Pullable 60 Amp Breaker
Tim_Lewis(at)msm.umr.edu
PostPosted: Sun Nov 18, 2007 6:05 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
Over the years I've looked without success for a pullable 60 Amp breaker. The other day I noticed one in a friend's Glastar (an early two-weeks-to-taxi pathfinder). I crawled under the panel, jotted down the part number, and found several sources on the net. The part number is 413-K14-LN2, made by ETA. I bought one from Pacific Coast Avionics (part number "ETA-60". They have a 75 Amp version, too.
Use with caution, of course. Pulling the breaker when the alternator is putting out significant current can ruin the alternator (V = L*di/dt, I suppose).
[img]cid:part1.03070702.07050801(at)msm.umr.edu[/img]
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 900 hrs
RV-10 #40059 under construction
 Filesize:  2.68 KB
 Viewed:  3140 Time(s)
longg(at)pjm.com
PostPosted: Mon Nov 19, 2007 6:02 am    Post subject: Pullable 60 Amp Breaker Reply with quote
Great find but an ANL fuse will offer the same protection and keep you or a curious passenger from ruining your alternator. Not to mention it cost about 1/10 of that breaker. Why are you so interested in isolating your alternator? When my alternator fails it doesn't run a-muck in the engine compartment and burst into flames, it simply becomes another lawn ornament.
 Filesize:  2.68 KB
nuckolls.bob(at)cox.net
PostPosted: Mon Nov 19, 2007 7:20 am    Post subject: Pullable 60 Amp Breaker Reply with quote
At 08:58 AM 11/19/2007 -0500, you wrote:
This thread has stirred a lot of concerns together which
I will attempt to put into perspective.
First, know that designers of upper-end production aircraft
have made a effort to get high-current, noise-carrying
conductors off the panel. The alternator is the strongest
noise source on the bus and it's b-lead is the strongest
emitter of magnetically coupled noise in the airplane. Hence,
a migration of b-lead protection out of the cockpit and onto
the firewall as seen here . . .
http://www.aeroelectric.com/Pictures/Wiring_Technique/Firewall_Ckt_Protection.jpg
Second, I cringe when concerns for the actions of
"curious passengers" are raised as drivers for how a
cockpit is laid out or fitted . . . I've flown hundreds
of passengers and never have I had to admonish anyone
to "not touch that". There would be only ONE time
that I might have to educate someone on passenger cockpit
etiquette. The second incident would result in a dispatched
return to the field and a polite request that the individual
exit the aircraft.
Third, it has been suggested that a breaker might serve
as the last-ditch means by which a pilot can bring a runaway
alternator to heel . . . or at least disconnect it from the
system. This logic is flawed for several reasons: (1) breakers
are designed to disconnect hard downstream faults in a system
where the voltage are on the order of 32 volts or less. (2)
A runaway alternator is capable of raising the b-lead terminal
to hundreds of volts in milliseconds where it is NOT reasonable
to expect the breaker to also serve as a SWITCH for reliable
disconnect of the offending alternator. Any attempt to use
a breaker (particularly a miniature one with plastic housing!)
for this purpose is to flirt with probability of cockpit fire
and much smoke.
Finally, know that a 60A breaker on a 60A alternator is
DESIGNED to nuisance trip. The b-lead protection on an alternator
should stay closed at current levels perhaps 20% higher than
the nameplate rating of the alternator. The GA spam-can community
really blew it when 60A b-lead breakers were installed in 100,000+
aircraft with 60A alternators.
The ideas cited above are drivers for my personal design
goals that strive to (1) move b-leads out of the cockpit and
(2) supply any-time, any-conditions, positive ON-OFF control
of all energy sources to the aircraft crew.
Of course, we're free to establish and satisfy any alternative
design goals. Incorporation of the 60A, panel mounted,
pullable breaker to satisfy the goals cited is, in my humble
opinion, ignoring a lot of experience and thoughtful reasoning
suggesting that panel a mounted, b-lead breaker is not the
best-we-know-how-to-do.
[quote]Great find but an ANL fuse will offer the same protection and keep you or
 Filesize:  2.68 KB
klehman(at)albedo.net
PostPosted: Mon Nov 19, 2007 3:12 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
In addition to other concerns, if they are push on connections, I'd
would not expect them to stand up to 60+ amps very long. Can you even
get push on connectors for awg 6 wire?
Ken
PostPosted: Mon Nov 19, 2007 4:52 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
The breaker uses a 3/8" screw (huge flat head) on both lugs.
RV-6A N47TD -- 975 hrs
Ken
gmcjetpilot
PostPosted: Tue Nov 20, 2007 1:24 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
Subject: RE: Pullable 60 Amp Breaker
Never heard noise in my plane with B-lead CB in panel.
I would just say prove it. Modern internally regulated alternators
are not noisy so it's a moot point. Old Gen from days gone by, yes
noisy.
