Fuse panel location
dstroud(at)storm.ca
PostPosted: Wed Oct 03, 2007 4:39 pm    Post subject: Fuse panel location Reply with quote
Hello to all. I'm new here on the list and have a question
about locating my fuse panel.
My older version of the AeroElectric connection and even books
by Tony Bengelis suggest that an intelligent choice for a fuse panel
location could indeed be farther than the reach of the pilot, since, if
the fuse blew there is little likelyhood of inflight repair to the
offending part anyway. This scenario is assuming good choices
have been made for wire and fuse sizing, length of travel etc.
and that certain circuits might need pullable breakers front and
center anyway.
Although the Fairchild 51 is a large plane, the panel is relatively small
and I'm trying to keep things simple and as authentic looking as
possible. My choice for the fuse panel location would in fact be about
12' behind the pilots seat in the "mechanical" room housing batteries
and the engine air start system.
Any comments to the pros and cons would be much appreciated.
David Stroud Ottawa, Canada
C-FDWS Christavia ( 400+ hrs. and no sparks )
Fairchild 51 under construction
klehman(at)albedo.net
PostPosted: Thu Oct 04, 2007 4:50 am    Post subject: Fuse panel location Reply with quote
Hi David
I can't reach any of my fuses in flight even though they are behind my
panel.
The downside I see for you is the number of wires you have to bring
forward from each fuse to switches and things. You might have to upsize
a few wires to cater to voltage drop.
Another minor concern might be picking up a bit of audio noise if you
run intercom and radio power in the same bundle as strobe or wig wag
light power. With some headsets I seem to have some noise even with
everything (including the forest of tabs ground block) on the firewall
but at least it is not noticeable in cruise. Even with a forest of tabs
we share grounds from there to the alternator and battery anyway but
those are heavy conductors I guess. Makes me wonder how they keep the
radio so quiet in cars despite ignition and injector pulses...
Ken
center anyway.
longg(at)pjm.com
PostPosted: Thu Oct 04, 2007 6:25 am    Post subject: Fuse panel location Reply with quote
I too have thought about fuse location. I am not sure why people always
want their CB's sticking out in front of their nose, but are willing to
hide fuse boxes behind seats, somewhere under the panel etc. Probably
that looks kool. Why not hide the CB's under the panel where you can
feel them and reset as necessary?
If I need to change a fuse, I don't want to stand on my head with my
ears between the pedals to do it. I have never read anything supporting
noise vs. the location of a fuse box where good wiring practices are
involved. If that is in fact true, it is surely different for every
single installation.
Why not use the example of many an automobile and set the fuse box just
behind the panel on the right side where a panel cover can be build for
easy strait forward access. I always loved the jobs where the panel
cover was just inside the door jam on the side of the panel.
If your panel is space challenged, another option might be on the panel
cover mounted face up perhaps using a door with a mirror so you can
easily see the condition of each fuse without breaking your neck.
I will use fuse panels, but I refuse to burry them. While location may
be of no use to myself in flight, if I have a passenger with me, they
can always assist with finding the trouble maker if they can get to the
panel.
gl
bkuc1(at)verizon.net
PostPosted: Thu Oct 04, 2007 7:25 am    Post subject: Fuse panel location Reply with quote
When I was building my velocity, I built my fuse box that was hinged at the
bottom of the panel. A little hook, kept it up. Just release the hook, and
the fuse holder drops down. Easy to see, easy to get to and easy to change
a fuse, if need be. You can offset the hinge forward to clear any back of
switches. That way, you do not need to build any panels, and if need be,
alto not sure why, you could even probably supposedly change the in flight.
However, the velocity was not in a fly mode before I sold it so am not sure
how practical it might really be, but it sure made changing fuses easy when
I was testing and blowing fuses. YMMV
Bob Kuc
I too have thought about fuse location. I am not sure why people always want
their CB's sticking out in front of their nose, but are willing to hide fuse
boxes behind seats, somewhere under the panel etc. Probably that looks kool.
Why not hide the CB's under the panel where you can feel them and reset as
necessary? >>
echristley(at)nc.rr.com
PostPosted: Thu Oct 04, 2007 7:46 am    Post subject: Fuse panel location Reply with quote
panel.
gl
The best solution I've seen for traditional configurations is to have
the fuseblock on a hinged panel that will swing down from the main
instrument panel. Tucks away nicely in flight, but conveniently swings
down for maintenance. Occupies nearly zero space that would be needed
for instruments.
I, OTOH, have other options. The Dyke Delta has extensive strakes, so
I've taken the opportunity to spread things sideways.
http://ernest.isa-geek.org/Delta/Pictures/AvionicsBay.jpg
http://ernest.isa-geek.org/Delta/Pictures/AvionicsBayAndPanel.jpg
The switch panel on the right flips down and hides most of the fuses
behind it. The small fuse panel on the left is just for audio
equipment...common ground and all that.
kahuna
PostPosted: Thu Oct 04, 2007 10:48 am    Post subject: Fuse panel location Reply with quote
This works pretty good on the RV-8
Hinged access panel in the fwd baggage compartment with fuse blocks.
