IFR in a kitfox
Goto page 1, 2  Next
buddcr(at)yahoo.com
PostPosted: Sun Nov 18, 2007 9:23 am    Post subject: IFR in a kitfox Reply with quote
Hi all,
I was wondering how many KFs there are out there that are IFR certified? And out of those how many people actually fly theirs in IMC? I wanted to know how people felt about being in IMC in a kitfox?
Chris Budd
97 Kitfox IV Speedster
VW pwr N53RJ
Get easy, one-click access to your favorites. [quote][b]
pulsair(at)mindspring.com
PostPosted: Sun Nov 18, 2007 10:15 am    Post subject: IFR in a kitfox Reply with quote
Chris,
Mike Harter flew IFR on a regular basis in his Kitfox. He was tragically killed in Arizona a few years ago not related to IFR. Jeff Classic IV
MichaelGibbs(at)cox.net
PostPosted: Sun Nov 18, 2007 8:58 pm    Post subject: IFR in a kitfox Reply with quote
Chris sez:
...I wanted to know how people felt about being in IMC in a kitfox?
I regularly fly my Piper Turbo Arrow IFR. One of the things I
appreciate about that airplane is that I can point it where I want it
to go, divert my attention for a few seconds to mess with the radios,
read an approach plate, or copy a clearance, and when I look at the
instruments again it's pretty much where I left it.
My Model IV Kitfox was an absolutely delightful and easy-to-fly
machine but it did not share that characteristic. I could take my
hand off the stick and it would stay roughly where it had been
pointed, but the air would push it this way and that quite a bit
more. I never even thought about this when VMC but I'm not sure if
it would have made a very stable instrument platform.
There's certainly no reason you couldn't operate IFR in a Kitfox as
others have done, but I'd be thinking "auto-pilot."
Mike G.
N728KF
Phoenix, AZ
n85ae
PostPosted: Mon Nov 19, 2007 1:08 pm    Post subject: Re: IFR in a kitfox Reply with quote
I have a full IFR panel in my Kitfox, with all the appropriate avionics, and
intended to fly mine IFR when I built it. Since I've been flying it for a few
years, now I would never fly it IFR. It is simply not a hands off airplane.
You could fly it iFR but it would be a VERY stressfull adventure as looking
at an approach plate and back at the panel you might find yourself 30-40
degrees off attitude in almost any direction, in as much time as it took to
read this.
I think mine is reasonably stable with the heavy IO-240 up front, but it
is definetly not a good IFR platform in my opinion.
Jeff.
Michel
PostPosted: Mon Nov 19, 2007 2:46 pm    Post subject: IFR in a kitfox Reply with quote
Since you ask, Chris, here is my story. In Norway, with my uncertified
Kitfox, I can't fly IFR. I can't fly at night and I can't even fly
on-top. So, I have no gyro instruments except one of those cheap
solid-state turn coordinator.
Last May, I was to fly from Norway to south Germany where I was to meet
friends. I had prepared that for a long time and was looking forward to
it. The forecast was for a high pressure over most of Europe so I was
optimistic. I had a flight plan for 8 AM.
When I arrived at the airfield, there was fog. I had to delayed my
flight plan. Usually that morning fog lifts up during the morning. I
had given me 12 AM as my last chance to leave, otherwise I wouldn't
reach my first overnight in northern Germany and my rendez-vous with my
friends.
At 11 AM, the fog had lifted and a call to the nearby airport tower
confirmed that the ceiling was now 1,000 ft. That gave me enough
altitude to cross the Oslo fjord and fly toward Sweden where the METAR
was CAVOK.
I took of and levelled at 800 ft, right under the cloud cover. A few
minutes later I was over the water when I realised that I had lost
sight with the ground. Grey over me and grey under me!
That happens often early in the year. The water is still colder than
the air and fog banks drift over the fjord. I had to take a decision. I
could try to climb and fly on-top. I could try to descent and hope to
see the water. Or I could just turn around and forget about my trip.
All that thinking took me some minutes during which I was keeping a
straight course, looking at the turn coordinator and my GPS with moving
map. I knew that it was only maybe ten minutes before I would be again
over land and certainly the fog will be gone. I didn't know how deep
was the cloud cover so I decided not to climb. I stayed at the same
altitude and heading.
After ten minutes I saw a dark shape under me, it was the first island
from the other side of the fjord. It got better with time and arrived
to the Swedish border I saw a timid sun from above, piercing in the fog
that soon dissipated to a CAVOK situation.
