johnd(at)data-tech.com Guest
Posted: Tue Oct 23, 2007 12:18 pm Post subject: Jab Dual Throttle Setup issue |
Hi All,
I just got my dual throttle setup installed per the Jabiru USA
instructions and have an issue with the roughness in throttle movement
when the throttles are firewalled. The throttle cable has to bend when
its firewalled as the arms on the bar mounted on the firewall shelf tilt
down in this position and this causes alot of stiffness and roughness
when pushing the throttles that far in. I havent hooked up the middle
cable to the carby yet so this friction is just from the two throttle
cables.
Any suggestions for improving the movement here ? Can I just grease the
cables ?
John Davis
Burnsville, NC
601XL - Jab 3300
Posted: Tue Oct 23, 2007 2:45 pm Post subject: Jab Dual Throttle Setup issue |
John,
I had the same difficulty with the cable end moving around a radius and
resolved most of it by adding a link
that stays straight with the cable but allows the link full travel.
You'll have to study the linkage shown in
the image below. This will leave you with a much smaller amount of sweep
thru the firewall and you'll be less
likely to break the end fitting.
http://www.macsmachine.com/images/controllinkages/full/throttlelink.gif
John Davis wrote:
Hi All,
tilt down in this position and this causes alot of stiffness and
roughness when pushing the throttles that far in. I havent hooked up
the middle cable to the carby yet so this friction is just from the
two throttle cables.
the cables ?
John Davis
Burnsville, NC
601XL - Jab 3300
rge177(at)yahoo.com Guest
Posted: Thu Oct 25, 2007 3:31 pm Post subject: Jab Dual Throttle Setup issue |
John,
I had the same problem. I did grease mine, and
that helped a little. The heavy wire inside the dual
throttle cable housings, tends to want to curl in one
direction, and it helps to rotate the cable inside the
housing so that it curls the way you need it to
deflect. I ended up extending the center leg on the
bellcrank about an inch, and mounted a bracket to hold
the center cable adjuster on the front of the shelf.
Now the dual throttle handles only have to travel
about 2", and this gives me the needed 2 1/2" travel
at the carby and eliminated the rough spot in my
throttle. I still have just a little more friction
than I would like (because of the drag of the co-pilot
throttle cable), but I think it will be acceptable.
Be sure and check out Lance Gingell's site to see how
he mounted his.
Ron
| Quote: | I just got my dual throttle setup installed per the
firewall shelf
tilt
| Quote: | down in this position and this causes alot of
the two throttle
cables.
| Quote: | Any suggestions for improving the movement here ?
Can I just grease the cables ?
| Quote: | Thanks,
John Davis
Burnsville, NC
601XL - Jab 3300
