by0ung(at)brigham.net Guest
Posted: Sun Nov 25, 2007 2:24 pm Post subject: fix a small hole |
One other question: What is the best way to fix a small hole( the size of my
pinkie finger) in the horizontal stab?
Grant
| Quote: | >>>>>>>>>>>>>>>>>>>>>
Well it kind of depends on what kind of fabric and paint.
If it is Polly fiber fabric and Polly tone paint it is easy... 2 ways
1:
Trim the ragged parts out of the hole
Lay unshrunk patch material over the hole and trace the outline of the patch
with a #2 pencil, make sure you have the required over lap (1 inch for
holes smaller than 8 inches ) cut the patch with pinking shears.
Mask off the area outside the patch, leave an extra 1/2 inch or so of
working room larger than the patch.
Clean off all the coatings inside the masked area with mek. Everything will
wipe off readily, right down the bare fabric.
Cement the patch to the old fabric with poly-tak, let it dry.
With a 225 deg iron, heat smooth the cemented areas.
With a 350 deg iron, heat shrink the area of the patch over the hole. This
acts as a shrinking panel to retighten the fabric in the area of the repair.
Use a piece of cardboard as a shield to keep the iron off the cemented
areas.
Brush on a coat of poly brush and let it day.
Spray poly spray to fill.
Paint with poly tone. You will find the poly tone is easy to spot spray into
the old paint with a good match unless the old paint is faded.
2:
Band aid option
It is perfectly safe and legal to just scuff sand the old poly tone and
cement directly on top of the old paint without cleaning off all the
coatings. It just looks pretty rough when finished. The poly tak will hold
just fine to the old poly tone.
Instructions from Poly fiber aircraft coatings book.
If you have other paint or fabric,,,, call a distributor and follow their
directions.
Boyd
Posted: Sun Nov 25, 2007 4:53 pm Post subject: Re: fix a small hole |
Back in the old days I used to go through the process of doing it the Stitts or Polyfiber way.
After 1994, unless it is a large hole, bigger than an inch or two, and depending whether it is in a critical to flight area, I stick a "sticker" on the hole. Most of the holes in the fabric of my 1992 mkIII are in the fuselage or tail section area. Probably have 30 lbs of sticker on the old gal.
If I am out on a long flight, 1 or 2 inch black electrical tape works great. So does duct tape.
I patched a 1/2" hole in the top of a wing, made with a screw driver, by making a dollar patch with clear packing tape and pinking shears. Spray painted it with Aerothane. No one knew it was there. The clear packing tape accepted the top coat of two part Aerothane with no problem.
_________________ John Hauck
Titus, Alabama |
Wade Lawicki
Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
Posted: Sun Nov 25, 2007 6:07 pm Post subject: Re: fix a small hole |
Grant,
Go to the hobby shop or find a friend that has some mono-kote for covering model airplanes, get the color close and cut a circle an inch bigger than the hole. start at the outside edges with a iron set at 225, seal the whole diameter then work your way inward. it sticks to the poly without burning it and will last a long time.
Fly Safe,
Wade
d-m-hague(at)comcast.net Guest
Posted: Sun Nov 25, 2007 6:37 pm Post subject: fix a small hole |
At 09:07 PM 11/25/2007, Wade Lawicki wrote:
| Quote: | Go to the hobby shop or find a friend that has some mono-kote
The problem with Monokote is that it's mylar film; if it starts to rip it
keeps on ripping. I haven't tried it as a Stits repair, but Coverite's
prepainted 21st Century Fabric (
http://www.coverite.com/covering/covq0301.html ) or Super Coverite (
http://www.coverite.com/covering/covq1000.html ) iron on the same way but
are dacron fabric. Hmmm, maybe I should get some and try it.
I've used ripstop nylon for small repairs on my Ultrastar. The roll I have
came with the plane, but it looks like "spinnaker tape" sold at marine stores.
-Dana
Ever notice how fast Windows runs? Neither did I.
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Sun Nov 25, 2007 7:54 pm Post subject: fix a small hole |
Why not use stits to patch it the same way???
Give Jim and Dondie a call..
PHONE: 1-877-877-3334
FAX: 1-614-877-3337
EMAIL: info(at)aircrafttechsupport.com
Real nice folks!
Oak Grove Missouri
Mark III Classic (one of the last of Old Kolb) - 0hrs
Suzuki G13B 1.3L - 0hrs
Started with Big Lar still behind...
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
jindoguy(at)gmail.com Guest
Posted: Mon Nov 26, 2007 6:53 am Post subject: fix a small hole |
I pass this along without personally trying it, but the A & P who gave it to me recovered a T-craft last spring that won at this year's AirVenture.
When doing small patches, make a frame of appropriate size to the task at hand and staple a piece of cloth to it. Shrink per manufacturer's recommendations. Cut out patches, pink edges, and attach per manufacturer's recommendations.
Rick
On Nov 25, 2007 9:53 PM, Kolbdriver <kolbdriver(at)mlsharp.com (kolbdriver(at)mlsharp.com)> wrote:
[quote] --> Kolb-List message posted by: "Kolbdriver" <kolbdriver(at)mlsharp.com (kolbdriver(at)mlsharp.com)>
FAX: 1-614-877-3337
EMAIL: info(at)aircrafttechsupport.com (info(at)aircrafttechsupport.com)
Real nice folks!
Oak Grove Missouri
Richard Pike
Posted: Mon Nov 26, 2007 8:41 am Post subject: fix a small hole |
Here's one more way: Take a piece of fabric, and dope it to a glass
window or other flat glass plate with Poly-Brush. Let it dry and then
pop it off, scrape the excess mess off the glass with a razor blade.