Those ten minutes with no visual reference were very tense. I had no
problem to keep the plane on en even keel, the turn coordinator (a
TruTrak) was responding very fast. But as time went, I noticed that I
had problems to keep a straight course. With time, I lost concentration
and was not flying any longer in a straight line. I don't think I could
have done that for much longer. High pulse rate, etc. you easily loose
concentration with time.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
msm_9949(at)yahoo.com
PostPosted: Tue Nov 20, 2007 1:44 pm    Post subject: IFR in a kitfox Reply with quote
Michel,
I had a similar experience returning from Oshkosh this August, flying over lake Michigan. I departed Wisconsin heading East, climbing to 8000 feet with scattered/broken clouds at about 2000 feet. It was a bright and beautiful day at 8k ft. The further I got out over the lake, however, the thicker the soup got below. Flight service kept telling me the weather would clear to the East, but as I neared my destination, ceiling was reporting 700 (misty rain) with tops at about 3000.
I puckered-up, descended thru the soup keeping eyes glued to the panel, scanning the flight instruments & focusing on staying right side up. It took about 3 minutes before I broke thru below but it seemed more like 3 hours. I did not pay attention to course (Michigan is pretty flat - except for cell phone towers) and, as a result, broke out 180 degrees opposite the course I was on when I began the descent.
No matter, I was out, right side up and 5 minutes from home over familiar territory. Landing was uneventfuI and underwear unsoiled. But I am buying myself a Tru-trak ADI (with GPS) for Christmas.
Michel Verheughe <michel(at)online.no> wrote:
[quote]--> Kitfox-List message posted by: Michel Verheughe
friends.
was CAVOK.
problem to keep the plane on en even Be a better pen pal. [quote][b]
john(at)leptron.com
PostPosted: Tue Nov 20, 2007 2:21 pm    Post subject: IFR in a kitfox Reply with quote
I installed the tru-trac adi last winter and have used it several times while leaving the primitive area in the dark. It has been one of my best investments yet.
John Oakley [b]
Michel
PostPosted: Wed Nov 21, 2007 10:48 am    Post subject: IFR in a kitfox Reply with quote
over lake Michigan.
Thanks for sharing, Marco. I have two questions:
1) How did you keep from going in a bank if you didn't had a giro
instrument?
2) Is on-top permitted in the US with non-certified engines? It is not
in Norway. The idea is: You must always have a possible landing place
in sight. Something you can't over the clouds. Maybe it's our
mountainous terrain that dictates that.
The only time I flew on-top (against my best judgement) it was over the
fog and I knew it would be clear at arrival, it was only a round trip.
Here it is:
http://home.online.no/~michel/Autumn/
Michel Verheughe
Norway
akflyer
PostPosted: Wed Nov 21, 2007 11:37 am    Post subject: Re: IFR in a kitfox Reply with quote
Michel,
Even if you are IFR rated an the plane has a full panel, you better be ready to fly with no gyros. Have lost a vacuum pump and it can hose you up good if you are fixated on your main flight instrument(s) (artificial horizon etc.). You can watch you compass to indicate turning, airspeed to tell if you are climbing or diving, RPM changes are great indications also. glance down to see if you are holding the stick or yoke in an unusual position (may indicate a turning climb or shallow dive). Most guys have a GPS on-board and most have some sort of situational awareness screen.
I have been in IFR conditions twice in a bare panel PA12, once was in a mountain pass. When I started in the pass at 1500' I could see the "turn" about 6 miles out. About 1 mile into the pass a layer formed within about 1 minute that made it hard to see the prop... I had an old Sony Pixes GPS that had a moving map and only showed the track not real terrain features. I kept myself glued to the bread crumb trail I had made earlier pointed the nose to the sky and firewalled it... I broke out at 14,500 in desperate need of a new pair of shorts as I was within a few miles of mount redoubt and really did not want to become a permanent part of the landscape. I went in the following week and began my Instrument training.
My instructor really loved to cover up various instruments at the most in-opportune times just to drill it into you NOT to get fixated and to let you know that you don't have to have a full panel to get yourself out of a tight spot and back home as long as you keep you head on straight and don't panic.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
PostPosted: Wed Nov 21, 2007 3:23 pm    Post subject: IFR in a kitfox Reply with quote
Michel,
I didn't avoid a bank. I was focused on staying right side up, keeping airspeed and rate of descent constant and the ball centered. Because I wasn't concerned about course (GPS showed no obstructions below) I did do an unintentional 180 degree, 3 minute turn.
To my knowledge, VFR "over the top" in the US is not restricted based on whether engine is certificated or not. If it is, I made up all that stuff in my last 2 posts. Wink
over lake Michigan.
Thanks for Be a better pen pal. [quote][b]
Float Flyr
PostPosted: Thu Nov 22, 2007 6:18 am    Post subject: IFR in a kitfox Reply with quote
On one occasion when I was doing my flight training my flight instructor had me blind folded for about five minutes at 5000' agl. The first minute or so seemed like an eternity not to mention a roller coaster. After that, once I calmed down, the the ride got a lot smoother. I found I was actually telling direction by feeling the sun on my face. I was concentrating on my butt. I had read somewhere that's where the term flying by the seat of your pants comes from.
