Finger Strainer
mritter509(at)msn.com
PostPosted: Thu Oct 25, 2007 2:17 pm    Post subject: Finger Strainer Reply with quote
After 150 hours the finger strainer in the right tank sprung a leak. Removed the fitting, cleaned the threads, applied fuelube and reinstalled. Still leaked. Put in new fitting and the leaked stopped. Go figure.
I was getting a faint wiff of avgas in the cabin that caused me to investigate. Found fuel stains on the bottom right wing fairing. After draining the right tank we place a balloon on the fuel vent line and put air in the tank via the fuel drain fitting. We then put liquid soap where we believed the leak was and found bubbles around the finger strainer.
Mark
RV-10/N410MR
<html><div></div></html>
Boo! Scare away worms, viruses and so much more! Try Windowsrial.aspx?s_cid=wl_hotmailnews' target='_new'>Try now! [quote][b]
Tim Olson
PostPosted: Thu Oct 25, 2007 5:06 pm    Post subject: Finger Strainer Reply with quote
I've seen brass valves and NPT fittings fail getting hairline
cracks in them pretty easily before. Probably was caused
just during torquing initially, as I know those finger strainers
can be a pain to tighten...then finally with the tension
on it, it finally made a hairline crack. That's great that you
found it and did all the right things diagnosing. You probably
won't have an issue again I'd bet.
stopped. Go figure.
strainer.
Mark
RV-10/N410MR
<html><div></div>
AV8ORJWC
PostPosted: Thu Oct 25, 2007 5:28 pm    Post subject: Finger Strainer Reply with quote
Incorrect Torque values and improper torqueing techniques contribute to
more problems than you can imagine. Good N' Tight sure has a price in
terms of damage in an aircraft environment. All of this is often
glossed over when reading the AC43.13 until a problem becomes apparent
after the damage was done on initial torqueing.
Be sure to use installation techniques which allow for regular and easy
inspection. Use materials which do not contribute to toxic fumes or
dissolve in the presence of AVGAS staining. Know the materials you are
using help the solution and don't amplify a potential problem.
John Cox - N49CX - Dreaming of flying like the Olson Clan
