Andair Fuel Valve - current sources?
MauleDriver(at)nc.rr.com
PostPosted: Thu Oct 25, 2007 2:49 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
I've been reading the archives and otherwise trying to figure out a good
approach to replacing the stock valve. Generally seems like a good
idea. But many options exist and several approaches taken.
Purchasing the valve - direct from the factory I can get exactly what I
want in a few weeks if I only knew for sure
- Vans but with a fuel return and
possibly other options not needed for the IO540
- Neal?
I think I can cobble together an order or select an available valve
after some more research but I'd welcome recommendations. Seems like
everyone learned something after they made their decisions that would
point to some modification if doing it again.
I've seen Tim's and Deem's pages (Thanks again!) and the Aeroquip
hoses sound great. Anyone else have photos.
Bill "switching tasks everyday but with great joy" Watson
Durham NC
#40605
Tim Olson
PostPosted: Thu Oct 25, 2007 3:08 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
I'd start with Neal first, and see what he can do. Then, if that
fails, just go straight to Andair and take the pain, but do a web
order for what you need. Order a foot of the valve extension
material. Once you figure what valve you need, and the
fittings on it, and get the extension, the rest isn't really
too bad to figure out on your own with the parts in your
hands.
- Neal?
Durham NC
#40605
LloydDR(at)wernerco.com
PostPosted: Thu Oct 25, 2007 5:18 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
I agree with Tim, this is exactly how I did it, even though I needed a
duplex valve with the return lines. I called Neal and he said to go
direct for the duplex valves and extensions. One caveat though is that
if you want two 90's so you can come in from each wing root without
crossing you will want Andairs new 90 degree elbow built in, they are on
the accessory page and you will have to call to get them rather than
just using the auto configure tool. If you go the auto configure route
you have to use two females and put in two 90 degree elbows and this
makes the valve to wide to fit in the tunnel, but if you use their new
built in fitting they fit with plenty of room left over.
Dan
N289DT RV10E flying
PostPosted: Thu Oct 25, 2007 8:20 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
I've been running the auto-configure tool and it looks like they added
the 90deg elbows to it. So what I end up with is (2) built in 90deg
elbows, exiting the FS20x7 at 45deg angle forward, then with end of the
elbow angling 45 deg rearward. It still sticks out a ways, so I'm
going down to check the clearance now.
I'm thinking that the custom version that ZackRv8 posted pictures of
where the 90deg elbows are pointing downward along with the feed line to
the engine might be optimal from a width perspective. But the depth
issue is not clear to me at all yet. With the extension, I understand
you want it low enough to allow the 2" SCAT to fit on top, and I guess
high enough not to interfere with the elevator pushrod and stuff. Just
not clear on the total picture yet.
Dan
N289DT RV10E flying
Tim Olson
PostPosted: Thu Oct 25, 2007 9:03 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
Surprisingly, I didn't find clearance to be an issue with the elevator
pushrod stuff. Having it down low enough for the SCAT tubing is
very nice though.
> <LloydDR(at)wernerco.com>
> Dan
> N289DT RV10E flying
n8zg(at)bellsouth.net
PostPosted: Thu Oct 25, 2007 4:44 pm    Post subject: Andair Fuel Valve - current sources? Reply with quote
Weeeell...dernit....what's a feller to do.
For the record - I was selling valves at my cost as a service to our
community. I quit handling Andair products because Van's started selling
valves cheaper than I could buy them, and I had to eat a case of $225
valves.
I'd like nothing more than to renew my relationship with Andair. In the
last week I've had enough inquiries to warrant consideration. Ultimately,
it's up to y'all. I haven't checked lately, but given the current exchange
rate, I expect base valves are going to run upwards of $240. Extensions add
about $75. Tack on international shipping (not cheap) and USPS ($6) - last
time I ordered, it cost me over $100 to ship a shoe box full of valves from
England to Alabama.
I'll need to place orders of AT LEAST 12 units at a time to make it worth
Andy's trouble.
If y'all are willing:
I'll handle ONE valve style - FS20X7-T.
I'll try to keep a few extension kits and extra inlet fittings on hand.
If our rotary or Sube friends want duplex valves, we'll work that out, too.
IT WILL NOT BE FAST - but you WILL get what you asked for.
The price WILL fluctuate with the exchange rate.
I have no intention or interest in making a buck off of this offer. Valves
will cost you a few pennies more that it costs me to drop one at the Post
Office. (Meaning, that if it costs me $200 to buy the valve, $120 to ship a
dozen from England, and $6.50 to put a stamp on it, I'll ask for $220.
Insurance costs a little more, UPS costs a lot more.)
