		| Author | Message |
		| Jeff Linebaugh
				|  Posted: Mon Feb 20, 2006 9:34 am    Post subject: Distraction-the Best Medicine |   |
				| One thing I have learned from being a parent is that sometimes the best way to end a tirade is by distraction...so....
 Distraction of the Week:
 At 500' after setting climb power on initial takeoff you observe your Main Air pressure at 28 and falling. (You DO always check your air pressure after takeoff, don't you?)  What should you do?
 a) Turn to the downwind and return immediately for landing
 b) Use the Emergency Air System to blow your gear down
 c) Both of the above
 d) none of the above...describe your actions....
 Jeff Linebaugh
 jefflinebaugh(at)earthlink.net (jefflinebaugh(at)earthlink.net)
 http://home.earthlink.net/~jefflinebaugh/
 Yakless
 Memphis, TN
 [img]cid:77223213-2C1C-4BBC-94EE-E999CC82F48F[/img]
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
 Jeff Linebaugh
 jefflinebaugh@earthlink.net
 Collierville, TN
		| Back to top |  |
		| wlannon(at)cablerocket.co Guest
				|  Posted: Mon Feb 20, 2006 9:44 am    Post subject: Distraction-the Best Medicine |   |
				| d) ----- Open the air valve!
[quote]   ---
		| Back to top |  |
		| dsavarese(at)elmore.rr.co Guest
				|  Posted: Mon Feb 20, 2006 10:09 am    Post subject: Distraction-the Best Medicine |   |
				| d) Since it was not described in the "distraction" if the gear  was retracted or not, if the landing gear indicated "up and locked" via the red  lights ON, with 28 ATM, there is enough air in the main system to extend the  landing gear into the down and locked position.  I would immediately 1)  verify the main air valve is fully ON (although with the gear up and lock it is  highly unlikely the main air valve is not open); 2) immediately extend the  landing gear and check for all green lights indicating "down and locked".   3) If the landing gear did not fully extend to indicate "down and locked" via  the green lights, then we would have the emergency air system to extend the  landing gear AND have air for braking upon landing.  No flaps in a Yak 52  though.
 If the landing gear did not indicate "down and locked", turn  off the main air supply; next move the gear selector to the neutral position and  allow the air in the shuttle valves and actuators to expel.  Once this is  accomplished (listen to the air expelling from the gear selector), open the  emergency air valve to extend the gear into the down and locked position (green  lights ON)
 Next, make a no flap landing.  Taxi to you hangar or  parking spot and then turn off the emergency air valve.
 Dennis
 [quote]   ---
		| Back to top |  |
		| brian
				|  Posted: Mon Feb 20, 2006 10:23 am    Post subject: Distraction-the Best Medicine |   |
				| Jeff Linebaugh wrote:
  	  | Quote: |  	  | One thing I have learned from being a parent is that sometimes the best way to end a tirade is by distraction...so....
 Didn't we just do this one not too long ago?
  	  | Quote: |  	  | a) Turn to the downwind and return immediately for landing b) Use the Emergency Air System to blow your gear down
 Put the gear down immediately using the normal system. Put the gear
 handle in neutral. See if the air pressure stabilizes. If it doesn't, at
 least the gear is already down and locked. If the gear won't come down I
 would put the gear and flap levers in neutral and see if I get any
 additional pressure. If not I would plan on flying to someplace with a
 long, wide runway where I could put the gear down with the emergency
 system. The leak will probably mean that, even if the gear does come
 down, I probably will NOT have brakes.
 It depends a lot on just how fast the pressure is going down. If it is
 going down slowly I would plan to land back home and open the emergency
 air valve just before touchdown to ensure I have air to stop the
 airplane. If it is still going down rather rapidly I would assume I
 would have to land without brakes even with the emergency air system
 which means I would not have directional control once I slow below the
 speed at which my rudder is effective. In that case I would fly to an
 airport with a very large runway that is aligned with the wind where I
 could get the airplane stopped on the runway without damage without
 using the brakes.
