kenharrison(at)comporium. Guest
Posted: Thu Oct 18, 2007 2:07 pm Post subject: Attachment fitting at top of lift struts. |
Hello all,
I have read a good deal in the archives regarding the connection to the wing at the top of the lift strut. Is there a definitive method to determine whether those fittings are on far enough. Mine do not have a witness hole and I’m very nervous about not having enough threads. I also see a small amount of surface rust on the threads. That whole connection just makes me nervous. I would think a connection that important, and under that much stress would have all the bolts in sheer, not tension. If those 8 or ten threads fail, your cooked.
Has anyone heard of a Kitfox failing at that point…other than the load testing that was done at the factory?
Does anyone have a secondary or beefed up system on his plane?
Ken
Kitfox III
john(at)leptron.com Guest
Posted: Thu Oct 18, 2007 6:49 pm Post subject: Attachment fitting at top of lift struts. |
Ken,
I have never heard of a failure at this point. I also believe the factory never was able to cause a failure at this point. I did witness many of the test that were done one the classic 4 and was impressed with the results.
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Ken Harrison
Sent: Thursday, October 18, 2007 4:06 PM
Subject: Attachment fitting at top of lift struts.
Hello all,
Ken
Kitfox III
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234
dave
Posted: Fri Oct 19, 2007 1:50 am Post subject: Re: Attachment fitting at top of lift struts. |
Ken,
I think you will find that there to my knowledge has ever been a inflight breakup of a Kitfox from the wing strut attach fitting. I think the testing showed in excess of +14G and still no failure. But I stand to be corrected.
I will say that AVIDs do have what seem to me to be a stronger wing attach fitting by eliminating the rod end.
Kitfox used rod ends I think to compensate for variances in build tolerances but I don't think it anything to worry about. I would check with John McBean to find out the exact procedure of what you are asking.
You only need one thread to fail ,so no matter how far it screwed in the rod end the one that will fail will be out side of it . Does anyone know the actual shear strength of the threaded part of the wing strut attach point ? I would bet each of the 4 attach points are 4000 to 6000 pound tensile and we fly at 1200 or so lbs divided by 4 = 300 each ? MAke sense ? If I am correct that means at 10 gs you are pulling 3000 pound force and I guarantee you that you won't see 10gs. I am done talking outta my ass now. <smile>
| Quote: | I would think a connection that important, and under that much stress would have all the bolts in sheer, not tension. If those 8 or ten threads fail, your cooked.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Fri Oct 19, 2007 2:49 am Post subject: Attachment fitting at top of lift struts. |
One thing that needs to be remembered is that AN fittings have "rolled"
threads, not cut threads. This makes them much stronger than the normal
non-AN threaded fitting and much less susceptible to stress cracking at the
threads. Personally, if there was anything to worry about I believe it
would be the fittings at the horizontal stab where there is a history of
breakage in the IV.
For what it's worth.
Deke
S5, NE Michigan
dave
Posted: Fri Oct 19, 2007 3:09 am Post subject: Re: Attachment fitting at top of lift struts. |
| Quote: | I believe it
breakage in the IV.
I think that perhaps the breakages was due to rough ground handling using the horiz.stab braces for handle rather than using the Fuselage handle.
Would this be the likely culprit ?
He have rolled thread on the strut atttach point?
SO what is the tensile of them and the rod ends ?
Posted: Fri Oct 19, 2007 3:21 am Post subject: Attachment fitting at top of lift struts. |
OK, that makes sense. Except I wonder if one of the lurking engineers on
the list could calculate the in-flight load on one of those fittings.
Because I think you have to account for the fact that the strut is not
attached to the wing at 90 degrees. The in-flight vertical load per fitting
is 300 pounds, but the strut is at about 60 degrees from vertical (or more,
I didn't actually measure it). Just for example, if the strut were at 45
degrees to the vertical, and had a 300 pound vertical load from the wing,
the tension felt by the strut would be 600 pounds, and 600 pounds of
compression felt by the inboard wing spar. (Now I'm showing my ignorance.)
Is that how it would work? The same as the vertical and horizontal
components of lift felt by a wing in turning flight?
Anyway, I think I'm just worrying for no reason. It sounds like the
connection is plenty strong. I'll go back to worrying about ground-looping.
Thanks for the info.
dave
Posted: Fri Oct 19, 2007 3:36 am Post subject: Re: Attachment fitting at top of lift struts. |
| Quote: | Anyway, I think I'm just worrying for no reason. It sounds like the
connection is plenty strong. I'll go back to worrying about ground-looping |
Ken, I am no engineer but I can tell you that past history does speak personally and from the other 5000 plus Kitfox and Avids out there.
