Tom Jones
Posted: Sat Oct 27, 2007 7:20 am Post subject: Doors open |
Do you need a limit strap of some sort on the kitfox doors when flying with them open? My doors are close to the wing bottom when open and the door struts seem kind of light weight to hold much force. I'm near the end of phase one testing and would like to test with my door open now.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Michel
Posted: Sat Oct 27, 2007 9:44 am Post subject: Doors open |
| Quote: | From: Tom Jones [nahsikhs(at)elltel.net]
with them open?
It's difficult to say, Tom, because the Kitfox is a homebuilt aircraft and there are not two built the same. Basically, it depends on how the door takes the wind and I believe a slight difference in their shape may cause a totally different behaviour. Maybe you should wait to try yours with a passenger and see how it goes.
With my model 3, opening and closing the doors in flight is extremely simple and doesn't require any force at all. Furthermore, even if the opened door is close to the wing, I have not noticed any effect on the flight characteristics when open. I have landed with open doors and the plane behaved as if they were closed. But that's my plane. Test carefully how yours work.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
dave
Posted: Sat Oct 27, 2007 11:51 am Post subject: Re: Doors open |
Tom,
I don't have door strut or cables on my IV . I fly with they open lots.
No issues
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Malcolmbru(at)aol.com Guest
Posted: Sat Oct 27, 2007 6:07 pm Post subject: Doors open |
are you flying a 4 with a 503? how much douse the plane weigh? my mod 2 is 538 lb. my only open door flight was when the passenger door opening on take off. it got real windy in there a couple of times.malcolm
Float Flyr
Posted: Sat Oct 27, 2007 6:51 pm Post subject: Doors open |
My limit straps are close to twenty feet long. (wings) the only problem I ever had with the doors open was on the very first day when a little bit of an uncontrolled turn looked enough like a slip to the door to cause it to come down quickly. If you want to breeze and slip the 'fox take the doors off first... It only takes a minute or so.
[img]cid:888283202(at)28102007-0BBE[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
19.77 KB |
496 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
What Michel said on Aerocet 1100 straight floats.
BTW the spray when landing ( close to glassy water) doesn't get into the
cabin but sounds fantastic!
Noel
[quote] --
Kitfox III-A
Tom Jones
Posted: Sat Oct 27, 2007 7:11 pm Post subject: Re: Doors open |
| Quote: | | are you flying a 4 with a 503? how much douse the plane weigh?� my mod 2 is 538 lb. my only open door flight was when the passenger door opening on take off. |
Malcolm, yes a 503 in a classic 4. See pictures attached. It weighs 546 and I weigh 160.
| Quote: | | If you want to breeze and slip the 'fox take the doors off first... It only takes a minute or so. |
Noel, I will probably take the doors off in the summer. When the doors are on I would like to open mine to take pictures.
898.97 KB |
561 Time(s) |
Classic IV
Ellensburg, WA |
Float Flyr
Posted: Sat Oct 27, 2007 8:22 pm Post subject: Doors open |
I've done both, opened the doors on occasion and taken them off at other
times (10 - 15 min). My flight instructor wouldn't let me fly the C172
without the doors even though it was certified to do so.
Noel
[quote] --
Kitfox III-A
dave
Posted: Sun Oct 28, 2007 2:30 am Post subject: Re: Doors open |
| Quote: | | are you flying a 4 with a 503? how much douse the plane weigh?? my mod 2 is 538 lb. my only open door flight was when the passenger door opening on take off. it got real windy in there a couple of times.malcolm |
my IV is about 550 and done one or two doors open or closed -- take offs , landing.
Fox5flyer Guest
Posted: Sun Oct 28, 2007 3:00 am Post subject: Doors open |
Nice install Tom. Looks great!
Deke
S5, NE Michigan