 Brian Lloyd                         361 Catterline Way
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
 Brian Lloyd
		| Back to top |  |
				|  Posted: Mon Feb 20, 2006 10:46 am    Post subject: Distraction-the Best Medicine |   |
				| Brian,
The 52's emergency system does supply air to the brakes, but not the flaps
 and is more than adequate to stop the airplane and taxi to the ramp.
 Dennis
		| Back to top |  |
		| brian
				|  Posted: Mon Feb 20, 2006 11:34 am    Post subject: Distraction-the Best Medicine |   |
				| A. Dennis Savarese wrote:
  	  | Quote: |  	  | <dsavarese(at)elmore.rr.com>
 Brian,
 flaps and is more than adequate to stop the airplane and taxi to the ramp.
 There is commonality in the two systems, normal and emergency. (I speak
 for the CJ6A and am making that assumption for the Yak-52.) If the leak
 is in a common component then you could end up with no brakes even if
 using the emergency system. Hence my suggestion to find a long, wide
 runway just-in-case.
 We know that there is a leak because the pressure is dropping. We just
 don't know where the leak is as isolating the systems by putting gear
 and flap levers in neutral does not stop the leak.
 Just off the top of my head it may be that the leak is in the braking
 system as there is no way to isolate that loop in the pneumatic system
 as you can with the gear and flap circuits. The braking system IS common
 to both the main and emergency pneumatic systems.
 Yes, I would question whether or not I would have brakes when I land.
 Better be safe than sorry. It will take less time to fix a leak in the
 braking system than to repair the airframe after running off the end of
 the runway.
 Brian Lloyd
		| Back to top |  |
		| ira.saligman(at)verizon.n Guest
				|  Posted: Tue Feb 21, 2006 2:45 am    Post subject: Distraction-the Best Medicine |   |
				| All very good  points.  I have one to add from the practical point of what should you have  been thinking if you find yourself rolling down a runway w/o  brakes:
 1) consider using  the longest runway and/or the runway with the best overrun situation (you should  know the overrun conditions at your home airport and already know which one you  would use)  also consider the other traffic at the  airport
 If the field has a  grass runway, consider landing on it, (higher resistance, quicker stop)
 Consider taking off  again and flying Gear down to an appropriate grass field
 2) Know how fast you  would want to be going if you needed( or could)  to taxi off the side of  the runway to the grass to stop.
 3) don't expect a  lot of steering ability upon landing w/a brake failure
 4) Shut down the  engine upon realizing there is a brake failure.  The unless you have  reverse thrust, the spinning prop is not going to help you stop.  (Maybe an  aerodynamic expert can jump here with the value of pushing air over the rudder  to turn the brakeless plane)
 5) open your canopy  prior to landing a little in case the plane rolls over.
 Ira Saligman
 isaligman(at)saligman.com (isaligman(at)saligman.com)
		| Back to top |  |
		| HawkerPilot2015
				|  Posted: Tue Feb 21, 2006 5:10 am    Post subject: Re: Distraction-the Best Medicine |   |
				| Bail out and order a new airplane from Dennis.
		| Back to top |  |
				|  Posted: Tue Feb 21, 2006 5:26 am    Post subject: Distraction-the Best Medicine |   |
				| That works for me! -)
Dennis
		| Back to top |  |
		| Rob Rowe
				|  Posted: Tue Feb 21, 2006 5:31 am    Post subject: Re: Distraction-the Best Medicine |   |
				| As a further thought  *** for a YAK-52 *** ... leave the circuit & turn the main air valve off for a few minutes to isolate air sources from air consumers.
 If pressure continues to drop then return to circuit & follow emergency air procedures as documented.
 If air pressure increases then upstream NRVs, pressure regulator, main air cylinder & air gauges will all be good ... & provides extra air to help fault find any potential gear problem (which if more difficult to do on the ground).
