pbesing(at)yahoo.com Guest
Posted: Sun Oct 28, 2007 5:14 pm Post subject: Prop Mounting-clocking |
Posted: Sun Oct 28, 2007 5:20 pm Post subject: Prop Mounting-clocking |
Must be a secret society!
Linn
Paul Besing wrote:
[quote] [b]
d-burton(at)comcast.net Guest
Posted: Sun Oct 28, 2007 5:34 pm Post subject: Prop Mounting-clocking |
This message was very strange. I have a preview feature on my computer that lets me see incoming messages superimposed over the screen I’m working on. Paul’s question was there on the preview screen but empty here. I don’t get it…
Dave
RV6
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing
Sent: Sunday, October 28, 2007 6:14 PM
To: rv-list(at)matronics.com
Subject: Prop Mounting-clocking
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
retasker(at)optonline.net Guest
Posted: Sun Oct 28, 2007 6:04 pm Post subject: Prop Mounting-clocking |
For what it's worth the same thing happened to me.
Dick
David Burton wrote:
Dave
RV6
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Paul Besing
*Sent:* Sunday, October 28, 2007 6:14 PM
*To:* rv-list(at)matronics.com
*Subject:* Prop Mounting-clocking
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
matronics(at)cencula.com Guest
Posted: Sun Oct 28, 2007 6:27 pm Post subject: Prop Mounting-clocking |
The message didn't show up in Thunderbird, but in Kontact it does. Anyway,
here's his question:
On Sunday October 28 2007 09:13:49 pm Paul Besing wrote:
| Quote: | Ok, silly question...my prop needs to be re mounted and I can't for the
life of me remember which position it looks like when stopped..when looking
at it from the cockpit, is the high blade on the left or right? i.e. the
blade you can see should be in the 10:00 or 2:00 position when viewed from
the cockpit?
Thanks.
Paul Besing
Posted: Sun Oct 28, 2007 6:34 pm Post subject: Prop Mounting-clocking |
Ok..try it again..here goes.
Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit?
Thanks.
Paul Besing
acepilot(at)bloomer.net Guest
Posted: Sun Oct 28, 2007 6:37 pm Post subject: Prop Mounting-clocking |
Mine is on the right (2 O'Clock) as I look out the windshield. An easy
way is to stand in front of the plane like you are going to hand prop.
Which feels the best?
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Michael D. Cencula wrote:
>the cockpit?
>Thanks.
>Paul Besing
>__________________________________________________
kboatright1(at)comcast.ne Guest
Posted: Sun Oct 28, 2007 6:46 pm Post subject: Prop Mounting-clocking |
Mine (and most I see) stop at the 2:00 position as seen from the cockpit. This is convenient for hand propping if you're so inclined.
KB
Posted: Sun Oct 28, 2007 8:20 pm Post subject: Prop Mounting-clocking |
FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop. It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC. With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks.
Linn
Paul Besing wrote:
[quote] Ok..try it again..here goes.
Thanks.
Paul Besing
----- Original Message ----
From: Paul Besing <pbesing(at)yahoo.com> (pbesing(at)yahoo.com)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Sunday, October 28, 2007 6:13:49 PM
aerobubba(at)earthlink.ne Guest
Posted: Mon Oct 29, 2007 5:10 am Post subject: Prop Mounting-clocking |
Linn-
| Quote: | FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop
prop.
I though you had a Pitts, not a Moth....
glen matejcek
aerobubba(at)earthlink.net
Posted: Mon Oct 29, 2007 8:09 am Post subject: Prop Mounting-clocking |
Ok, there is a vote for each...any one care to make a tie breaker?
Paul Besing
dougpflyrv(at)aol.com Guest
Posted: Mon Oct 29, 2007 9:03 am Post subject: Prop Mounting-clocking |
2 o'clock viewd from the cockpit
dp
sbuc(at)hiwaay.net Guest
Posted: Mon Oct 29, 2007 9:07 am Post subject: Prop Mounting-clocking |
Paul Besing wrote:
| Quote: | Ok, there is a vote for each...any one care to make a tie breaker?
Paul Besing
Paul, the high blade will be at the 2:00 position when viewed from the
cockpit (10:00 when facing the prop during a hand-start).
Sam Buchanan
Paul Besing
Sam Buchanan
27.96 KB |
462 Time(s) |
n616tb(at)btsapps.com Guest
Posted: Mon Oct 29, 2007 9:10 am Post subject: Prop Mounting-clocking |
Ok I vote 2:00 when viewed from the cockpit. In these planes you prop from the right side and want the prop up on that side. That said, I have never needed to prop my plane but am used to seeing it in this position.
Sent: Monday, October 29, 2007 10:09 AM
Subject: Re: Prop Mounting-clocking
Paul Besing
n5lp(at)warpdriveonline.c Guest
Posted: Mon Oct 29, 2007 9:11 am Post subject: Prop Mounting-clocking |
Paul,
It's 2:00 viewed from the cockpit. I've propped many airplanes and
that has always been the orientation. I can't imagine trying to prop
one by somehow twisting my body and flipping up on the prop.
The prop usually stops between compressions so as you pull down on
the prop you will be going though a compression, which is what you
want. The impulse coupler works on each and every compression.
Larry Pardue
Carlsbad, NM
http://n5lp.net
On Oct 29, 2007, at 10:09 AM, Paul Besing wrote:
[quote] Ok, there is a vote for each...any one care to make a tie breaker?
Paul Besing
kahuna
Posted: Mon Oct 29, 2007 9:13 am Post subject: Prop Mounting-clocking |
Its 2.
[img]cid:1__=08BBF910DFCD05B88f9e8a93df938(at)us.ibm.com[/img]Paul Besing <pbesing(at)yahoo.com>
[img]cid:3__=08BBF910DFCD05B88f9e8a93df938(at)us.ibm.com[/img]
To
rv-list(at)matronics.com [img]cid:3__=08BBF910DFCD05B88f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Re: Prop Mounting-clocking [img]cid:3__=08BBF910DFCD05B88f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBF910DFCD05B88f9e8a93df938(at)us.ibm.com[/img]
Paul Besing
105 Bytes |
9500 Time(s) |
1.23 KB |
9501 Time(s) |
45 Bytes |
9501 Time(s) |
Posted: Mon Oct 29, 2007 10:16 am Post subject: Prop Mounting-clocking |
Got it thanks folks...one of those things I just couldn't picture, because I've seen both, but couldn't remember what was "normal".
Paul Besing
Posted: Mon Oct 29, 2007 7:55 pm Post subject: Prop Mounting-clocking |
glen matejcek wrote:
| Quote: | | Quote: | --> RV-List message posted by: "glen matejcek" <aerobubba(at)earthlink.net> (aerobubba(at)earthlink.net)
Linn-
prop.
I though you had a Pitts, not a Moth.... | | I do ....and for the first 13 years I hand propped it before I got smart and put a battery and starter in it. The clue is 'rising blade' that you didn't quote! ....at least I think I said that! When you pull the 2:00 blade CCW, the impulse will fire when that blade is at 8:00 on the down stroke.
Linn
[quote] [b]
