a.s.elliott(at)cox.net Guest
Posted: Wed Oct 17, 2007 10:19 am Post subject: Control Locks? |
Looking for any good ideas, drawings or pix on making a control lock for the dual stick version of the 601XL. (No, I don't want to use the seat belts!)
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
Posted: Wed Oct 17, 2007 12:05 pm Post subject: Control Locks? |
Not there yet but how about a flat, triangular plate which fastens to the bottom lip of the control panel with wing nut quarter-turn fasteners and extends horizontally to meet the stick at its "parked" position? A U-shaped flange at the stick would allow a Velcro strap to clamp the stick to the plate. A little padding would keep the flange from scratching the stick.
GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Wed Oct 17, 2007 1:43 pm Post subject: Re: Control Locks? |
I WAS THINKING ABOUT A BAR THAT YOU ENGAGE THE CENTER SPAR AND ALSO ENGAGE THE BRAKES FOR A PARKING BRAKE, JUST NOT AT THAT STAGE YET.
GLENN
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
bryanmmartin
Posted: Wed Oct 17, 2007 2:13 pm Post subject: Control Locks? |
It's fairly easy to make exterior control locks for the 601xl. You just need a device to slide into the gap between the flap and aileron on one side and trap the aileron from above and below. Another similar device to slide between the elevator and the end fairing. Add a couple "Remove Before Flight" flags and you're done.
On Oct 17, 2007, at 2:15 PM, Dr. Andrew Elliott wrote:
| Quote: | Looking for any good ideas, drawings or pix on making a control lock for the dual stick version of the 601XL. (No, I don't want to use the seat belts!)
Andy Elliott, Mesa, AZN601GE (reserved)601XL/TD/QB, Corvair, building...
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
