carlosh(at)sec-engr.com Guest
Posted: Thu Oct 11, 2007 1:04 pm Post subject: New style flap actuator |
Hello everyone,
My name is Carlos Hernandez and I'm in Arizona. Please excuse me for not
owning a Zenith aircraft but I have some questions about the linear flap
actuator that are now being used in them. I own and fly a Pazmany PL-1,
which is very similar in size and performance to the 601, with manual
flaps and we want to convert to electric flaps. Now I've read the
archives but not much has been mentioned about the performance of the
new style unit compared to the original heavier and more costly
actuator. I was told that there are several flying with this unit. The
old unit number is D145-00-36-3 and the newer version is DE12-17W41. I
have an A&P who is persistent in using the more expensive unit that has
"a track record". I'm not looking to debate the A&P, he's a good friend
and I do greatly respect his knowledge and opinion. I just don't allows
agree with him. So I'm more or less looking for testimonials and/or
experiences with the new style actuator. Do you trust it less/same/more
than the original? I'm looking into these because they're lighter, less
expensive and, if need be, easily replaceable.
Thank you for your time ladies and gents!
Carlos
Carlos Hernandez <carlosh(at)sec-engr.com>
Structural Engineers, LLC
2963 W. Elliot Rd. - Suite 3
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
CONFIDENTIALITY NOTICE
The information in this email may be confidential and/or privileged.
This email is intended to be reviewed by only the individual or
organization named above. If you are not the intended recipient or
an authorized representative of the intended recipient, you are hereby
notified that any review, dissemination or copyingof this email and
its attachments, if any, or the information contained herein is
prohibited. If you havereceived this email in error, please
immediately notify the sender by return email and delete this email
from your system.
psm(at)ATT.NET Guest
Posted: Thu Oct 11, 2007 2:14 pm Post subject: New style flap actuator |
Hi Carlos,
I am replying with anecdotal information I got from email posts
rather than experience, so don't take my comments too seriously. I
also had a conversation with an engineer at ZAC over the actuator question.
First let me say the reason I spoke to ZAC over this issue is the old
unit didn't give me full displacement on the flaps. The drawings
call for 30 degrees and I was getting around 28. The engineer at
Zenith told me the new actuator only gives 20 degrees in this design.
The other comment I have is some builder posted a complaint about
run-away flaps a few months ago. I don't know which actuator he had,
but apparently it wasn't the old "tried and true" heavy and expensive actuator.
Good luck,
Paul
XL fuselage
At 02:03 PM 10/11/2007, you wrote:
Hello everyone,
not owning a Zenith aircraft but I have some questions about the
linear flap actuator that are now being used in them. I own and fly
a Pazmany PL-1, which is very similar in size and performance to the
601, with manual flaps and we want to convert to electric flaps. Now
I've read the archives but not much has been mentioned about the
performance of the new style unit compared to the original heavier
and more costly actuator. I was told that there are several flying
with this unit. The old unit number is D145-00-36-3 and the newer
version is DE12-17W41. I have an A&P who is persistent in using the
more expensive unit that has "a track record". I'm not looking to
debate the A&P, he's a good friend and I do greatly respect his
knowledge and opinion. I just don't allows agree with him. So I'm
more or less looking for testimonials and/or experiences with the
new style actuator. Do you trust it less/same/more than the
Carlos
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
Posted: Thu Oct 11, 2007 6:44 pm Post subject: New style flap actuator |
The run-away actuator was with the Surplus Center actuator and actually
cause by the electronic controller available from the same source. With a
hard toggle switch there is no power available to the actuator (of any make
or model) and it can't run away. Others include a circuit breaker in the
flap motor circuit to add a back-up disconnect.
-- Craig
