Bending leading edge skin
wjones(at)brazoriainet.co
PostPosted: Sun Oct 07, 2007 8:08 am    Post subject: Bending leading edge skin Reply with quote
Hello group ,yes it can be done the same as the Sonex .This morning I was amazed at how easy it was to form the leading edge skin using the vacuum method .It only took about one hour with the help of my lovely wife . The results are very satisfactory.
Wade Jones
 Filesize:  61.31 KB
 Viewed:  492 Time(s)
Afterfxllc(at)aol.com
PostPosted: Sun Oct 07, 2007 6:52 pm    Post subject: Bending leading edge skin Reply with quote
Can you send me some more pics of the skin?
PostPosted: Mon Oct 08, 2007 3:11 am    Post subject: Bending leading edge skin Reply with quote
Yes I will send some pictures and details if you will contact me at wjones(at)brazoriainet.com (wjones(at)brazoriainet.com) .
Wade Jones South Texas
601XL plans building
Cont. 0200
kmccune
PostPosted: Mon Oct 08, 2007 3:59 am    Post subject: Re: Bending leading edge skin Reply with quote
Would a shop vac do that, or does it require a vacuum pump?
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
PostPosted: Mon Oct 08, 2007 4:07 am    Post subject: Bending leading edge skin Reply with quote
Hi Kevin shop vac works great .
Cont. 0200
bruno(at)shortcutto701.co
PostPosted: Mon Oct 08, 2007 10:52 pm    Post subject: Bending leading edge skin Reply with quote
Here a video about this method (3 parts):
http://www.youtube.com/watch?v=yqzToYQ765w&mode=related&search=
http://www.youtube.com/watch?v=Aa9LVYDeMEo&mode=related&search=Sonex%20sonexbuilding
http://www.youtube.com/watch?v=IonjM5IEoMs
bye
Bruno
maarten versteeg
PostPosted: Tue Oct 09, 2007 6:36 am    Post subject: Bending leading edge skin Reply with quote
Hello Wade,
I am approaching the leading edge step in my building so I was
very interested in options for the bending process.
I watched the video's on 'youtube' and it looked like a great
way to get the desired bending in a very controlled process.
I have tried both the 'table' and air bending processes on a
very small piece of material and the leading edge fit was a
little better with the 'table' pressed part. My question is
what size of tube did you use to 'air' bend the skin, I did my
test with the drawing listed 1 3/8" tube.
Maarten, San Antonio
601xl, plans building wings
Time: 09:08:24 AM PST US
Subject: Bending leading edge skin
Wade Jones
Maarten Versteeg
601XL scratch building wings
PostPosted: Tue Oct 09, 2007 6:50 am    Post subject: Bending leading edge skin Reply with quote
Hi Maarten ,I used a galvanized 1" sch 40 pipe .The pipe book lists this
size as 1.315" mine measured 1.322 .This being a bit smaller than the
required 1.375 worked out well and took care of the spring back .
Cont. 0200