I'll contact Andair in the next few days and see what we can work out.
In the mean time, if you'd like an Andair FS20X7-T valve, send a note direct
to ( neal at appaero.com ). If you want an extension, say so. Be prepared
to write a check - I simply don't have the cash on hand to front a $3000+
order.
Neal E. George
2023 Everglades Drive
Navarre, FL 32566
Home - 850-515-0640
Cell - 850-218-4838
PostPosted: Thu Oct 25, 2007 6:54 pm    Post subject: Andair Fuel Valve - current sources? Reply with quote
Well Neal, if you do it, we will come.
However, I think the critical element is a well documented installation
diagram using the specific valve configuration (FS20X7-T) you would be
selling.
As you know, I'm one of the people fishing around for an Andair valve.
I just configured and ordered a:
EFS20b7T,3/8 Type 7 Extension Fuel Selector :,6 Inch Ext. Tube (at) gbp
195.99 = gbp 195.99
My order is based on the best solution I could come up with based on
input from several people on the site (sort of including you). The
input made it clear that several people have used different
configurations to support different installations with varying degrees
of, but eventual success. If someone had a well documented successful
installation with a specific valve configuration and you offered it, I
would be all over it. And I would guess that many of those builders
coming behind me would do the same.
Philosophy switch on: Homebuilding gives so many things to so many
people. You can design an aircraft from scratch, you can build one
from plans and create your own, personal version of someone's dream you
can build from a materials kit and learn in-depth building skills, you
can do a quick build kit and ..... etc. I consider my RV10 project to
be an effort to build a build a $500K aircraft for $150K and a lot of
sweat equity. The final result will be a state of the art 4 place
personal transportation machine that will be so satisfying to operate
that I pinching myself while writing this. But in building this dream
machine, I'm trying to take maximum advantage of the QB offeriing,
standard powerplant, and off-the-shelf avionics. And in the same vein,
I'm looking for every bit of help I can get in solving all of the
little design and fabrication challenges inherent in this, perhaps the
most evolved homebuilt design available. There's pride in solving some
of these problems personally. But the greatest pride is in just
completing the project with all personal transportation goals achieved.
Give me a good solution and a product to go with it, I'm buying it.
Philosophy switch off.
In the meantime, I'm puttering around in the Maule doing just fine while
dreaming of doing so much better. Nice writeup Tim!
valves.
England to Alabama.
Andy's trouble.
order.
Neal E. George
Navarre, FL 32566
Home - 850-515-0640
Cell - 850-218-4838
hotwheels
PostPosted: Fri Oct 26, 2007 6:51 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
Neal was good to me. Don't forget to order the extension kit!
There are several Andair install photos under the "Fuse" link here:
http://www.brinkmeyers.net/AirplaneBuilding.htm
Jay
___________________________[quote][b]
PostPosted: Fri Oct 26, 2007 8:20 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
Thanks Jay. Those pics are a lot of help. I canceled my order pending
a bit more research into configuration and availability.
I intend to configure the same model you installed. It appears to be
the same one that Neal sold and recommends.
It looks like 6" of extension is more than enough. Do you agree?
Is that the extension with the universal joint? Or just a straight
extension? (I'm thinking <6" straight extension w/o ujoint is what I need)
I'm going to check with A/C Spruce and Vans regarding their stock to see
if they have the configuration that Neal was selling including the
extension. If not, I'm going back to Andair....
.. unless Neal decides to try another batch buy. No urgent hurry here,
I realize it may take weeks. So I can join in if Neal decides to do it.
Bill "jumping from brakes, rudders and fuel lines" Watson
Durham NC - #40605
Jay
wcurtis(at)nerv10.com
PostPosted: Fri Oct 26, 2007 10:26 am    Post subject: Andair Fuel Valve - current sources? Reply with quote
Bill,
Why don't you just order the FS 20X7T that Van's offers for $205? 90 degree swing between left and right and 90 degree AN6 ports. Seems almost a drop in replacement, only you don't have to criss-cross the fuel lines. You don't even have to lower it and use an extension.
See it here or search for :Fuel Selector Valves":
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1193417645-34-690&browse=airframe&product=fuel-selector-valve
William
http://wcurtis.nerv10.com/
PostPosted: Fri Oct 26, 2007 3:16 pm    Post subject: Andair Fuel Valve - current sources? Reply with quote
William, I was looking at that and talked to them. I'm right now of the
opinion that I want the extension and that I want to lower the valve
body 4 or 5 inches. That gives the SCAT tubing a clear run and seems to
avoid any rudder cable, fuel line interference.
