Charles Heathco
Posted: Fri Feb 24, 2006 7:22 am Post subject: Freezin high up in drafty 6A. |
I had to stuff things in around the seat to cut down on the freezing cold air coming in from various places overcomming the anemic heat source yesterday. Had to come down to 11500 ( taking advantage of the 70mp tail winds), and legs still shaking. 2 questions. Anybody tried adding a 2nd heat muff on the rt exaust, and 2, is it practicle to try and cover the inspection panels for the flap actuators. I have insulated the fluting on the baagage bulkhead, but still get lots of cold air. I got the drawings for the actuator covers, but dont see that as a good seal. Charlie Heathco
SSoule(at)pfclaw.com Guest
Posted: Fri Feb 24, 2006 7:41 am Post subject: Freezin high up in drafty 6A. |
Hi Charlie,
I bought an insulated USAF flight suit (Nomex and never worn, $100) and wear
felt lined boots, gloves and a hat.
Stephen Soule, RV-6A N227RV
Highgate, Vermont
DOUGPFLYRV(at)aol.com Guest
Posted: Fri Feb 24, 2006 7:51 am Post subject: Freezin high up in drafty 6A. |
Charlie, we have 2 heat muffs on our 7. We bought it in MSP so they were
being prepared for the COLD. I have no idea what you may encounter in the
process. Appears that it would not be a problem to add it.
Doug
N731RV
DO NOT ARCHIVE
Ed Anderson
Charlie,
A lot of the cold air may be coming up between your legs from the opening
for the control stick. I get a lot of cold air there - nice in the summer,
but brutal in cold weather. I have seen various schemes to keep the cold
air from entering underneath the floor pan through the aileron push tube
holes in side of fuselage.
I am considering using a control stick boot to at least cut down on the air
flow.
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Fri Feb 24, 2006 8:01 am Post subject: Freezin high up in drafty 6A. |
I built 2 RV-6A's which I flew in northern British Columbia.
I installed two heat muffs with two entrances into the cockpit.
I insulated all the side walls including under the panel.
I installed boots around the aileron push tubes (the biggest offender for
cold air)
I put weatherstrip under the rear skirt on the slider canopy as well as
along the side skirts. (2nd biggest offender)
I never did the baggage bulkheads or the flap actuator rods.
The plane was comfortable to fly down to about -15 or -20 deg celsius.
Ted French
RV-10 fuselage (finish kit here)
_________________ Ted French
RV-10 fuselage |
johnd(at)wlcwyo.com Guest
I had the same problem 4 years ago when I flew to Rochester, MN. It was
10F below when I landed. My daughter and I were dawn cold.
Later I added a second heat muff, built aileron boots to cover the push
tube exit hole. I also insulated the panel where the flap horn exits.
I have a slider and I placed some thin weather stripping at the very
edge of the back of the canopy.
Another thing is the air coming in along the side of the canopy. A
simple fix is to get some 1/2" foam pipe insulation, and cut to lengths
that will sit between the front part of the slider and the locking block
in back. Simply put these in place after you have the canopy closed and
are ready to taxi.
After these fixes we flew very comfortably when temperatures were below
0 F.
PS I don't recommend flying when temperatures at 10 below F.
John L. Danielson
Knicholas2(at)aol.com Guest
Posted: Fri Feb 24, 2006 8:04 am Post subject: Freezin high up in drafty 6A. |
There is an amazing amount of air that flows from around the edges of the
canopy - especially the rear area. I put weather strip around the canopy, boots
around the airleron control rods thru the fusealge, and boots on the stick.
The combination made an enormous difference.
Kim Nicholas
RV9A
Auburn, WA
ronlee(at)pcisys.net Guest
Posted: Fri Feb 24, 2006 8:13 am Post subject: Freezin high up in drafty 6A. |
At 08:20 AM 2/24/2006, you wrote:
My 6A had a second heat muff and it did nothing but negatively impact
cooling air exiting the airplane (with oil temp problems). I now just
use one heat muff and it is probably better.
I also have the drafty issues and fixing those is among the best
remedies (along with Stephen's warm clothing comment).
Ron Lee
Posted: Fri Feb 24, 2006 8:20 am Post subject: Freezin high up in drafty 6A. |
I just ordered my exhaust system from Vetterman - with dual heater/mufflers. It gets cold here on the DelMarVa peninsula...
I'm also interested in what everyone else has done / is doing to cure this.....
Ralph Capen
Posted: Fri Feb 24, 2006 10:32 am Post subject: Freezin high up in drafty 6A. |
At 09:18 AM 2/24/2006, you wrote:
this.....
I would run each heat muff to a separate entry into the cockpit.
One for pilot and one for pax.
Ron
Posted: Fri Feb 24, 2006 11:15 am Post subject: Freezin high up in drafty 6A. |
That was part of that plan...I also have injection so the induction system doesn't need heat.......
shempdowling2(at)earthlin Guest
Posted: Fri Feb 24, 2006 1:40 pm Post subject: Freezin high up in drafty 6A. |
Vans recommends plumbing the 2 heat muffs in series.
Shemp/Jeff Dowling
RV-6A, N915JD
265 hours
Chicago/Louisville