If these were going to be over stressed we would be seeing reports of breakage. I think the most likely reason for Kitfox accidents is likely form pilot incompetence from lack of training.
For example if you look at another popular design the Challenger there have been in lfight break ups at the strut to longeron fitting called a RONY bracket. They recommend to change them ever so many hours. Now that is a RED FLAG to me .
Hope this helps
Lynn Matteson
Posted: Fri Oct 19, 2007 4:04 am Post subject: Attachment fitting at top of lift struts. |
Is that "history of breakage in the IV" when they were 3/16" rod end
bearings? I know there's an SB on changing these to 1/4", which is
what I did during my building process. I got the AN490 threaded rod
ends (1/4"), welded them myself, and got the necessary 1/4" x 3/16"
rod end bearings, and have been avoiding the grim reaper ever
since. : ) (knock on wood)
Lynn Matteson
flying w/420+ hrs
On Oct 19, 2007, at 7:46 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
"rolled" threads, not cut threads. This makes them much stronger
than the normal non-AN threaded fitting and much less susceptible
to stress cracking at the threads. Personally, if there was
anything to worry about I believe it would be the fittings at the
horizontal stab where there is a history of breakage in the IV.
Deke
S5, NE Michigan
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
MichaelGibbs(at)cox.net Guest
Posted: Fri Oct 19, 2007 7:37 am Post subject: Attachment fitting at top of lift struts. |
Ken sez:
| Quote: | ...I wonder if one of the lurking engineers on the list could
I don't want to discourage the lurking engineers from having some
fun, but that calculation was performed at the factory 20 years ago
when the design was developed. Since there has never been an
inflight failure, I'd say their numbers have been fully validated
through operational experience.
There are things to worry about when building and flying your Kitfox
but this is probably not one of them.
Mike G.
N728KF
Phoenix, AZ
n61kf
Joined: 27 Aug 2006 Posts: 23 Location: Waynesville Ohio
Posted: Fri Oct 19, 2007 8:45 am Post subject: Re: Attachment fitting at top of lift struts. |
Ken.
There should be 1 1/16" of threads on the end of the lift strut. The witness hole on my rod ends are 5/16" from the open end. I too have had some concern about the strength of the threaded portion of the lift strut. This stems from the fact that both of the threaded ends on the left wing of the Mod IV that I am repairing, broke off, just below the rod end bearing. This was due to a severe compression load on the strut due to a pancake landing which collapsed the landing gear and bent the fuselage. I think in this case some thing had to give, and it was the threaded end that gave. I this case you are already on the ground and having a bad day. so the rod ends breaking is not the worst of it.
Keith Schneider
Mod IV 912,almost done
Waynesville, Ohio
_________________ Keith Schneider
Red Stewart Airfield
Waynesville Ohio
KF IV 912ul |
Guy Buchanan
Posted: Fri Oct 19, 2007 4:10 pm Post subject: Attachment fitting at top of lift struts. |
At 04:20 AM 10/19/2007, you wrote:
| Quote: | OK, that makes sense. Except I wonder if one of the lurking engineers on
the list could calculate the in-flight load on one of those fittings. |
Sigh. I know it's fun to hash these things out verbally every time they arise, but one of the "lurking engineers" has calculated in-flight loads on these fittings in the past two years. Indeed this entire subject was re-hashed and therefore appears in the archives. Since I know no one will look I will quickly summarize my findings:
Using the rod end fittings found on my IV-1200 there was NO WAY you were going to get to 14g's. (Personally I think that's an urban legend, since I've not seen any NUMBERS to justify it.) Indeed my rod ends would fail at something closer to 6g, as they should for this design. (Utility category limit loads of +3.8g, -1.5g, break at +5.7, -2.25g.).
Though it's not the best way to accommodate a load, there's nothing terribly wrong with the rod ends when loaded in tension, indeed they allow for all sorts of manufacturing defects. (There are stress concentration factors associated with loading threads in tension, but you design for that. Look around and you'll see all sorts of designs with treads loaded in tension; like cylinder and head bolts.) Unfortunately the rod ends are less desirable in compression, since any misalignment can cause the exposed threaded rod to buckle prematurely.
The bottom line is that there has never been an in-flight break-up of a Kitfox to our common knowledge, and I personally know of several who have tried, and probably still are trying. Over 15(?) years that's a pretty good record.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Posted: Fri Oct 19, 2007 5:25 pm Post subject: Attachment fitting at top of lift struts. |
Guy sez:
| Quote: | Using the rod end fittings found on my IV-1200 there was NO WAY you
It's more than a legend, Guy. It was documented in a builder
newsletter from the factory in the late '80s or early '90s, complete
with photos of the physical testing. I have it around here
somewhere... The caption on one of the photos specifically stated
that the sandbags piled on the inverted wing/lift strut assembly
represented 14g.
