thebourgets(at)cia.com Guest
Posted: Mon Nov 19, 2007 5:33 pm Post subject: New Ownership for Cdn. CJ |
Hi all,,,
Just had to share. This evening I concluded a deal for my new Chang C-FXMI... will be flying with me soon.
Thank you to all who gave me advice, and all of your words of encouragement.
I have to brag now <grin>
Here she is: (I can’t figure out how to post a picture or a movie)
Nanchang CJ-6A Serial # 1332012, Registered as Canadian C-FXMI
The aircraft was then disassembled for full inspection, painted,
modified as noted below, reassembled and certified with a
Certificate of Airworthiness in December, 1994.
Both night and aerobatic certifications have since been received from Transport
Canada
This CJ is a 1965 model with 3,400 airframe and 339 engine hours
since installation of a “0” time since first factory overhaul stock Housai engine four years ago. Propellor is new, “0” time in Dec. 2004 – replaced at the 10 year standard overhaul time for all Canadian aircraft.
The aircraft is painted in the colours of a
Soviet Guards Sqn. of circa 1943. Both cockpits have been
refinished in standard military grey. Both airspeed indicators and
altimeters have been replaced with knots and feet respectively. Standard
equipment includes stock inverter-powered A/H and gyrosyn compasses in each
cockpit.
All modifications, installations, annuals, and periodic maintenance have been undertaken through Victoria Air Maintenance. Modifications or improvements include:
<![if !supportLists]> <![endif]>-tinted new canopy (plexiglass is provided by a Seattle firm);
<![if !supportLists]> <![endif]>-enlarged (plug added) fuel tanks, for total 53 US Gal (204 litres).
<![if !supportLists]> <![endif]>-Cleveland nose wheel conversion
<![if !supportLists]> <![endif]>-auxiliary air bottle with separate selector valve, gauge and plumbing (the tank is also recharged by the engine compressor similar to the standard tank);
<![if !supportLists]> <![endif]>-EGT and OAT gauges, plus “G” meter;
<![if !supportLists]> <![endif]>-functional stock instrument lighting & pitot heat;
<![if !supportLists]> <![endif]>-luggage compartment behind the rear seat
<![if !supportLists]> <![endif]>-alternate static (cockpit air);
<![if !supportLists]> <![endif]>-pre-oiler;
<![if !supportLists]> <![endif]>-avionics installation of Narco Com 810 TSO, Narco Nav 825 TSO, Narco ILS Loc & GS; Apollo II Morrow 2001 NMS GPS, King KT-76A transponder plus encoder, plus ELT;
<![if !supportLists]> <![endif]>-100% stainless steel exhaust conversion, installed with new engine in December, 2000;
<![if !supportLists]> <![endif]>-Reinforced wing walk;
<![if !supportLists]> <![endif]>-Standard North American Halogen sealed beam landing light conversion;
<![if !supportLists]> <![endif]>-Replaced upper stabilizer fairings with new, for improved appearance;
-All instruments and controls are functional in both cockpits.
cjpilot710(at)aol.com Guest
Posted: Mon Nov 19, 2007 5:43 pm Post subject: New Ownership for Cdn. CJ |
Mike,
Good for you! Welcome to the exclusive club of people who have enough moxie and eye for beauty to pick a CJ OVER a Yak.
You need only now to fly a lot and get your self down to Oshkosh next year to help celibate her Fifth birthday.
Jim "Pappy" Goolsby
In a message dated 11/19/2007 8:34:16 P.M. Eastern Standard Time, thebourgets(at)cia.com writes:
Hi all,,,
Canada
cockpit.
· -tinted new canopy (plexiglass is provided by a Seattle firm);
· -enlarged (plug added) fuel tanks, for total 53 US Gal (204 litres).
· -Cleveland nose wheel conversion
· -auxiliary air bottle with separate selector valve, gauge and plumbing (the tank is also recharged by the engine compressor similar to the standard tank);
· -EGT and OAT gauges, plus “G” meter;
· -functional stock instrument lighting & pitot heat;
· -luggage compartment behind the rear seat
· -alternate static (cockpit air);
· -pre-oiler;
· -avionics installation of Narco Com 810 TSO, Narco Nav 825 TSO, Narco ILS Loc & GS; Apollo II Morrow 2001 NMS GPS, King KT-76A transponder plus encoder, plus ELT;
· -100% stainless steel exhaust conversion, installed with new engine in December, 2000;
· -Reinforced wing walk;
· -Standard North American Halogen sealed beam landing light conversion;
· -Replaced upper stabilizer fairings with new, for improved appearance;
://www.matronics.com/contribution">http://www.matronics.com/contribution
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
.matronics.com/">http://forums.matronics.com
skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
skidmk
Posted: Mon Nov 19, 2007 6:16 pm Post subject: Oh Yeah,, ,here are some pics |
thought I 'd send some pics....
1.21 MB |
382 Time(s) |
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