The exercise was apparently to teach me that I could fly the plane regardless of what happened.
[img]cid:510325013(at)22112007-08A9[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  617 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Thu Nov 22, 2007 9:23 am    Post subject: IFR in a kitfox Reply with quote
Noel sez:
agl...I found I was actually telling direction by feeling the sun on
my face.
Doesn't seem a very useful exercise. If you can feel the sun on your
face you aren't in instrument conditions and you should have no
trouble staying upright... Smile
Mike G.
N728KF
Phoenix, AZ
akanka(at)kiamichiwb.org
PostPosted: Thu Nov 22, 2007 11:21 am    Post subject: IFR in a kitfox Reply with quote
aerobatics(at)aol.com
PostPosted: Thu Nov 22, 2007 11:32 am    Post subject: IFR in a kitfox Reply with quote
Sun on the face is a good one.... I teach instrument for a living and
have heard many good ones like simpley listening do one thinr if makes
it worse do something else ....
don't reccommend any of that of course...
do reccommend at least some training and try to at least practice a bit
with a safety pilot a few times a year. Proper scan along a bit of
comfort knowing u can could save your life even if not legal.
Getting caught on top low fuel as a VFR pilot is a real scenerio even
when being careful.
I also have heard some wise instrument pilots won't go unless there at
least VFR legal under very wise
fly safe
Dave KF2
http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003
PostPosted: Thu Nov 22, 2007 11:36 am    Post subject: IFR in a kitfox Reply with quote
when being careful.
fly safe
Dave KF2
Michel
PostPosted: Thu Nov 22, 2007 2:48 pm    Post subject: IFR in a kitfox Reply with quote
Then you confirm what I thought, Marco, thank you. Mind you, if I fly
"over the top" in Norway, nobody will know because when I am up there,
I am only a tag on the controller's secondary radar! Smile
Michel Verheughe
Norway
7suds(at)Chartermi.net
PostPosted: Thu Nov 22, 2007 2:51 pm    Post subject: IFR in a kitfox Reply with quote
Guys,
While flight trainiing in a 150 my instructor had me do an exercise one
morning where we climbed to altitude and then he had me put my chin in my
chest and fly by feel and sound, I did well for a while and then the engine
started to rev, so my senses told me we were decending so I pulled back on
the yoke and heard the engine rev a little more. All the time my body senses
told me I was upright and straight. My instructor had me look up at that
time and to my surprise we were in a 1 G spiral headed towards the ground,
so when I pulled back earlier I simply tightened the spiral. I recovered and
learned a valuable lesson, senses can be decieving.
Lloyd
Model 5 Rebuild
Rotax 912
Iron Mountain Mi.
Noel sez:
>had me blind folded for about five minutes at 5000' agl...I found I was
Doesn't seem a very useful exercise. If you can feel the sun on your face
you aren't in instrument conditions and you should have no trouble staying
upright... Smile
Mike G.
N728KF
Phoenix, AZ
Michel
PostPosted: Thu Nov 22, 2007 2:54 pm    Post subject: IFR in a kitfox Reply with quote
I agree with you, Leonard, when you fly, you have to be ready for
anything and it is better to practice whenever one can.
But I agree with John when he says that even the best pilot cannot
sustain level flight in IMC, without gyro/GPS for more than a limited
time. I think that most aviator handbooks will agree with that too. The
next factor, which may be individual, is how we handle the situation
when adrenaline pumps in our veins. I know that I can fly my replica
Kitfox with exactly the same instruments in a flight simulator for
hours. But when I had to do it in real life for ten minutes, I noticed
how fast I lost concentration.
Michel Verheughe
Norway
avidfox
PostPosted: Thu Nov 22, 2007 3:32 pm    Post subject: IFR in a kitfox Reply with quote
"....even the best pilot cannot sustain level flight in IMC, without
time."
Don't tell my WWII P-51D driver Dad that..
"Needle, Ball, Airspeed....' from takeoff to 25,000 ft when
necessary. That was after a zero visibility takeoff using the DG to
maintain runway heading.
I guess the 250 hr, 20 yr old CFI's, with their ties and prettty
shoulder stripes don't get in to that anymore.
The man is now 85 and still does it right...most every weekend in his
basic IFR Skyhawk. No auto pilot, no wing leveler. Just good
airmanship and a constant instrument scan.
Needle ...ball...airspeed... learn the basics... then get the "toys".
Steve
84KF
Float Flyr
PostPosted: Thu Nov 22, 2007 3:43 pm    Post subject: IFR in a kitfox Reply with quote
For the first couple of minutes I wasn't feeling any thing on my face...
The only thing that kept me coherent at all was the knowledge that the
instructor was in the seat beside me if I inadvertently stood the plane on
its tail or nose. During the whole exercise he didn't touch the controls at
all... In fact he seemed quite impressed.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Goto page 1, 2  Next
Page 1 of 2
