jkafka(at)trojanuv.com Guest
Posted: Wed Oct 10, 2007 11:34 am Post subject: Wing Spars Done! Bolts? |
More than 3 years after starting them (there was a long break), my plans-built wing spars are done. For me this was a big deal because dealing with all those solid rivets (without a rivet gun) appeared to be one of the bigger hurdles in the way of eventual completion.
To celebrate my minor success, I decide to get a photo of me posing behind the assembled structural “guts” of my 601XL-to-be. While assembling, I was unable to find direction in the plans or manual about the way the twelve bolts connecting the outboard spars to the center spar should face. Does it matter if the bolt heads are on the forward or aft side of the spars? Should one alternate them? What about the bolt at the root of the outboard spars and the ones in the center spar (in the plans the latter appear to have the bolt heads on the forward side).
On to finish the remaining rear ribs!
Jeff Kafka
601XL Plans
Tail, Flaps, Ailerons, Spars Done
Working on Ribs & Assembling Wings
This message (including any attachments) contains confidential
and/or proprietary information intended only for the addressee.
Any unauthorized disclosure, copying, distribution or reliance on
the contents of this information is strictly prohibited and may
constitute a violation of law. If you are not the intended
recipient, please notify the sender immediately by responding to
this e-mail, and delete the message from your system. If you
have any questions about this e-mail please notify the sender
immediately.
bryanmmartin
Posted: Wed Oct 10, 2007 12:05 pm Post subject: Wing Spars Done! Bolts? |
I put my bolts in with the nuts exposed on the front of the spar for
easy inspection.
Kafka, Jeff wrote:
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
Rick.Beckman(at)atk.com Guest
Posted: Wed Oct 10, 2007 12:14 pm Post subject: Wing Spars Done! Bolts? |
Jeff Kafka
My tech counselor told me that bolts go back, in, and down.
Happy Building!!!!!
Rick Beckman
dougsnash(at)yahoo.com Guest
Posted: Wed Oct 10, 2007 12:23 pm Post subject: Wing Spars Done! Bolts? |
Hey Jeff, sounds like a major milestone, congrats.
Keep in mind that I am a 701 builder and have no
actual data to base this advice on but standard
aircraft procedure dictates that the heads of the
bolts will be forward. That way if the nut came off,
the slipstream would help hold things together.
Hope this helps in this application.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
DO not archive
--- "Kafka, Jeff" <jkafka(at)trojanuv.com> wrote:
| Quote: | More than 3 years after starting them (there was a
long break), my
big deal because
gun) appeared to be
completion.
photo of me posing
behind the assembled structural "guts" of my
601XL-to-be. While
spars to the center
center spar (in the
the forward side).
Jeff Kafka
601XL Plans
Don't let your dream ride pass you by. Make it a reality with Yahoo! Autos.
http://autos.yahoo.com/index.html
bryanmmartin
Posted: Wed Oct 10, 2007 2:12 pm Post subject: Wing Spars Done! Bolts? |
There are two guidelines for installing bolts. A. Install the bolt such
that gravity or aerodynamic forces will tend to keep the bolt in place
in case the nut falls off. B: Install the bolt such that the nut can be
easily inspected for security.
Since the spar bolts are mounted horizontally inside the fuselage, I
chose to make the nuts easy to inspect. I also did this with the bolts
through the rear spar. I installed these bolts with the nuts visible
from the rear when the flaps are lowered.
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Wed Oct 10, 2007 6:56 pm Post subject: Re: Wing Spars Done! Bolts? |
Congratulations on reaching that milestone. Here is a picture of my solid riveting machine.
145.61 KB |
600 Time(s) |
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
