PFolbrecht(at)starkinvest Guest
Posted: Mon Feb 20, 2006 11:29 am Post subject: Opinions on antenae in VS |
I'm about to close up my VS and need to decide if there's anything I want to put in there.
I know I don't want a strobe there but have been thinking about antenae. However, since it looks like my 9A will be light up front (320 with Catto prop and RG batt), and I didn't do the "optional" lightening holes in the VS spar, I think I want to avoid any unneccessary weight in the VS at all. Many people seem to do the nav & com in the wingtips which seems to work well.
So, those are my thoughts now, but if someone would like to tell me differently I would like to hear it. Thank you.
Paul
9A QB #1176
luckymacy(at)comcast.net Guest
Posted: Mon Feb 20, 2006 11:51 am Post subject: Opinions on antenae in VS |
a bullet (aka lipstick or spy) camera in the vertical stab fiberglass tip is a cool option. You'll want to make the fiberglass tip removable and as an option you might want to run some wire or string down between the two forward tooling holes you will have to open up to pass the stab cam cables through. No big deal. Just makes life a teensy bit easier later on.
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
in there.
Paul
9A QB #1176
a bullet (aka lipstick or spy)camera in the vertical stab fiberglass tip is a cool option. You'll want to make the fiberglass tip removable and as an option you might want to run some wire or string down between the two forward tooling holes you will have to open up to pass the stab cam cables through. No big deal. Just makes life a teensy bit easier later on.
From: "Folbrecht, Paul" PFolbrecht(at)starkinvestments.com
-- RV-List message posted by: "Folbrecht, Paul"
<PFOLBRECHT(at)STARKINVESTMENTS.COM>
in there.
seem to do the nav com in the wingtips which seems to work well.
t. Thank you.
Paul
9A QB #1176
ronlee(at)pcisys.net Guest
Posted: Mon Feb 20, 2006 1:53 pm Post subject: Opinions on antenae in VS |
| Quote: | Many people seem to do the nav & com in the wingtips which seems to work
well.
I am not sure I have heard of people happy with wingtip comm antenna.
VOR yes.
Ron Lee
william(at)gbta.net Guest
Posted: Mon Feb 20, 2006 7:02 pm Post subject: Opinions on antenae in VS |
My VS on my -10 will have a cats whisker VOR/ILS/GS antenna on the top of
it.
Bill Britton
RV-10 Tailcone
#40137
George McNutt
Posted: Mon Feb 20, 2006 8:46 pm Post subject: Opinions on antenae in VS |
Folbrecht, Paul wrote:
| Quote: | I'm about to close up my VS and need to decide if there's anything I want to put in there.
Paul
You'll want to make the H/S fiberglass tip removable and open up the two forward tooling holes and put snap bushings in them, then you can add anything you want at a later date.
George in Langley BC
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Tue Feb 21, 2006 12:01 am Post subject: Opinions on antenae in VS |
I have acquired an active helical GPS antenna I plan to put under the VS radome.
See:
http://www.sarantel.com/products/#s
Doug Gray
Paul
9A QB #1176
Posted: Tue Feb 21, 2006 11:30 am Post subject: Opinions on antenae in VS |
Have to ask - why not hide it?
You are right.
It is pushing 1 yr now since I did my elec. system planning and details
are getting fuzzy. I should have taken better notes. It was prelim,
and I knew I'd revisit everything.
Posted: Wed Feb 22, 2006 4:13 pm Post subject: Opinions on antenae in VS |
The original builder installed it in the VS and he had to cut notches in the
sides of the skin on the top (small notches) where the antenna will exit. I
could probably cover the notches and change it's location but just am not to
that point yet.
