 40321
> Richmond, VA
LarryRosen
PostPosted: Sat Feb 25, 2006 4:24 am    Post subject: Headliner rework Reply with quote
Ahn used a molding around the windshield and windows as you can see on
his web site <http://www.geocities.com/anhvu_rv10/Fuselage3.html>
Ahn, do you have any details?
Larry Rosen
iron.
Larry Rosen wrote:
> Not Tim but....
> Abby at Flightline Interiors
> <http://my.execpc.com/~erdmannb/index.htm>. The material is flame
> Flame Resistance
> ASTM E-84 Class 1
> CAL 117-E Passes
> MVSS 302 Passes
> UFAC Class 1
> retardant (FR) finish so it passes the MVSS 302 FR test which makes
> it suitable for automotive aftermarket and transportation applications.
> soldering iron to seal and smooth it. This will also prevent any
> fraying. We recommend sealing the edge above the baggage door too."
> Larry Rosen
>> Tim,
>> you worry
>> attach my
>> canopy.
>> John Testement
>> 40321
>> Richmond, VA
Larry Rosen
#40356
N205EN (reserved)
<http>
PostPosted: Sat Feb 25, 2006 5:43 am    Post subject: Headliner rework Reply with quote
Tim, Which fabric did you choose and why did you prefer fabric over the foam
backed headliner material?
John Testement
40321
Richmond, VA
QB canopy and windshield trim
zackrv8
PostPosted: Sat Feb 25, 2006 6:52 am    Post subject: Re: Headliner rework Reply with quote
[quote="LarryRosen"]Ahn used a molding around the windshield and windows as you can see on
Larry Rosen
I visited Anh's Rv10 a couple of months ago. He has a very nice fabric on his headliner (I forgot the name). I think he also has a closed cell foam behind it. Not sure of the thinkness.
Anh did all of his sewing on the interior. He even did his seats. Beautiful work. He even made a cell phone pocket on the side of his seats! Pretty cool.
Zack
See photos below.
 Filesize:  46.22 KB
 Viewed:  642 Time(s)
 Filesize:  32.23 KB
 Viewed:  642 Time(s)
RV8 #80125
RV10 # 40512
indigoonlatigo(at)msn.com
PostPosted: Sat Feb 25, 2006 7:04 am    Post subject: Headliner rework Reply with quote
[quote]From: Larry Rosen <LarryRosen(at)comcast.net>
Subject: Re: Headliner rework
Date: Sat, 25 Feb 2006 07:20:51 -0500
Ahn used a molding around the windshield and windows as you can see on his
Larry Rosen
>iron.
>Tim Olson - RV-10 N104CD - Flying
>Larry Rosen wrote:
>>Not Tim but....
>>Flame Resistance
>>ASTM E-84 Class 1
>>CAL 117-E Passes
>>MVSS 302 Passes
>>UFAC Class 1
>>(FR) finish so it passes the MVSS 302 FR test which makes it suitable for
>>"The edge around the windows will need to be trimmed with a utility knife
>>or razor blades. To finish the edges you can use a hot soldering iron to
>>seal and smooth it. This will also prevent any fraying. We recommend
>>Larry Rosen
>>>Tim,
>>>worry
>>>my
>>>canopy.
>>>John Testement
>>>40321
>>>Richmond, VA
Larry,
That looks fantastic. Great job. Thanks for sharing.
JG.
Do NOt Archive
Larry Rosen
>iron.
>Larry Rosen wrote:
>>Not Tim but....
>>Flame Resistance
>>ASTM E-84 Class 1
>>CAL 117-E Passes
>>MVSS 302 Passes
>>UFAC Class 1
>>Larry Rosen
>>>Tim,
>>>worry
>>>my
>>>canopy.
>>>John Testement
>>>40321
>>>Richmond, VA
PostPosted: Wed Mar 01, 2006 6:09 am    Post subject: Headliner rework Reply with quote
Ahn,
How did you do your headliner - looks great! How did you trim the edges?
What foam/sound insulation did you use under the fabric, if any?
John Testement
40321
Richmond, VA
