Oil Access Door
Jaybannist(at)cs.com
PostPosted: Sat Nov 03, 2007 6:02 pm    Post subject: Oil Access Door Reply with quote
I am now contemplating the access door to get to the dip stick on my 601XL with WW Corvair engine. I have some ideas, but I would like to see what others have done, learn from your experience and maybe get it right the first time. I've had enough "do-overs" already, thank you.
Jay in Dallas
craig(at)craigandjean.com
PostPosted: Sat Nov 03, 2007 6:32 pm    Post subject: Oil Access Door Reply with quote
What's wrong with William Wynne's standard cowling? Four quarter-turn
fasteners release the top right cover which exposes the dip stick. Pictures
attached of William's tail-dragger. Somebody (Bill Clapp?) bent his and
brought it out through the hole in the cowl. But I bet the standard
alternator position might block that.
-- Craig
 Filesize:  118.36 KB
 Viewed:  505 Time(s)
 Filesize:  106 KB
 Viewed:  526 Time(s)
larry(at)macsmachine.com
PostPosted: Sun Nov 04, 2007 8:26 am    Post subject: Oil Access Door Reply with quote
Hi Jay,
I put in a door that's easy to make for the fiberglass cowling. Using
fine jigsaw blades in an Exacto blade holder, you can manually cut a
very fine door
from the cowl itself and then remount it on a frame plate and hinge with
Dzus fasteners. See link,
http://www.macsmachine.com/images/cowling/full/cowlaccessbaseplate2.gif
http://www.macsmachine.com/images/cowling/full/cowloilaccess2.gif
http://www.macsmachine.com/images/cowling/full/cowloilaccessopen2.gif
http://www.macsmachine.com/images/completion/full/601ezfrontright.gif
Good luck,
Jay in Dallas
Gig Giacona
PostPosted: Mon Nov 05, 2007 7:42 am    Post subject: Re: Oil Access Door Reply with quote
I'm with Craig on this one. The WW cowling really doesn't need another hole in it.
Jay in Dallas
W.R. "Gig" Giacona
601XL Under Construction
