Gear Legs
mr.sun
PostPosted: Mon Oct 22, 2007 8:58 am    Post subject: Gear Legs Reply with quote
Hi folks,
I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube.
Thanks in advance.
Greg
Greg RV-7
n616tb(at)btsapps.com
PostPosted: Mon Oct 22, 2007 9:30 am    Post subject: Gear Legs Reply with quote
Greg,
There is an excellent tool from Avery just for this purpose. I use it and love it. You end up drilling a hole in the center of the wheel nut and installing a bracket over it to replace the rivenut for the wheel pants. It is an easy conversion, an inexpensive jack jig, and makes lifting a wheel and removing it quite safe and easy. Check it out here.
http://www.averytools.com/p-181-rv-jack-stand.aspx
I see they have the already modified axle nuts as well.
http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx
Here are the brackets for wheel pant connection
http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx
You can purchase all this as a kit.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Greg Williams
Sent: Monday, October 22, 2007 11:57 AM
To: rv-list(at)matronics.com
Subject: Gear Legs
Hi folks,
Thanks in advance.
Greg
yenduc(at)sbcglobal.net
PostPosted: Mon Oct 22, 2007 10:35 am    Post subject: Gear Legs Reply with quote
Tim:
I'm having a hard time visualizing how you get the wheel off with the jack attached to the axle???  How does that work?
dave
On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote:
Greg,
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Greg WilliamsSent: Monday, October 22, 2007 11:57 AMTo: rv-list(at)matronics.com (rv-list(at)matronics.com)Subject: Gear Legs
Hi folks,I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7.  (I'm having a GREAT time flying!!)     I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago.  I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up.  Does anyone have their gear leg out in the open and could give me a measurement?  Mine is all wrapped up in wheel pants and tough to get to right now.  I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance.Greg
PostPosted: Mon Oct 22, 2007 10:46 am    Post subject: Gear Legs Reply with quote
Yea, I understand that. What you do is remove the little wheel pant bracket, place the jack inside the axle through the axle nut. After jacking it up you remove the axle nut and slide it onto the jack bracket pipe. You slide the wheel onto the jack bracket pipe as well then you can place a block or jackstand or something under the axle and let it down. This allows you to remove the wheel from the jack bracket to do whatever you need.
Reverse to re-install.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney
Sent: Monday, October 22, 2007 1:32 PM
Subject: Re: Gear Legs
Tim:
dave
Here are the brackets for wheel pant connection size=2 width="100%" align=center>
Subject: Gear Legs
Hi folks,
Thanks in advance.
Greg
http://www.matronics.com/Navigator?RV-Listhttp://forums.matronics.com
- NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com[/b]
lifeofreiley2003(at)yahoo
PostPosted: Mon Oct 22, 2007 11:30 am    Post subject: Gear Legs Reply with quote
Hey Greg,
I've got a spare Avery jack and modified axle nut set
I'll sell to you. They are nice and work very well.
Total Price New $75.00,
I'll take $50.00
Darrell
--- Tim Bryan <n616tb(at)btsapps.com> wrote:
Greg,
here.
well.
_____
Subject: Gear Legs
Hi folks,
Thanks in advance.
Greg
PostPosted: Mon Oct 22, 2007 1:29 pm    Post subject: Gear Legs Reply with quote
Thanks that makes sense.
dave
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Dave CudneySent: Monday, October 22, 2007 1:32 PMTo: rv-list(at)matronics.com (rv-list(at)matronics.com)Subject: Re: Gear Legs
Tim:
dave
Here are the brackets for wheel pant connectionsize=2 width="100%" align=center>
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Greg WilliamsSent: Monday, October 22, 2007 11:57 AMTo: rv-list(at)matronics.com (rv-list(at)matronics.com)Subject: Gear Legs
  http://www.matronics.com/Navigator?RV-Listhttp://forums.matronics.com               - NEW MATRONICS WEB FORUMS -  class="Apple-converted-space">   --> http://forums.matronics.com[/b]
mr.gsun+rv-list(at)gmail.
PostPosted: Mon Oct 22, 2007 2:00 pm    Post subject: Gear Legs Reply with quote
Hey Folks,
Thanks for all the replies. I'm looking for the right size pipe to use. My thought is to weld a 16" piece of pipe to this old scissor jack that I already have. It came out of some import car and is in good shape. It will go low enough to slide the pipe in after the wheel pant and little bracket are removed. That way it is always in my hangar ready for use. I wouldn't ever worry about the pipe falling off the jack either. If a piece of 3/4" sch 40 water pipe (7/8" OD) will work, I'll grind off the galvanizing, weld it to the jack & slap some paint on it. If I can get something bigger in there, that's better.
Anyone know or can easily measure the ID of that gear leg axle for me?