 Open main air valve again & isolate flaps & gear (seperately) by setting each control to neutral ... if air loss continues then be aware that brake systems may be the compromised & plan accordingly ... return to circuit & follow emergency air procedures.
 If flap isolation stops the pressure loss then return to circuit & make a flapless landing.
 If gear isolation stops the pressure loss then cycle gear "down" to see if the problem is gear position specific ... note operation of gear lights for any unusual (slow) gear leg operation. If you've a GIB then consider having him repeat same using the the rear cockpit gear control to see if the front unit is leaking. Follow the emergency air procedures on rejoining the circuit.
 FWIW ... once had an intermittent air pressure drop (YAK-52) post lowering gear that took months to diagnose. Pressure would drop to c.25 kgf/cm2 & then recover back to normal. Problem occured randomly ... but could never be repeated on ground jacks (50+ cycles).
 To make diagnosis even more interesting we found that when the air pressure drops to low levels the seal integrity of the control valves can become compromised ... making them audibly leak (the design relies on high pressure air pushing the machined metal faces together to form a seal) ... so false symptoms further clouded the root cause.
 After spending a lot of time (& money) learning, stripping gear actuators & control valves the problem was eventually resolved by replacing the air pressure regulator valve unit.
 Seems this was prone to sticking open when a large downstream air demand was made (probably when regulating (at) 50 kgf/cm2) & was only in use when aloft. When the pressure differential became large enough it snapped shut again causing the system operation to return to normal!
 Rob R.
		| Back to top |  |
				|  Posted: Tue Feb 21, 2006 6:12 am    Post subject: Distraction-the Best Medicine |   |
				| Rob,
Very interesting FWIW discussion.  Also very helpful.
 As for the in-flight trouble shooting, I am not sure I or many other Yak 52
 owners/pilots would go through the extensive trouble shooting initially
 since air pressure is THE most precious commodity on the 52.  (Exclusive of
 the engine and prop turning of course).  My first reaction is going to be to
 find out if the landing will extend using whatever pressure is still
 available in the main air system and land the airplane.  Then do some
 trouble shooting in the hangar and on the jacks.  If we're unable to isolate
 the problem on the ground, at least we now have some confidence in the
 system components.  Then we can go to the next level which would be to fly
 the airplane and follow your in-flight trouble shooting technique.
 Simply put, I think your technique is excellent.  But for me, probably just
 a bit premature when a problem as described shows up after take off and at
 500 ft.  That's just me though.
 Dennis
		| Back to top |  |
		| brian
				|  Posted: Tue Feb 21, 2006 6:58 am    Post subject: Distraction-the Best Medicine |   |
				| Ira Saligman wrote:
  	  | Quote: |  	  | 4) Shut down the engine upon realizing there is a brake failure.  The unless you have reverse thrust, the spinning prop is not going to help
 The residual thrust will probably keep the airplane from stopping when
 on a hard surface (runway). Turning off the engine as soon as you have
 brake failure is part of the "normal" emergency procedure in that case.
 Brian Lloyd
		| Back to top |  |
		| brian
				|  Posted: Tue Feb 21, 2006 7:24 am    Post subject: Distraction-the Best Medicine |   |
				| Rob Rowe wrote:
  	  | Quote: |  	  |
 As a further thought ... leave the circuit & turn the main air valve off for a few minutes to isolate air sources from air consumers.
 Turning off the air valve in the CJ6A only isolates the storage tank
 from the main pneumatic pressure bus. The compressor is still connected
 and the loads are still connected. The only thing this will do is cause
 the pressure to go up or down much more rapidly as the volume of the
 system is now greatly reduced.
 But the pneumatic system in the Yak-52 does indeed work as you suggest
 it does. That means that troubleshooting a pneumatic problem in the CJ6A
 in flight will be different from troubleshooting a pneumatic system
 problem in the Yak-52 in flight.
 In the CJ6A, turning off the main air valve will preserve what pressure
 that is left in the storage tank while you fiddle about trying to find a
 combination that will stop the pressure loss. In that case you can use
 the remaining pressure to lower the gear and preserve the air in the
 emergency bottle to to provide braking on roll out.
