wingnut
Posted: Sun Nov 04, 2007 2:55 pm Post subject: Broken EGT probe |
I lost my EGT readings on my last flight. Checking the probe, I noticed that it seems to have come apart near the point where it enters the pipe. I have Westach combination gage and I was wondering if I need to replace the probe with a Westach probe or if any EGT probe will do.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
kitfoxpilot(at)msn.com Guest
Posted: Sun Nov 04, 2007 4:08 pm Post subject: Broken EGT probe |
I don't know if this is true or not, but I read someplace that the rotax 912 does not need an EGT, but you do need the CHT, oil temp and oil pressure! I'm no expert!!
Ray
| Quote: | Subject: Broken EGT probe
Date: Sun, 4 Nov 2007 14:55:11 -0800
--> Kitfox-List message posted by: "wingnut" <wingnut(at)spamarrest.com>
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=143849#143849
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote][b]
wingnut
Posted: Sun Nov 04, 2007 4:39 pm Post subject: Re: Broken EGT probe |
| Quote: | | I don't know if this is true or not, but I read someplace that the rotax 912 does not need an EGT, but you do need the CHT, oil temp and oil pressure! I'm no expert!! |
Hmm. That would be interesting. I don't have CHT but I have EGT... Anyone else running with no CHT?
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Sbennett3(at)aol.com Guest
Posted: Sun Nov 04, 2007 4:52 pm Post subject: Broken EGT probe |
Isn't CHT water temp for a 912 ??? I heard the same about egt... Not necessary for a 4 stroke. Although mine has it too. Steve Bennett Durham NC
Posted: Sun Nov 04, 2007 5:03 pm Post subject: Broken EGT probe |
As far as I know you don't need the EGT probe! I have one because the original builder installed one. However, CHT which monitors the temps on the cylinder head is important. I remember viewing the rotax dvd I got a few months ago.
Ray
| Quote: | Subject: Re: Broken EGT probe
Date: Sun, 4 Nov 2007 16:39:26 -0800
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=143863#143863
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Sun Nov 04, 2007 5:05 pm Post subject: Broken EGT probe |
Interesting topic. Six months ago, when I was designing my panel, I ask Lockwood about EGT. He said "forget that". And so I did.
Vic Baker
S7 912S Warp 95%
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
runwayrex(at)juno.com Guest
Posted: Sun Nov 04, 2007 5:27 pm Post subject: Broken EGT probe |
Another viewpoint.............I have four EGT probes on my 912 feeding into a four position switch that feeds the gauge. I don't concern myself too much with it during normal conditions, but it sure comes in handy when troubleshooting a problem. Being able to switch to each cylinder's EGT individually narrows things down quite quickly.
Rex in S.E Michigan / 912 UL / Warp / Model 3 / 628 Hours
Vic Baker
S7 912S Warp 95%
Carson City, Nv
kerrjohna(at)comcast.net Guest
Posted: Sun Nov 04, 2007 5:59 pm Post subject: Broken EGT probe |
Luis, I rely heavily on the relative EGT readings to guide the seasonal changes to the main jets on my 912. I can not imagine flying without. I check it every flight every time I change the throttle setting to be aware of how the engine is operating.
I would recommend going with the westach probe to maintain and "apples" comparison.
John Kerr, approaching 800 hours.
| Quote: | -------------- Original message --------------
.hmmessage P { margin:0px; padding:0px } body.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY:Tahoma } I don't know if this is true or not, but I read someplace that the rotax 912 does not need an EGT, but you do need the CHT, oil temp and oil pressure! I'm no expert!!
Ray
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://f orums. matronics.com/viewtopic.php?p=143849#143849
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! | [b]
wingnut
Posted: Sun Nov 04, 2007 6:18 pm Post subject: Re: Broken EGT probe |
| Quote: | | Interesting topic. Six months ago, when I was designing my panel, I ask Lockwood about EGT. He said "forget that". And so I did. |
I guess things just got more complicated for me then. The gage I have is a combo gage with EGT, Water Temp, Oil Temp and Oil pressure. There's no room in my panel for a new gage so I guess I'd have to find a similar gage with CHT instead of EGT. That's going to pinch a bit more than a new probe. Bummer.
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Nov 04, 2007 7:15 pm Post subject: Broken EGT probe |
Luis,
The water temp is equivalent to the CHT since the cylinders are water
cooled. You are fine. I had the EGT as well, but seldom looked at it. I
didn't have the convenience John has with one on each exhaust stack. My
thought is, and consider that my airplane is sitting in a salvage yard
somewhere. is that rather than having a dead gauge staring you in the face
every flight. I'd pony up for the new sender and then the needle would be
in the proper range on the gauge face. I sure liked the look of all the
needles in the middle of the green. Until the last flight, I mean.