Because it was a general interest publication, no engineering data
was included.
Mike G.
N728KF
Phoenix, AZ
dave
Posted: Fri Oct 19, 2007 5:52 pm Post subject: Re: Attachment fitting at top of lift struts. |
Guy, how do you justify this statement ?
| Quote: | Using the rod end fittings found on my IV-1200 there was NO WAY you were going to get to 14g's. (Personally I think that's an urban legend, since I've not seen any NUMBERS to justify it.) Indeed my rod ends would fail at something closer to 6g, as they should for this design. (Utility category limit loads of +3.8g, -1.5g, break at +5.7, -2.25g.).
dave
Posted: Fri Oct 19, 2007 6:00 pm Post subject: Re: Attachment fitting at top of lift struts. |
I have pics and video here as well but I think you will find this satisfying info on John Mc Bean's Site
http://www.kitfoxaircraft.com/Testing%20information.htm
Nextd tim you see an AVID look close at the wing strit attach to wings points. There are no rod ends as Dean Wilson designed it to be strong. Not to say the Kitfox is not strong but I think with a Rod end that just adds one more part that could fail.
Does anyone have tensiles of a rod end used ?
Also what is tensile of the wrapped end on the Avids ?
Guy Buchanan
Posted: Sat Oct 20, 2007 5:18 am Post subject: Attachment fitting at top of lift struts. |
At 06:52 PM 10/19/2007, you wrote:
| Quote: | Guy, how do you justify this statement ?
Which statement? Do you mean you would like me to provide the math?
Or do you mean the catagory limit loads?
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
dave
Posted: Sat Oct 20, 2007 5:48 am Post subject: Re: Attachment fitting at top of lift struts. |
yes, please show us how you can claim your rod ends will fail at 5.7g s and what what weight of aircraft? And document your testing to make these statements. Since you know how to figure this tell us when the outboard section of spar from wing attach point outwards will actually bend and stay distorted.
Thanks in advance
| Quote: | | Using the rod end fittings found on my IV-1200 there was NO WAY you were going to get to 14g's. (Personally I think that's an urban legend, since I've not seen any NUMBERS to justify it.) Indeed my rod ends would fail at something closer to 6g, as they should for this design. (Utility category limit loads of +3.8g, -1.5g, break at +5.7, -2.25g.). |
Guy Buchanan
Posted: Sat Oct 20, 2007 9:40 am Post subject: Attachment fitting at top of lift struts. |
At 06:48 AM 10/20/2007, you wrote:
| Quote: | yes, please show us how you can claim your rod ends will fail at
I don't know, Dave. It sounds like you may have a chip on your
shoulder and that I'd be pretty much wasting my time. You know very
well I haven't done any testing and that all the information publicly
available on Kitfox structural testing, (I've looked,) is contained
in those few pictures plus an anecdotal value of 14g's. Perhaps John
will come forth with details of the structural testing, including
methodology, drawings, detail photo's, and results.
When I find the time I will, however, provide the math and rod end
specifications for your use. Don't hold your breath but you may
remind me from time to time if I dally.
And you needn't be alarmed by my results. I DID note that they were
consistent with the stated design loads.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Guy Buchanan
At 06:23 PM 10/19/2007, you wrote:
| Quote: | It's more than a legend, Guy. It was documented in a builder
represented 14g.
OK Mike. I know your word is good. I'll see if I can reconcile my
results with those in the pictures on John's site. If nothing else is
available John might be able to send enlargements of the pictures so
I can learn more about the testing. If anybody has the newsletter I'd
be grateful if I could get a copy.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
jdmcbean(at)kitfoxaircraf Guest
Posted: Sat Oct 20, 2007 11:25 am Post subject: Attachment fitting at top of lift struts. |
We do have the documentation on the structural testing done to the Fox. It
was extensive and done with FAR part 23 in mind for certification purposes.
I can tell you that when testing the wing section at 5.7g's positive... the
rod end did not fail.
Fly Safe !!
"It's not how Fast... It's how Fun!"
5:41 PM
temco(at)telusplanet.net Guest
Posted: Sat Oct 20, 2007 11:42 am Post subject: Attachment fitting at top of lift struts. |
Guy
I do have a copy of that test and I will forward a copy to you as soon as I
find it.
Ted Palamarek
K-IV-1200/912UL
Edmonton, Alberta
Guy Buchanan
San Diego, CA