You are stretching. Does the passenger have a control
yoke or stick they could shove right after takeoff or
right before landing? No Bozo allowed.
and much smoke.
With all due respect I think your logic is flawed. It may fit for external
regulated alternators but not for internally regulated ones.
A CB is RATED to disconnect at 32volts many many times, however
it can handle much more. No I don't have an absolute number but
when most 12 volt alternators with a so called over voltage rarely
exceeds 17 v much less 32 v, your point is moot, 32v good enough.
When you say 100's of VOLTS and Cockpit FIRE, it's fear mongering
not based on facts. Science and engineering are based on facts not
emotional reasons. CB catch on fire? Really? OK, prove it.
Small 40 / 60 amp alternators are not pumping 100's of volts or amps.
Internally regulated alternators typically go to 16 or 17 volts, if
regulation fails, easily controlled by a CB. Yes there may have
been one "screw lose" case where voltage was truly out of control,
but it's rare, and the voltage was undetermined. I doubt it got to
over 32 volts.
Also an ANL fuse will not blow with 100's of volts, it's a current
device. If you want to wire your airplane like a Toyota with fuses, fine,
but there is no need to make stuff up against CB's in the panel.
Easily solved by sizing the CB properly. I guess they don't have
smart people working for the GA spam-can community. Frankly CB's
can take slight overloads for a period of time with out a trip. Again
moot point Bob, if the alternator can only put out 45 amps.
>In my humble opinion, ignoring a lot of experience and
thoughtful reasoning suggesting that panel a mounted, b-lead
breaker is not the best-we-know-how-to-do.
What?
Fuses are fine. Buth with (stock) internal regulation the CB is a good
reason to use a B-lead CB. Other engineers have worked on this
Bob. The pull-able CB for the B-lead is specified. It's irresponsible of
you to be so stubborn and opinionated, making ONE blanked edict
that one size fits all. Fuses are not a BE ALL solution for every
application. Follow the manufactures recommendation!
In my humble opinion, I disagree with Bob with my thoughtful reasoning
and facts. I don't care what you use but know why you are using it. I
don't believe you will have noise or won't be able to disconnect the
b-lead manually if you want to. When people talk 100's of volts & fire
they are exaggerating in non-scientific emotional arguments, not
engineering. Have Bob prove these are real problems. I could come
up with lots of NIT PICK reasons a fuse really is a poor choice.
Cheers George
schaefer(at)rts-services.
PostPosted: Tue Nov 20, 2007 2:16 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
Why would anyone want to reset a tripped 60A breaker in flight ?
If you want to disable the alternator than switching off the alternator field would generate a lot less transients that components have to deal with.
PostPosted: Wed Nov 21, 2007 3:15 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
Date: Tue, 20 Nov 2007 13:23:04 -0800 (PST)
noisy.
George, this has nothing to do with the style of
regulator. 3-phase rectified AC has a 5% built-in ripple
component that is a physical artifact of the product.
I've encountered magnetically coupled noises in both
automobiles and aircraft. So your statement about "modern
internally regulated alternators not being noisy" is
demonstrably in error and your admonition to "prove it"
is a manifestation of your proven history of inability
or unwillingness to carry on discussions based on
physics and simple-ideas.
I've troubleshot and fixed a number of magnetically
coupled alternator whine problems on aircraft and once
in my own automobile. It's doubtful that any demonstration
would be sufficient "proof" to make this phenomenon
real and significant in your limited understanding.
Alternators are much more noisy than generators.
>and much smoke.
It matters not what style of alternator is being
considered, any alternator running self-excited by
a field voltage which is a product of it's own output
is capable of well over 100 volts of output. See:
http://aeroelectric.com/articles/When_is_110V_not_Over_Voltage.pdf
A CB is RATED to disconnect at 32 volts many many times, however
Yes, the runaway alternators that were NOT putting out
hundreds of volts were being loaded by a battery that
was dutifully sacrificing itself by accepting what the
alternator could deliver due to its inherent current
limiting.
But the very act of opening the b-lead on a runaway
alternator disconnects the battery and all other parts
of the ship's systems. As soon as the contacts of the
'switch' open, the alternator becomes unrestrained and
b-lead voltage will rise rapidly to values much greater
than the 32-volt rating of the breaker. Once you strike
the arc between the opening contacts, one has 100+
volts at 40-60 amps (4,000+ watts) of potential power
being dumped into the fire. This would probably be
contained by an all-metal enclosure like:
http://www.aeroelectric.com/Pictures/Contactors/s701-1.jpg
but enclosures like this . . .
http://www.aeroelectric.com/Pictures/Contactors/6041_Contactor.jpg
. . . have proven incapable of containing such fires
http://www.aeroelectric.com/Pictures/Failures/6041_Contactor_Failure.jpg
It is an absolute certainty that an enclosure like this
http://www.aeroelectric.com/Pictures/Breakers/circuitbreakers.jpg
will not contain such fires either.
over 32 volts.
