Avid Builder
falcon43
PostPosted: Fri Oct 26, 2007 7:56 pm    Post subject: Avid Builder Reply with quote
Kitfox Group: I am a Avid Builder learning a lot from the kitfox group
discussions. Are avid builders welcome as we really are much the same
aircraft but do not have the same great support system as the kitfox people.
Harry Cieslar, Ontario, Canada , Avid Magnum Project
MichaelGibbs(at)cox.net
PostPosted: Fri Oct 26, 2007 8:07 pm    Post subject: Avid Builder Reply with quote
Harry sez:
group discussions. Are avid builders welcome as we really are much
the same aircraft but do not have the same great support system as
the kitfox people.
Absolutely you are welcome, Harry. Avids and Kitfoxes have a common
ancestor (that wasn't called "Kitfox" Smile
Mike G.
Kitfox List Admin
N728KF
Phoenix, AZ
john(at)leptron.com
PostPosted: Fri Oct 26, 2007 8:43 pm    Post subject: Avid Builder Reply with quote
Harry,
Welcome to the list, you are an important new member. Not only will you get
good help, stories and information but you will be able to help others with
the experience you will and have gained.
John Oakley
Model 4 speedster
912ul cap
Over 1100 hours in kitfox's
Float Flyr
PostPosted: Sat Oct 27, 2007 5:50 pm    Post subject: Avid Builder Reply with quote
Harry:
As you say the kitfox and the avid are virtually the same aircraft... Yes they are a few differences but they were both designed by the same guy.
There is an Avid group on yahoo groups and they are pretty active... I'm a kitfox owner and I'm reasonably active on that group too. Actually several of the guys on this list are also on the Avid list.
You will find that topics do not tend to echo through the two groups. This is because all the guys are pilots or builders sand it is whatever is concerning them at the minute that you will see posted. Every conceivable engine / prop set up is represented on both groups but it is good sometimes to get opinions from both groups.
This list tends to support Mr. John Mc Bean, Kitfox LLC., because he provides the support for all the different parts of the kitfox. The Avid list tends to support Steve Winder of Airdale, because he provides the special Avid parts when needed. Both gentlemen have similar backgrounds. I am pleased to say I think both gentlemen are good guys.
Now that that is said....Welcome aboard!
[img]cid:253083701(at)28102007-0BB0[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  486 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
kitfox(at)ida.net
PostPosted: Sat Oct 27, 2007 11:17 pm    Post subject: Avid Builder Reply with quote
The opinion with me is welcom aboard, all of you.
Albert
5TD NSI,Cap
