herbgh
Posted: Wed Oct 17, 2007 7:53 pm Post subject: Installing Book binding tape |
All
Trying to install gap seals on my Firefly today.. made a mess of the first one...Wondering what the technique could be ? Missing something in my reclining years...Herb
Steve Boetto
Posted: Thu Oct 18, 2007 4:13 am Post subject: Installing Book binding tape |
Herb,
After you prepare your overlapped tape (assumed you know how to do this) cut a short section of this as a test, a few inches long.
From the top of the wing, apply one of the sticky sides to the top, back edge of the wing trailing edge.
You will see the whole tape assy above the wing and aileron. with the other sticky edge towards the rear and pointing up.
Place that aileron FULL down.
Push the tape down through the gap between the wing trailing edge and aileron leading edge.
From underneath, push the sticky part on the underside of the aileron leading edge.
If you have too much or too little tape length left, adjust by changing the position on the wing (step 1)
Now you will know where to start when applying the tape on the wing.
Go for it with a full length piece.
Goo luck, It is easy once you get the hang of it.
Steve B
Firefly 007/Floats
See w [quote][b]
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Thu Oct 18, 2007 4:27 am Post subject: Installing Book binding tape |
Steve,
For those of us that may be unsure of how to accomplish the overlap, could you detail that procedure also?
N27SB(at)aol.com wrote:
[quote] Herb,
Steve B
Firefly 007/Floats
See w [quote][b] [quote][b]
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
Steve Boetto
Posted: Thu Oct 18, 2007 4:44 am Post subject: Installing Book binding tape |
In a message dated 10/18/2007 8:28:00 A.M. Eastern Daylight Time, kolbdriver(at)mlsharp.com writes:
Sure,
I use the kitchen counter top. (Wives and mothers love this)
Take a length of tape, (more than you need) and lay it sticky side up.
Secure it by taping each end down using tape.
Lay a second piece down over it and leave about a half inch exposed along the full length.
About a half inch of the top piece will stick to the counter top.
Trim each end to achieve the desired length.
Carefully carry it out to the plane and apply.
Remove all traces of airplane activity from the kitchen lest all Hell break loose.
Steve B
Firefly 007/Floats
terry(at)juliaswartz.com Guest
Posted: Thu Oct 18, 2007 5:05 am Post subject: Installing Book binding tape |
Here is the easy way. Forget the tape overlap. Get some 4 inch wide tape, stick it on the bottom of wing-flap, sprinkle baby powder on the exposed adhesive. Your done.
On 10/18/07, Michael Sharp <kolbdriver(at)mlsharp.com (kolbdriver(at)mlsharp.com)> wrote: | Quote: | Steve,
N27SB(at)aol.com (N27SB(at)aol.com) wrote:
| Quote: | Herb,
Steve B
Firefly 007/Floats
See w
herbgh
Posted: Thu Oct 18, 2007 6:36 am Post subject: Installing Book binding tape |
Steve
Should have made myself more clear....no problem with application,,,the problem is in handling..at one time or the other both hands are stuck to the tape.. when I get a suitable piece layed flat on a table, the overlap piece is just very difficult to place into position..static electricity etc.. once it sticks--you are stuck!
Anyone tried straight pins to hold the first piece in position? Herb
On Thu, 18 Oct 2007 08:11:40 EDT N27SB(at)aol.com (N27SB(at)aol.com) writes:
[quote] Herb,
Steve B
Firefly 007/Floats
See w
bill_joe(at)bellsouth.net Guest
Posted: Thu Oct 18, 2007 6:37 am Post subject: Installing Book binding tape |
Well here is my advise, if you want to do it right forget about the book binding stuff and use 3 inch finishing tape. I have done both and the finishing tape is easy to do. Ten you paint it with a brush. I replaced the book binding stuff twice on mine before I used the finishing tape.If you want to know how to do it get with me off line.lt is easy.
My opinion
Bill Futrell
herbgh
Posted: Thu Oct 18, 2007 6:38 am Post subject: Installing Book binding tape |
Steve
That is what I was looking for...never occurred to "frugal" Herb to waste an inch or so on either end! Thanks....Herb
On Thu, 18 Oct 2007 08:43:17 EDT N27SB(at)aol.com (N27SB(at)aol.com) writes:
[quote] In a message dated 10/18/2007 8:28:00 A.M. Eastern Daylight Time, kolbdriver(at)mlsharp.com writes:
Sure,
Steve B
Firefly 007/Floats
Steve Boetto
Posted: Thu Oct 18, 2007 7:44 am Post subject: Installing Book binding tape |
Herb, Yell if you have any questions. You can also mark the countertop with a dry erase marker to aid in positioning the tape. That first piece is hard to see.
There are many ways to do the gap seal.
This method was Bryan Melborn's.
IMHO, This is the nicest looking and it is very durable unless your plane sits out 24/7.
It is almost invisible unless you really look.
You can remove it by using a little heat from a hair dryer(Yup, you guessed it,From the girlfriend's bathroom) and clean up with googone. It does not harm Polytone in my experience. Test yours.
Steve
Firefly 007/Floats
See w [quote][b]
JetPilot
Posted: Sat Oct 20, 2007 6:30 am Post subject: Re: Installing Book binding tape |
What is finishing tape and where do you get it ???
Also, where do you guys get the book binding tape ?
Kolb MK-III Xtra, 912-S |
Steve Boetto
Posted: Sat Oct 20, 2007 9:58 am Post subject: Installing Book binding tape |
In a message dated 10/20/2007 10:31:25 A.M. Eastern Daylight Time, orcabonita(at)hotmail.com writes:
| Quote: | Also, where do you guys get the book binding tape ?
There are many sources on the Web, I think John H posted one on this thread.
I buy mine from TNK. About the same price and Travis keeps it in stock.
Steve B
Firefly 007/Floats
See w [quote][b]
possums(at)bellsouth.net Guest
Posted: Sat Oct 20, 2007 3:59 pm Post subject: Installing Book binding tape |
At 10:30 AM 10/20/2007, you wrote:
This was put on with "finishing tape" and painted, I forget what
size I used. All the aircraft fabric places sell it where ever you get
your covering supplies.
61.06 KB |
438 Time(s) |