Very convenient.
Best,
http://www.mstewart.net/super8/accesspanels/index.htm
[img]cid:1__=08BBF9F9DFF63C368f9e8a93df938(at)us.ibm.com[/img]Ernest Christley <echristley(at)nc.rr.com>
[img]cid:3__=08BBF9F9DFF63C368f9e8a93df938(at)us.ibm.com[/img]
To
aeroelectric-list(at)matronics.com [img]cid:3__=08BBF9F9DFF63C368f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Re: Fuse panel location [img]cid:3__=08BBF9F9DFF63C368f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBF9F9DFF63C368f9e8a93df938(at)us.ibm.com[/img]
--> AeroElectric-List message posted by: Ernest Christley <echristley(at)nc.rr.com>
> panel.
> gl
for instruments.
orum -
tor?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
EB FORUMS -
tp://forums.matronics.com
 Filesize:  105 Bytes
 Viewed:  7932 Time(s)
 Filesize:  1.23 KB
 Viewed:  7935 Time(s)
 Filesize:  45 Bytes
 Viewed:  7933 Time(s)
gyoung
PostPosted: Thu Oct 04, 2007 11:45 am    Post subject: Fuse panel location Reply with quote
I'm doing just that except on the left side. They will have an access panel
in the sidewall. They are screwed directly to the fuselage skin with dimples
and CS screws. I have added a 12-slot and 2, 6-slot blocks (aux & bat
busses) since the picture was taken. I've got fuses for EVERYTHING.
Greg Young - Houston (DWH)
RV-6 N6GY - project Phoenix
Navion N5221K - just an XXL RV-6A
[quote] --
 Filesize:  72.53 KB
 Viewed:  432 Time(s)
enewton57(at)cableone.net
PostPosted: Fri Oct 05, 2007 8:07 pm    Post subject: Fuse panel location Reply with quote
Here is a webpage from my Bearhawk builder's site on how I set up my Fuse
panel which is hinged and can swing out for easy access.
http://mybearhawk.com/finish/electrical2.html
Eric Newton - Long Beach, MS
BH #682- Mississippi Mudbug
BEARHAWK BUILDER'S MANUALS
walter.fellows(at)gmail.c
PostPosted: Sat Oct 06, 2007 8:30 am    Post subject: Fuse panel location Reply with quote
Great installation, thanks for sharing it. If others have builder sites with similar documentation of electrical installations please share them with us.
On 10/5/07, Eric Newton <enewton57(at)cableone.net (enewton57(at)cableone.net)> wrote:[quote] --> AeroElectric-List message posted by: "Eric Newton" <enewton57(at)cableone.net (enewton57(at)cableone.net)>
PostPosted: Sat Oct 06, 2007 1:30 pm    Post subject: Fuse panel location Reply with quote
Eric Newton wrote:
<enewton57(at)cableone.net>
Fuse panel which is hinged and can swing out for easy access.
I'll try to get some pictures later tonight, but for everyone using
these fuse blocks...
You can get 90* 1/4" push-on fittings. I (fortunately) have a friend
with the expensive crimper, 'cause he uses bags of them in his
business. These are VERY nice to have when you're trying to fit the
fuse-block in a tight space like Eric is doing.
Mark Phillips in TN
PostPosted: Sat Oct 06, 2007 8:06 pm    Post subject: Fuse panel location Reply with quote
In a message dated 10/06/2007 11:32:43 AM Central Daylight Time, walter.fellows(at)gmail.com writes:
Similar theme here:
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5106
Browse thru the previous entries for how I got to this point.  On current project fuse blocks are mounted on sub-panel behind glovebox, which has hinged panel on rear wall that drops down to expose them.  This actually looks like a neater approach so far...
From The PossumWorks in TN
Mark
See what's new at AOL.com and
From The PossumWorks...
longg(at)pjm.com
PostPosted: Tue Oct 09, 2007 10:33 am    Post subject: Fuse panel location Reply with quote
Great job on documenting your work for the Bearhawk Eric. You should be
an instructor. I will borrow your swing out panel idea or build a swing
down panel using a cut-out portion of my avionics shelf on the co-pilots
side.
Question: Where did you get the electronic amp sensor? Great idea. Also,
it looks like you did not use a shunt in front of your ANL?
PostPosted: Wed Oct 10, 2007 4:44 am    Post subject: Fuse panel location Reply with quote
Thanks for the kind words.
The donut AMP pickup device goes with my Grand Rapids EIS system (as an
option you have to purchase). No shunt needed with the amp device.