Lowell
john(at)leptron.com Guest
Posted: Sun Nov 04, 2007 8:17 pm Post subject: Broken EGT probe |
Luis I may have a spare probe for the westac, give me a day to look at the
hanger.... its free
John Oakley
Jim Shumaker
Posted: Sun Nov 04, 2007 9:58 pm Post subject: Broken EGT probe |
Luis
The water temperature is the cylinder head temperature. Rotax engines come with a sensor (or two) already installed in the cylinder head. That is correct location to take a temperature reading that you can call a cylinder head reading. There is actually not enough room to install a standard cylinder head temp sensor under the spark plug. When I built my plane, the water temperature gauge was installed in the spyder tank. This is a pretty accurate reading for the water temperature and thus the cylinder head temperature. It is actually more accurate to use the sensor in the cylinder head for those rare instances when the cylinder boils the coolant and then with the sensor in the head you will get a warning of a problem. The instructions that came with the engine (1994 era) actually had the water temp in the spyder and the oil temp in the dry sump. The dry sump oil sensor is a measure of the bypass gases and is not even close to the oil temp so that sensor was relocated. Then an oil cooler had to be installed because the actual oil temps were much higher than recorded in the dry sump. The point is that the water temp sensor you have will be fine, especially if it is connected to the sensor in the cylinder head.
Jim Shumaker
Salinas, CA
Kitfox III, 912ul, 835 hours
_________________ Jim Shumaker |
wingnut
Fox5flyer Guest
Posted: Mon Nov 05, 2007 5:22 am Post subject: Broken EGT probe |
Personally, one can get along without EGT, CHT, oil temp, fuel pressure, oil pressure, fuel flow, and even fuel gauges, but I find them very nice to have for reference. We know what is normal for our airplanes and when any one of them begins to change it gives us early warning that something isn't right.
Deke Morisse
S5, NE Michigan
Float Flyr
Posted: Mon Nov 05, 2007 2:59 pm Post subject: Broken EGT probe |
I would expect both instruments have advantages and are worth having.
CHT tells you how hard your engine is working and when it is working too hard.
EGT tells you how the tune of your engine is. Whether it is too lean or too rich.
Most of the instruments used in amateur built planes really need some calibration and that's where the fun comes in.
The EGT can be calibrated by looking at the spark plugs... Once the plugs are giving a nice tan colouration what ever the EGT has been reading is optimal for you.
When flying you keep an eye on the CHT too. If it unexpectedly starts to climb you may have a problem.... Land and get it checked out. Obviously when you are climbing WOT or close to WOT then you will be generating a bit more heat and you should be able to see this in your CHT. Remember the cylinder heads are liquid cooled so a noticeable increase in CHT can mean a problem with your liquid cooling system.
Personally, a little off topic, I hate idiot lights. Gauges tell the whole story at a glance the thing to remember is not to fixate on the EGT, or any instrument for that matter, and fly de plane! There are few idiot lights on planes, they're called enunciator panels. They will draw your attention to a problem. The gauges will tell the story of the problem. I once had someone take the oil light out of a car because it was glaring in their eyes. The engine ran through a ten hour road rally with no oil in the base. Some how I didn't lose the engine!
[img]cid:207294722(at)05112007-079B[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
19.77 KB |
422 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Mon Nov 05, 2007 3:11 pm Post subject: Broken EGT probe |
In your case the Water Temp is your cylinder head temp.... The hear is
liquid (water) cooled. Temp is the temp of the liquid leaving the heads.
Noel
[quote] --
Kitfox III-A
wingnut
Posted: Mon Nov 05, 2007 5:05 pm Post subject: Re: Broken EGT probe |
One issue I've always had with the EGT readings is that during normal cruise on a cold day, it normally reads near the top of the gage (around 1450). The gage only reads to 1500 so there's not much movement there for me to pick out a problem. Is this consistent with what others are reading?
| Quote: | | When flying you keep an eye on the CHT too. If it unexpectedly starts to climb you may have a problem.... Land and get it checked out. Obviously when you are climbing WOT or close to WOT then you will be generating a bit more heat and you should be able to see this in your CHT. Remember the cylinder heads are liquid cooled so a noticeable increase in CHT can mean a problem with your liquid cooling system. |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
