lcottrell
Posted: Thu Nov 15, 2007 6:39 pm Post subject: a flying day |
The weather turned off clear and of course a bit cold. The wind forecast was from the south at no more than 10 all day. I rolled out the Firestar and fueled up to max. When I took off at 10: AM the temp was 31 degrees. I have been presenting the Ranchers that allow me to hunt my hawks on their property with a framed 8x10 aerial photo of their ranch. It seems to go over pretty well, and it is the least that I could do. There were two ranches that I did not like the picture that I had and wanted to do it over. I climbed up to 1600 feet agl and headed east. I have a enclosure around the front, but leave off the clear plastic that Kolb sends to make their full enclosure. (Slows flight by 10 mph) I do have a heater that captures the air from the engine shroud. I also use a cowboy (buckaroo in this area) "Wild Rag", a silk scarf around my neck, down vest, leather flight jacket. I also use "Bog" boots on my feet.(neoprene) as my feet generally get cold at these temps. The flight was just great. I had my 10 MPH wind from the south and was making 86 over the ground. The air was as stable as it ever gets. I had checked the batteries in the camera before leaving the ground and of course after I took three pictures the rascal was showing dying batteries. My path after the ranch houses took me along the Jordan River, and out to the Jordan Craters Lava Flow. I was also checking for duck ponds to visit later.
The Jordan craters flow covers about 25 miles, and was featured in one of Louis Lamour's novels. The lava has not collapsed, so the lava is scabbed over and it is hollow underneath. Kind of unnerving when you walk on it. Little spots have collapsed making little potholes where grass and willows grow. Some of them are filled with water and ducks are as safe there as they ever get. I also took a picture of a "line shack" made out of the lava rock. A bit hard to see. Then I came back over the Pillars of Rome. As I came back over the desert leaving the ranches behind, I can see a glowing white dot that is a feral horse that lives there with a buckskin and a bay. She shows up when the sun hits her for at least 10 miles. She is a "Cream" and to me looks like Silver, Gene Autry's horse. She also has black eyes, but that is the only color on her. She is also as wild as a March hare, and starts running as soon as she sees a plane. ( They round them up with choppers) I took this picture and lined up for a real close up and had her with her head up looking behind her at me. Mane and tail were flying, I was 25 feet high and 50 feet behind. You guessed it, the camera died!
Larry C
[img]cid:00da01c827f9$52de2946(at)usermj5tjr71vq[/img]
221.21 KB |
430 Time(s) |
biglar
Posted: Thu Nov 15, 2007 7:12 pm Post subject: a flying day |
Heck of a shot, Larry. I want to see the next ones. Take a spare battery in your shirt pocket. I learned the hard way, too. Lar. Do not Archive.
Larry Cottrell wrote: [quote] The weather turned off clear and of course a bit cold. The wind forecast was from the south at no more than 10 all day. I rolled out the Firestar and fueled up to max. When I took off at 10: AM the temp was 31 degrees. I have been presenting the Ranchers that allow me to hunt my hawks on their property with a framed 8x10 aerial photo of their ranch. It seems to go over pretty well, and it is the least that I could do. There were two ranches that I did not like the picture that I had and wanted to do it over. I climbed up to 1600 feet agl and headed east. I have a enclosure around the front, but leave off the clear plastic that Kolb sends to make
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
lcottrell
Posted: Thu Nov 15, 2007 10:34 pm Post subject: a flying day |
My wife has informed me that Silver was the Lone Rangers Horse. I actually knew that.
Larry (Dangerfield) C
Posted: Fri Nov 16, 2007 6:12 am Post subject: a flying day |
Larry, I too have a battery-gobbling early digital. After some
experimenting, the best
batteries I have found to date are:
DURACELL AA/HR6//DC1500 NiMH 2650mAh
I found them at Kmart.
I also use a slow charger that takes overnight to recharge.
BB
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Fri Nov 16, 2007 12:50 pm Post subject: Re: a flying day |
Larry forwarded the rest of the pics he had. They are now posted online in front of the others he shared.
http://www.ill-eagleaviation.com/larryc.htm
I'm trying out a slideshow format on this page. Any comments, good or bad, would be appreciated. Send them directly to me.
icrashrc(at) aol dot com
_________________ Scott
www.ill-EagleAviation.com
do not archive |
gaman(at)att.net Guest
Posted: Fri Nov 16, 2007 1:24 pm Post subject: a flying day |
ElleryWeld(at)aol.com Guest
Posted: Fri Nov 16, 2007 2:50 pm Post subject: a flying day |
gaman(at)att.net (gaman(at)att.net) your shooting blanks man fix your gun
Couldnt resist ...LOL
Ellery
lcottrell
Posted: Fri Nov 16, 2007 5:54 pm Post subject: a flying day |
It looked good to me.Thanks
Larry