 Brian Lloyd
		| Back to top |  |
		| Rob Rowe
				|  Posted: Tue Feb 21, 2006 8:10 am    Post subject: Re: Distraction-the Best Medicine |   |
				|  	  | dsavarese(at)elmore.rr.co wrote: |  	  | Rob, Very interesting FWIW discussion.  Also very helpful.
 since air pressure is THE most precious commodity on the 52.  (Exclusive of the engine and prop turning of course).[/color]
 Dennis,
 Fair comment ... although *** for a YAK-52 ***  if the first thing you do is turn the main air off then you can establish within seconds the important information as to whether you've got an up or down stream problem.
 If it's up stream then you'll need to use the emergency air anyway to ensure gear down & for braking ... so no delay incurred.
 If it's down stream then you'll have preserved precious air (& start replacing what's been lost) providing both time & confidence to perform a few minutes of valuable in-flight diagnostics.
 Aside from gaining time to collect your thoughts, it allows for a fuller assessment of the problem being faced & therefore the safest way to deal with it.
 I guess we'll all make our own call on this ... but if there's a silver lining to the problems we experienced it's that we all got to know the systems very well & felt comfortable that we were not going to make the situation worse by our actions.
 Believe me after several months of trying to diagnose this problem, and its random nature, the 5 guys in our syndicate could perform these procedures in their sleep!
 Rob R
		| Back to top |  |
		| Rob Rowe
				|  Posted: Tue Feb 21, 2006 8:21 am    Post subject: Re: Distraction-the Best Medicine |   |
				| Brian wrote
  	  | Quote: |  	  |
 You're quite right ... I'd failed to notice that an aircraft type was not specified ... and I'm YAK-52 biased anyway ;-)
 Rob R
		| Back to top |  |
				|  Posted: Tue Feb 21, 2006 8:43 am    Post subject: Distraction-the Best Medicine |   |
				| Rob,
I disagree.  The first thing you want to do is get the gear back down.  Not
 try to figure out where the air is leaking from which by the time I get all
 that sorted out in my brain and still fly the airplane, may deplete
 everything in the main air system.  That in itself reduces the adrenalin
 flow.  I would not turn off my main air supply when I have 28 ATM's
 remaining until AFTER I get the gear back down regardless if it's leaking or
 not.  Turning off the main air supply before I put the gear down pretty much
 assumes I'm going to use the emergency air to get the gear down.  Why use
 what you don't have to?  Personally, I prefer to save that for when I really
 need it.  If the gear is down and locked and I land I can always turn on the
 emergency air to supply air to the brakes if the main air supply is
 depleted.  Just as long as the gear is down and locked, I have the emergency
 system as the backup, which is was it intended to be in the first place.
 Once again, I don't disagree with you wanting to assess the problem.  I just
 personally prefer assessing this type of problem on the ground.    In
 reality, most (I did not say all) pilots in that situation will want to get
 the gear down and leave it down.  Then land and troubleshoot.
 Dennis
		| Back to top |  |
		| Rob Rowe
				|  Posted: Tue Feb 21, 2006 9:07 am    Post subject: Re: Distraction-the Best Medicine |   |
				| Dennis,
 Ok guess we'll (dis)agree to differ ... you propose getting the gear down as being paramount (even if you don't know what the likely leak cause is .. so you'll have to assume flaps, brakes etc are all suspect).
 My preference is to safely trouble shoot the problem to try and quantify what I've got to deal with ... and be prepared to use the back-up systems (if needed) because that's what they were designed to do.
 Same problem ... two approaches ... pick the one you feel most comfortable in handling.
 Rob R
		| Back to top |  |
				|  Posted: Tue Feb 21, 2006 9:23 am    Post subject: Distraction-the Best Medicine |   |
				| Now we agree.  <Same problem ... two approaches ... pick the one you feel
most comfortable in handling.>
 Dennis
		| Back to top |  |
