evmeg(at)snowcrest.net Guest
Posted: Tue Feb 21, 2006 6:51 am Post subject: pitot tube group buy |
Ok fellow builders, I have had several inquiries about whether or not I would discount my pitot tube kits for a group buy. Since I am currently participating in the Hooker harness group buy I can hardly say no. So heres the deal...I will discount the kit by 25% for a group buy of 10 or more, limited to the stock on hand. Anybody interested should just call or email me directly and add your name to the list. As soon as I hit the 10 mark I will ship them out. Those interested can have a look at the kits at the following link:
http://www.evansaviationproducts.com/Other%20Products.htm
Cheers...
Evan Johnson
(530) 351-1776 cell
bo124rs(at)hotmail.com Guest
Posted: Tue Feb 21, 2006 12:32 pm Post subject: pitot tube group buy |
Can I install your kit post wing construction?
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
dan(at)rdan.com Guest
Posted: Tue Feb 21, 2006 2:43 pm Post subject: pitot tube group buy |
Similar question,,
Can I install it in a Quick build wing ??
mine will be here in few weeks
Dan
Dana Overall
Richmond, KY i39
Posted: Tue Feb 21, 2006 7:14 pm Post subject: pitot tube group buy |
Sure, no problem. If the bottom skins are not in place it will not be a big
challenge. Even if they are it has been done a few times. The only difficult
part would be if the standard pitot location has been drilled...then you
have a hole to fill. The quick build should not have this drilled out. The
issue is that you do not want to have a pitot line interfering with the
aileron bellcrank. The pitot per plans is in the same bay as the
bellcrank....any other option needs to be moved. If you are not sure about
your wing then please give me a call or email so we can work it out.
Cheers.....
Evan Johnson
(530)247-0375
(530)351-1776 cell
flyrv6(at)bryantechnology Guest
Doesn't the quick build wing have one skin still off? It used to be that
way. If one is off, you should be able to put in this pitot tube easy
enough.
Posted: Tue Feb 21, 2006 7:44 pm Post subject: pitot tube group buy |
Cheers.....
Evan Johnson
(530)247-0375
(530)351-1776 cell
Posted: Wed Feb 22, 2006 6:50 am Post subject: pitot tube group buy |
Hi Dana, thanks for the inquiry. It is a bit more of a challenge on a
finished wing but of course it can be done. The stiffener plate that goes
inside the wing captures several of the rivets along the spar flange so you
would have to drill those out. Also the pitot needs to be moved one bay
outboard from the aileron bellcrank, so you either have to replace your line
in the wing or splice in a length. Personally I would just re-run the
tubing....its cheap enough. If you are interested forward me your mailing
address and I will get a kit out to you. We already have enough interest to
make the group buy work. In any case if you get the kit and decide you are
not up for the job, just return it. I'm easy that way and you will only be
out shipping.
Evan
william(at)gbta.net Guest
Posted: Wed Feb 22, 2006 4:13 pm Post subject: pitot tube group buy |
Wish you had a heated version.
Bill
Posted: Thu Feb 23, 2006 7:38 am Post subject: pitot tube group buy |
Hi Bill, I was working on a CNC milled version of a cessna heated tube but
kind of put the project on hold. A couple of others came available so I was
not sure there would be enough interest. My target price for the tube and
the mount with all of the hardware is around $350....I guess I should finish
my work up and see.
Evan Johnson
(530)247-0375
(530)351-1776 cell
Posted: Thu Feb 23, 2006 3:03 pm Post subject: pitot tube group buy |
Would definitely be interested if you can finalize them.
Bill
