| wild.blue(at)verizon.net Guest
				|  Posted: Wed Feb 22, 2006 10:38 am    Post subject: cold weather starts |   |
				| Gents--
 Here in the wet PNW it seldom gets below freezing, but I have found that
 preheat does indeed help starting, even if its 40F or even 50F outside. Len
 Cunningham (Cunningham Aircraft Covers) has made several insulated cowling
 covers for me for both CJ's and 52's. I highly recommend them--and he has
 patterns for making more. They are made of heavy nylon type material,
 heavily insulated (and look like they could double as sleeping bags),
 completely enclose the cowling and have exhaust outlet openings so you can
 hang your favorite collection device outside the cover and keep things clean
 The covers are pulled tight with draw strings so you can insert a duct from
 your heat source anywhere you want to keep things toasty.  Nothin' like a
 nice warm engine and oil for starting in cold weather.
 Electric sump heaters are also useful and can be attached to the oil tank,
 though I prefer to heat the entire engine along with the oil.
 Jelled kerosene/gasoline and Primus stoves have burned down lots of
 airplanes--be careful out there!
 It's also important to build some head pressure on the fuel line to the
 carburetor--wobble, wobble wobble--before you start cranking. No pressure
 and the fire will go out before it builds enough to sustain operation. Yes,
 pumping the throttle or the primer (after it's running) will help keep it
 running, but you gotta have that pressure first.
 Finally, "blubbering" is often the result of not locking the primer after
 start. Fuel will go past the primer and richen the mixture, just enough to
 cause a little perplexing roughness.
 Jerry Painter
 Wild Blue Aviation
 425-876-0865
 http://mysite.verizon.net/res0cs5r/index.html
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