Greg
On 10/22/07, Dave Cudney < yenduc(at)sbcglobal.net (yenduc(at)sbcglobal.net)> wrote:[quote]
dave
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [ mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Dave Cudney Sent: Monday, October 22, 2007 1:32 PM To: rv-list(at)matronics.com (rv-list(at)matronics.com) Subject: Re: Gear Legs
Tim:
dave
Here are the brackets for wheel pant connection size width="100%" align=center>
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [ mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Greg Williams Sent: Monday, October 22, 2007 11:57 AM To: rv-list(at)matronics.com (rv-list(at)matronics.com) Subject: Gear Legs
Hi folks, I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance. Greg
0--> http://www.matronics.com/Navigator?RV-List - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com
[quote][b] http://www.matronics.com/Navigator?RV-List http://forums.matronics.com [quote][b]
PostPosted: Mon Oct 22, 2007 2:08 pm    Post subject: Gear Legs Reply with quote
Hi Greg,
The hole in my axle nut based on the modification is 1” diameter.  The shaft from the avery tool is ¾” diameter.  I don’t have an axle nut off right now so not sure of the size hole into it.  Hope that helps.
Sent: Monday, October 22, 2007 4:59 PM
Hey Folks,
Greg
dave
Tim:
dave
Subject: Gear Legs
Hi folks,
Thanks in advance.
Greg
Doug Gray
PostPosted: Mon Oct 22, 2007 3:04 pm    Post subject: Gear Legs Reply with quote
Axle ID on my -6 gear legs is 7/8".
Doug Gray
JohnInReno
PostPosted: Tue Oct 23, 2007 2:30 pm    Post subject: Gear Legs Reply with quote
Harbor Freight sells a 1500lb ATV/Motorcycle lift that will pick up the
whole airplane. I am using this on a Grumman Yankee (a.k.a. RV Trainer)
and it works great! I built a box to fit on the rails and topped it with
a piece of plywood and the pink hard foam from Home Depot. Just center
the lift under the CG and service all three wheels at once.
John Morgensen
RV-9A Fuselage plumbing
Grumman AA1B-150 (RV Trainer)
Hey Folks,
Greg
On 10/22/07, *Dave Cudney* < yenduc(at)sbcglobal.net
> Tim
dave
> * From:* owner-rv-list-server(at)matronics.com
> <mailto:owner-rv-list-server(at)matronics.com> [
> mailto:owner-rv-list-server(at)matronics.com] * On Behalf Of *Dave Cudney
> * Sent:* Monday, October 22, 2007 1:32 PM
> * To:* rv-list(at)matronics.com <mailto:rv-list(at)matronics.com>
> * Subject:* Re: Gear Legs
> Tim:
> dave
> <mailto:owner-rv-list-server(at)matronics.com>] * On Behalf Of *Greg
> Williams
> * Sent:* Monday, October 22, 2007 11:57 AM
> * Subject:* Gear Legs
> Hi folks,
> tube.
> Thanks in advance.
> Greg
> http://www.matronics.com/Navigator?RV-List*
> http://forums.matronics.com*
> - The RV-List Email Forum - class="Apple-converted-space"> *
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
klwerner(at)comcast.net
PostPosted: Tue Oct 23, 2007 2:50 pm    Post subject: Gear Legs Reply with quote
Not a bad idea...
sbuc(at)hiwaay.net
PostPosted: Tue Oct 23, 2007 3:36 pm    Post subject: Gear Legs Reply with quote
Can you do that to an RV without damaging the bottom of the fuse?
Sam Buchanan
Konrad L. Werner wrote:
[quote] Not a bad idea...
billsettle(at)bellsouth.n
PostPosted: Tue Oct 23, 2007 4:36 pm    Post subject: Gear Legs Reply with quote
John,
Got any pics?
[quote]-------------- Original message from John Morgensen <john(at)morgensen.com>: --------------
[quote] --> RV-List message posted by: John Morgensen
John Morgensen
> Hey Folks,
> Greg
>&gt ; Yea, I understand that. What you do is remove the little wheel
>> Tim
> dave
>> * From:* owner-rv-list-serve r(at)matr onics.com
>> Tim:
>> dave
>> http://www.averytools.com/p-181-rv-jack-stand.as px > >>
>> Williams
>> Hi folks,
>> I'm getting stuff rea dy to do my first annual condition inspection
>> tube.
>> Thanks in advance.
>> Greg
>&g t; > >> http://www.matronics.com/Navigator?RV-List*
> > * st uti [quote][b]
JohnInReno
PostPosted: Tue Oct 23, 2007 5:17 pm    Post subject: Gear Legs Reply with quote
Pictures:
The 1 1/2" hard pink foam gets poked by the odd nut sticking out but it
supports the weight of the plane without crushing. On the RV and the
Yankee, the CG is on the flat part of the bottom where the spar is
located. The top of my platform is about 18" x 40" or about 5 square
feet. The pressure on the bottom of the fuselage would be about 1200/5
or 240 lbs/sq.ft.
Bill Settle wrote:
John,
Got any pics?
up the
Trainer)
it with
center
> John Morgensen
> > Hey Folks,
scissor jack
wheel pant
the
will work,
paint on
for me?
> > Greg
> >> Tim
> > dave
*Dave Cudney
> >> Tim:
> >> dave
> >> Williams
> >> Hi folks,
inspection
> >> tube.
> >> Thanks in advance.
> >> Greg
> >&g t;
> > > * st uti
 Filesize:  45.71 KB
 Viewed:  299 Time(s)
 Filesize:  50.06 KB
 Viewed:  315 Time(s)
John Morgensen
RV4 - for sale