As soon as the runaway alternator is disconnected from
the system by pulling a breaker, the battery is relieved
of sacrificial duties and the voltage at the alternator's
b-lead will rise rapidly and to magnitudes previously cited. . .
the Mother of All Load Dumps.
Fuses are not expected to protect against over-voltage events
but over-current events. Know that a runaway alternator has
NEVER put out more current that what's established by the
physics of it's magnetics. I.e, not enough to open the
b-lead protection irrespective of it's design (assuming
it is sized for sufficient headroom to avoid nuisance
tripping). Nonetheless, bus voltages are carried upward
to many times greater than normal bus voltage unless
some well considered means for stopping it has been included
in the design.
That's what I said. The 60A breaker is too small for
being used with a 60A alternator. Yes, MOST nuisance
tripping is avoided by the noteworthy time delays
inherent in the design of CBs . . . but the majority
of nuisance trips of breakers in light aircraft are
the 60A b-lead breaker tied to a 60A alternator.
Your off-hand comment about the intelligence of folks
working in GA is uncalled for and yet another manifestation
of your long and oft demonstrated history of belligerent,
ill-informed, nay ignorant participation on this List.
There are MANY folks within GA that would very much
like to rectify the condition cited . . . but it's never
bubbled to the top-ten-problems list with an airframe OEM and
the FAA makes it insanely $difficult$ to make even the
simplest changes. Hence, this marginal design has
endured for decades more out of resignation to the
authority of a higher power than of ignorance or apathy.
>Bob . . .
What?
This isn't a fuses/breakers discussion, it's
an examination of the physics which govern assembly
of some exceedingly simple ideas into recipes for
success with an acknowledgment of hazards which
should be considered as part of a thoughtful design.
George, you have been politely requested to keep
your comments on this topic to yourself . . . they've
been read many times for years on this List and debunked
as recorded and published at:
http://www.aeroelectric.com/articles/gmcjetpilot.html
http://aeroelectric.com/articles/The_Truth_about_Crowbar_OV_Protection.pdf
You have designed nothing, fixed nothing, contributed
nothing to the understanding of physics, serviced no
customers, taught no classes, or offered a 100% satisfaction
assured warranty for your products. Yet you persist
in lurking at the edges of a sandbox not of your
construction to throw rocks and mud while hiding behind
a pseudonym decorated with much alphabet soup of
self proclaimed titles/accolades. You claim superior
engineering insight while never having demonstrated
it with useful work-product.
I've demonstrated/experienced/explained every assertion
I've ever made based on my hands-on experiences with these
systems since I did my first OV relay design for Cessna
Aircraft in 1975. Your belittling diatribes and circular
arguments contribute nothing to the advancement of
our science, understanding or art and yet you deign to
call me a liar. Your brand of 'science' is not welcome
in this classroom. You sir are the secretive, fraudulent
participant in these discussions and I will ask you
politely for the third or forth time, please go away.
( -Thomas Paine 1776- )
PostPosted: Wed Nov 21, 2007 3:52 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
Yes, you'll have to research this topic in the
archives a bit. It's not about whether or not
one should 'reset' a tripped breaker but one
of selecting design goals. I.e, is it (1)
reasonable to assume an alternator with a "broken"
internal regulator can be depended upon to
remain at or below 17 volts and (2)
depend on a panel mounted b-lead breaker
to disconnect said alternator from the bus
after (3) the pilot becomes aware of the OV
condition.
It has been suggested that this design
goal is a suitable alternative to architectures
and goals embraced by the vast majority
of the TC aviation community.
medorrisjr(at)hotmail.com
PostPosted: Wed Nov 21, 2007 5:46 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
With several hundred, uh thousands (they become blurred and seemingly insignificant) of flight hours I now attempt a life-long goal of building my own airplane. My self-professed weakness is wiring, electronics and electricity in general. Thus, my reason for joining this forum.  I read every post with an open mind and hopefully add to my limited understanding of the traveling electron.
In following this thread of "Pullable 60 Amp Breaker" I am reminded of something I learned a long time ago. The only difference between a jet pilot and a jet engine is the fact that a jet engine stops whining when you shut it down.
Happy Thanksgiving & Best Regards to all,
Marvin
e: Wed, 21 Nov 2007 17:08:17 -0600
Subject: Re: AeroElectric-List: RE: Pullable 60 Amp Breaker
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
>noisy.
> >and much smoke.
limiting.
>over 32 volts.
in the design.
> >Bob . . .
>What?
PostPosted: Wed Nov 21, 2007 8:47 pm    Post subject: Pullable 60 Amp Breaker Reply with quote
you shut it down.
It is for folks such as yourself that at least
some among us must go out of their way to protect
the liberties of all against the attacks of a
few. This is the simple-idea that defines
honorable behavior. I (and I'm sure others)
will continue to sift and refine the inventions
to be formed from solid understanding of their
component simple-ideas. You have come to the
right place sir.