Then cut out your patch, pink the edges, etc and dope it in place with
Poly-Brush. Saves the trouble of making a frame, and still gives you a
perfectly flat smooth patch. Plus you can still shrink it later to
tighten it up if necessary. Also works with wide tapes if you should
happen to need one of those instead.
Richard Pike
MKIII N420P (420ldPoops)
Richard Girard wrote:
[quote] I pass this along without personally trying it, but the A & P who gave
AirVenture.
Rick
<mailto:kolbdriver(at)mlsharp.com>> wrote:
<kolbdriver(at)mlsharp.com <mailto:kolbdriver(at)mlsharp.com>>
FAX: 1-614-877-3337
<mailto:info(at)aircrafttechsupport.com>
Real nice folks!
Oak Grove Missouri
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Mon Nov 26, 2007 2:35 pm Post subject: fix a small hole |
Richard, As I said, the pre-shrinking idea came from my neighbor, but using unshrunk fabric means the patch will be understrength compared to the fabric to which it's attached, doesn't it?
Rick
On Nov 26, 2007 10:24 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote] --> Kolb-List message posted by: Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
| Quote: | I pass this along without personally trying it, but the A & P who gave
AirVenture.
Rick
> <mailto:kolbdriver(at)mlsharp.com (kolbdriver(at)mlsharp.com)>> wrote:
[quote] <mailto: info(at)aircrafttechsupport.com (info(at)aircrafttechsupport.com)>
Real nice folks!
Oak Grove Missouri
Richard Pike
Posted: Mon Nov 26, 2007 4:04 pm Post subject: fix a small hole |
Not if you go back and shrink it after it is doped on, which is what you
would normally do. If you preshrink it, and your fabric around the hole
or the patch itself turns out to be a bit slack, then what do you do?
Uh-oh. Attach your pre-doped patch, and then shrink it. So far, it's
worked for me. (And actually, this is one of those things that's hard to
get wrong, almost anything will turn out good, with just a little care
and thought...)
Richard Pike
[quote] Richard, As I said, the pre-shrinking idea came from my neighbor, but
Rick
<mailto:richard(at)bcchapel.org>> wrote:
<richard(at)bcchapel.org <mailto:richard(at)bcchapel.org>>
Richard Pike
who gave
> AirVenture.
the task
> Rick
> <mailto:kolbdriver(at)mlsharp.com <mailto:kolbdriver(at)mlsharp.com>>>
wrote:
> < kolbdriver(at)mlsharp.com <mailto:kolbdriver(at)mlsharp.com>
> FAX: 1-614-877-3337
<mailto:info(at)aircrafttechsupport.com>>
> Real nice folks!
> Mike
> Oak Grove Missouri
> Do not archive
Kingsport, TN 3TN0
Posted: Tue Nov 27, 2007 6:55 am Post subject: fix a small hole |
< Here's one more way: Take a piece of fabric, and dope it to a glass
pop it off, scrape the excess mess off the glass with a razor blade>
How about doing it on a teflon frying pan? I never tried this method
but will keep it in mind. The question about the strength of the patch..??
A little one inch hole won't make a significant change in the overall
strength of a large fabric panel. In the case of fabric on a non stressed
area like the cage it would be totally irrelevant.
BB
Posted: Tue Nov 27, 2007 7:33 am Post subject: fix a small hole |
Just my personal observations but I don't do any of this stuff and my fabric holds great. I have had to replace large portions of the fabric on my cage where I welded on the new VW mount and other patches around the cage where the fabric literally gets pounded by the prop and nothing works loose.
I merely wipe the area I will be sticking new fabric to with MEK. Stick it with Poly Tack iron it tight and cover with the Poly Fiber process. I don't even pinking shear anything. On my ten year old airplane the only fabric that has worked loose is that fabric that was pinked.
I know the certified process of covering fabric airplane says all edges must be pinked but is it better that way? I know if I were to lift a glued anything I start at a corner. Try it yourself. Stick a piece of tape to something and then remove it. Where is easiest to start. Do you start in the middle of a smooth side or at a corner?
Just getting a discussion going.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Tue Nov 27, 2007 8:24 am Post subject: fix a small hole |
To: kolb <kolb-list(at)matronics.com>
Bob and others,
Strength of the patch has to do with fabric overlap. In most cases this is
not a problem. Strength is getting confused with tension of the patch and
the surrounding fabric. This is why Richard's method is good, in that, one
can reestablish uniform fabric tension in the patch and the surrounding
fabric by shrinking the patch.
A teflon coated cookie sheet might be an improvement over the frying pan.
Jack B. Hart FF004
Winchester, IN
Ralph B
Posted: Tue Nov 27, 2007 10:13 am Post subject: Re: fix a small hole |
| Quote: | "Richard Pike"]Here's one more way: Take a piece of fabric, and dope it to a glass
Richard Pike
MKIII N420P (420ldPoops) |
Here's a similar way:
Clean up the hole with an exacto knife. I usually will make it square. Cut a piece of fabric with 1" overlap and round the corners. Use lacquer thinner to clean around the hole. Place the patch over the hole and brush Polybrush outward from the hole. Make it as smooth as possible. Let dry 24 hours. Take a small monokote iron at low heat to shrink it slightly. Using too much heat will make the sides of the patch bow inwards. Use two more more coats and then paint with Polytone. If done right, the patch will be difficult to see.
I have used Polybrush instead of Polytak for large patches too. It makes for a nicer patch.
Ralph B
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Nov 29, 2007 12:57 pm Post subject: Re: fix a small hole |
The good thing about the polyfiber/stits process is that if you use the right components they will all chemically bond to each other right from the poly tak to the poly-tone....thats why you can use the poly brush to stick patches down right to some MEK cleaned poly-tone and it will stick well.
I'd stay away from non-polyfiber products just to avoid having to do things twice when the non compatible product eventually lets go.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