The FS20X7T at Vans is a GREAT price and except for the extension, the
right valve. It is basically a drop-in replace for the kit supplied
valve but people seemed to have struggled a bit with the SCAT and rudder
cable. I thought that I might be able to pick the valve up from Spruce
and an extension from ACSpruce. But Spruce indicates that they only
sell the extension with a valve. The Andair site makes it clear there
is an A and B type valve - only the B will accept the extension. And,
adding an extension to a B is a bit more than just inserting a piece of
rod. Andair will sell an extension kit for a B model but by the time
you get done, you are within $75 of just ordering the whole thing from
the factory.
I'm agonizing here a bit but the recently reported problems with the kit
valve pushed me over the edge to get the Andair. And once there, I'm
trying to get it as right as I can without recreating the same problems
others have had.
The frugal decision seems to be to use the kit valve
The crafty decision would be to get the Vans valve and solve the minor
tunnel space issues
The do it as right as I can figure and damn the cost decision seems to
be just order the thing from the factory.
Did someone say 'budget'?
William Curtis wrote:
Bill,
William
PostPosted: Fri Oct 26, 2007 4:07 pm    Post subject: Andair Fuel Valve - current sources? Reply with quote
Seems the path of least resistance is to use the Vans offering and route the rear cabin heat via the original path. With the input fuel lines 90 degrees apart and the center output port, you should also be able to route the rear heater cable through those lines also as an option.
William
 Filesize:  180.3 KB
 Viewed:  481 Time(s)
Tim Olson
PostPosted: Fri Oct 26, 2007 5:18 pm    Post subject: Andair Fuel Valve - current sources? Reply with quote
Bill,
Don't sweat it too hard. The valve was something that I originally
reworked and wanted better. The FS20X7T valve should be an easy
one to fit, and the other andair valve, even with it's tight clearance
to the rudder cables isn't all that bad to fit either. Once you get
the parts, you'll see that it really isn't a big deal at all, and
that it should go together very well. Heck, you've even FLOWN
in a plane with the whole andair valve installed....so you even get
the ease of mind to know that it indeed works. Once you get the parts,
and stuff them in, it'll be just like all the problems when you first
started the empennage....all a thing of the past.
It's just...a...valve, and it's a very nice valve, with very good
positive detents and prevention from accidentally turning it off.
No, it's not the cheapest solution, but of the choices you have, I
believe firmly that it's the best solution, even if others are fine
too. The Cirrus uses that valve too, from what I understand. A couple
months from now you'll look back and laugh that you even stressed
that much. I know how you feel...ever time I had to make a choice
that I thought was huge, I sweated every detail. In the end, yeah,
it paid off, but I sure wasted a lot of time on it. You have the luck
of being able to have many examples to look at of people ahead of you.
I think you'll be happy in the end, knowing you got the best in
fuel valve safety you could do. Plumbing it will not be a big
deal at all....especially if you use flexible lines. Those are
another item I really like how they turned out.
It's too bad you can't be here during inspection time to put your
hands on all these things and see how it all goes together, but
again, you'll be happy in the end.
You may need to come on over for another shot of "motivation" by
burning some 100LL. Wink
the factory.
others have had.
tunnel space issues
> Bill,
> William
capsteve
PostPosted: Fri Oct 26, 2007 7:33 pm    Post subject: Andair Fuel Valve - current sources? Reply with quote
I purchased my valve from Neal and thankfully he knew all the parts that
were needed for the extension. I probably would have ended up ordering crap
I didn't need. I attached I pic of my extension setup.
Steven dinieri
Iflyrv10.com
capsteve(at)adelphia.net
716.579.5790
opinion that I want the extension and that I want to lower the valve body 4
or 5 inches. That gives the SCAT tubing a clear run and seems to avoid any
The FS20X7T at Vans is a GREAT price and except for the extension, the right
valve. It is basically a drop-in replace for the kit supplied valve but
people seemed to have struggled a bit with the SCAT and rudder cable. I
thought that I might be able to pick the valve up from Spruce and an
extension from ACSpruce. But Spruce indicates that they only sell the
extension with a valve. The Andair site makes it clear there is an A and B
type valve - only the B will accept the extension. And, adding an extension
to a B is a bit more than just inserting a piece of rod. Andair will sell
an extension kit for a B model but by the time you get done, you are within
$75 of just ordering the whole thing from the factory.
valve pushed me over the edge to get the Andair. And once there, I'm trying
to get it as right as I can without recreating the same problems others have
had.
The frugal decision seems to be to use the kit valve The crafty decision
would be to get the Vans valve and solve the minor tunnel space issues The
do it as right as I can figure and damn the cost decision seems to be just
 Filesize:  44.06 KB
 Viewed:  430 Time(s)
