jswanson(at)jamadots.com Guest
Posted: Wed Nov 07, 2007 3:13 pm Post subject: CH701 Rotax 912 |
Installing Rotax 912 into CH701.
Trying to wire the switch to the Mags. How do i install the flat pin terminal
to the shielded wire?
What tool do i need?
John
seems as if the last 10% takes longer
nuckolls.bob(at)cox.net Guest
Posted: Wed Nov 07, 2007 4:04 pm Post subject: CH701 Rotax 912 |
At 06:04 PM 11/7/2007 -0500, you wrote:
| Quote: | Installing Rotax 912 into CH701.
I presume you're wrestling with the shield connection.
No special tools needed. You need to convert the shield
braid into wire like so:
http://aeroelectric.com/articles/pigtail/pigtail.html
Once both conductors at the end of your shielded
wire are "plain wire", you can use the standard
PIDG terminals and appropriate tool.
Posted: Thu Nov 08, 2007 6:27 am Post subject: CH701 Rotax 912 |
Posted: Thu Nov 08, 2007 2:11 pm Post subject: CH701 Rotax 912 |
Apparently the flat pin connector is German DIN, its now on the newer Rotax
912 engines. Its used to plug in the shielded wire from the switch into the
electric module, (mags). I have already ruined one flat pin connector by not
having the proper technique or tool.
Any help on this would be appreciated
Okay, you need to send me a picture of the
parts you're working with. Get me a closeup
of the un-installed pin and the socket in the
module.
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
RURUNY(at)aol.com Guest
Posted: Sat Nov 10, 2007 12:28 pm Post subject: CH701 Rotax 912 |
I posted some pics of the connector in question, I used a crimper as specified on Bobs site.
Just go to:
http://www.701builder.com
I put a link at the top of the homepage called Rotax Ignition Wiring.
hope this helps
Brian Unruh
Long Island
See w [quote][b]
ruruny(at)aol.com Guest
Posted: Sat Nov 10, 2007 10:22 pm Post subject: CH701 Rotax 912 |
Just go to:
hope this helps
Brian Unruh
Long Island Email and AIM finally together. You've gotta check out free AOL Mail!
Posted: Sat Nov 10, 2007 11:42 pm Post subject: CH701 Rotax 912 |
Just go to:
hope this helps
Brian Unruh
