				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| HawkerPilot2015
				|  Posted: Tue Feb 21, 2006 5:52 pm    Post subject: Removing the blades from the V-530 |   |
				| Anyone ever done it? Any advice on the process. I am having the blades overhauled next month.
 Thanks in advance!
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| dsavarese(at)elmore.rr.co Guest
				|  Posted: Tue Feb 21, 2006 6:24 pm    Post subject: Removing the blades from the V-530 |   |
				| Very easy Tim.  Remove the cotter pins from the castellated nuts that hold
the counter weight clamps.  Next, loosen the nuts to release the pressure on
 the blade shanks.  Unscrew the blades by turning them counterclockwise.
 Bingo, your done.
 Dennis
		| Back to top |  |
		| rkent(at)wlacrussianeng.c Guest
				|  Posted: Wed Feb 22, 2006 12:41 am    Post subject: Removing the blades from the V-530 |   |
				| Tim,
 Blade removal is easy. You undo the nut on the counterweight bolt and the
 blade unscrews in the normal anti-clockwise manor.
 Rob Kent
 Stores Manager
 WLAC - Russian Engineering
 www.wlacrussianeng.co.uk
 Tel: +44 1628 829 165
 Fax: +44 1628 828 961
		| Back to top |  |
				|  Posted: Wed Feb 22, 2006 12:42 am    Post subject: Removing the blades from the V-530 |   |
				| Sorry Tim/Dennis,
 I missed this reply.
 Rob Kent
 Stores Manager
		| Back to top |  |
		| HawkerPilot2015
				|  Posted: Wed Feb 22, 2006 8:42 am    Post subject: Re: Removing the blades from the V-530 |   |
				| Thanks guys!
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
