				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| Jeff Linebaugh
				|  Posted: Tue Feb 21, 2006 5:06 am    Post subject: Distraction of the Week |   |
				| Maybe you are right Brian, but I thought we did a leak on gear extension...
 Anyways, the point I was trying to make with the air leak after takeoff is that assuming...
 1) that you checked that you were "making air" before takeoff and
 2) that the air valve was open (Walt....good point also!)
 ...then chances are that the air leak is in the gear retract system. If you put the gear handle down, chances are that you will stop the leak and start making air again.
 If this is the case I see no need to hurry back to land and/or use the emergency system. In fact, I would wait for the compressor to recharge the main system, and then land...
 I have now done my part...you all can now return to dissing flight suits and the FAA....
 JL
 Jeff Linebaugh
 jefflinebaugh(at)earthlink.net (jefflinebaugh(at)earthlink.net)
 http://home.earthlink.net/~jefflinebaugh/
 Yakless with Elvis in Memphis, TN
 [img]cid:F9F2E0B8-51CB-4BA8-9081-2986C6BBEEEB[/img]
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
 Jeff Linebaugh
 jefflinebaugh@earthlink.net
 Collierville, TN
		| Back to top |  |
		| cjpilot710(at)aol.com Guest
				|  Posted: Tue Feb 21, 2006 5:33 am    Post subject: Distraction of the Week |   |
				| No.  I want to add  to this distraction before I trundle off to fly the B-24.  (Oh I think I  mention that already).
 Anyway, what if you  landing gear system has no gear up locks?  Same scenario just that the  airplane, a CJ-6, has no up locks.
 Jim "Pappy"  Goolsby
		| Back to top |  |
		| brian
				|  Posted: Tue Feb 21, 2006 7:13 am    Post subject: Distraction of the Week |   |
				| Jeff Linebaugh wrote:
  	  | Quote: |  	  | Maybe you are right Brian, but I thought we did a leak on gear extension...
 I guess these pneumatic system problems all sound pretty much the same
 to me.
  	  | Quote: |  	  | Anyways, the point I was trying to make with the air leak after takeoff is that assuming...
 Hmm, in the CJ6A with uplocks, after retraction I would put my gear
 lever in neutral. At that point if I am detecting a loss of air pressure
 I doubt it would be in the retraction circuit other than where the
 retraction circuit connects to the main air bus, the rear cockpit gear
 lever in this case.  (Did anyone think about how the gear system depends
 on the rear gear lever?)
 This is a case where it really pays to know how the system works. Where
 do each of the three pneumatic control circuits; i.e. gear, flaps, and
 brakes; connect to the main air bus? What components are in common
 between the main and emergency pneumatic systems? Which lines, check
 valves, and fittings are under pressure in the various configurations?
 Think about it:
 Gear up, gear neutral, gear down.
 flaps up, flaps down.
 Brakes applied left, brakes applied center, brakes applied right, brakes
 off.
 All of the above using the normal system.
 All of the above using the emergency system.
 That is a LOT of combinations and permutations. Isolating a problem
 in-flight and making the right decision requires a lot of understanding.
  	  | Quote: |  	  | I have now done my part...you all can now return to dissing flight suits and the FAA....
 Well I was never really dissing flight suits. I was just dissing the
 demand that I wear one when I feel that, for whatever reason, I am
 better off not wearing one.
 Brian Lloyd                         361 Catterline Way
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
 Brian Lloyd
		| Back to top |  |
		| brian
				|  Posted: Tue Feb 21, 2006 7:25 am    Post subject: Distraction of the Week |   |
				| cjpilot710(at)aol.com wrote:
  	  | Quote: |  	  | */Anyway, what if you landing gear system has no gear up locks?  Same scenario just that the airplane, a CJ-6, has no up locks./*
 Most CJ6A's have uplocks. Some don't. This also affects the trouble
 shooting process.
 Brian Lloyd
		| Back to top |  |
		| BitterlichMG(at)cherrypoi Guest
				|  Posted: Thu Feb 23, 2006 11:32 am    Post subject: Distraction of the Week |   |
				| The answer to this question differs slightly  if you are flying a YAK-50 instead of a 52.  Any input from the 50 folks?
 Mark Bitterlich
 [quote]   --
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
