Zenith building expense
Goto page 1, 2, 3  Next
naumuk(at)alltel.net
PostPosted: Thu Sep 27, 2007 4:06 pm    Post subject: Zenith building expense Reply with quote
All-
Yes, it is possible to build a Zenith for under $30K if you have a basic panel and you never make a mistake.The last thing I wanted to do was dissuade anyone from building, but I do want people to understand that homebuilding isn't a walk in the park. I dare any builder to say this is not good advice!
My main point was, build costs were not less than the cost of an overhaul. When I was part owner of a C-172, we upgraded to an Air Plains "Superhawk" conversion with a factory new O-360. $23K for everything. 'Nuff said.
Good building!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
david_a_g_johnson(at)btin
PostPosted: Thu Sep 27, 2007 11:37 pm    Post subject: Zenith building expense Reply with quote
Everyone seems to be stressing the cost of building, what about the benefits? (think positively folks!).
At the end of the project you have an aeroplane that must be worth something, here in the UK kit-built aeroplanes sell for about the cost of the kit. Also what is the value of what you have learned during the build?
Dave Johnson
601XL from a CZAW kit
purplemoon99(at)bellsouth
PostPosted: Fri Sep 28, 2007 6:47 am    Post subject: Zenith building expense Reply with quote
Well Mate,building a airplane is a good thing ,but you must have a true pict. of what it's going to cost. Cost is cost and all it ever does is go up,.over here .then there is the human factor to want a better this or that. I always wanted to build a" proper " aero plane, and to build a proper one, I think it's better to have a better this or that than to have a bad learning experinence on take-off or at 3ooo ft.
ashontz
PostPosted: Wed Oct 03, 2007 6:40 am    Post subject: Re: Zenith building expense Reply with quote
Building from scratch is pretty cheap. Figure $5,000 in materials, maybe a little more. Corvair with conversion, another $2,000. Basic instruments, $2,500 - $3,000. If it takes you 4 years that's $2,500/yr, or about $200/month.
n85ae
PostPosted: Wed Oct 03, 2007 7:24 am    Post subject: Re: Zenith building expense Reply with quote
Get real! If you want to build a real plane, that is not really
"experimental", then you're talking Lycoming, Continental,
Rotax, Jabiru, etc. You're also going to spend money on other stuff.
If you scrounge, and convert a car engine, etc. you can be one of the
miracle builders. But for the average guy, it's not gonna happen. PLus
it shouldn't. Do your families a favor, and don't hobby yourself into
becoming a statistic. Flying is dangerous enough.
Mid-Thirties is the bottom end - Realistically.
Yes, I've seen stuff that looks like it was powered by Briggs and Stratton
with a carved 2x4 for a prop, I've also had the pleasure of watching
a hangar neighbor continuously wrenching on his NSI turbo Subaru,
which he enjoyed immensely since he was a tinkerer. Yep 12 hours of
wrenching for every hour of flight, not to mention the occasional dead
stick landing ....
Jeff
ashontz
PostPosted: Wed Oct 03, 2007 7:32 am    Post subject: Re: Zenith building expense Reply with quote
I have gotten real, I built a hefty low-tolerance 8 foot bending brake with a 1/8 inch radius bend, made all the forms, and built a rudder, an elevator, a stabilizer, and wing for about $1,200 with rivets from Zenith and 6061-T6 from aircraft spruce. And every part is well within tolerances per Zenith. As far as an engine goes, go talk to William Wynne about Corvairs, they're excellent engines.
Don't get pissed at me you're struggling with a $20,000 kit less engine. LOL
Kind of reminds me of the people I meet at the dock. I come back in with my 1975 V-20 Wellcraft and it's 1986 140 evinrude full of fish and see guys in boatshow purchased floating livingrooms who didn't catch anything working on a bad battery cable, or better yet, boats sitting at the dock unused because they cost too much to operate and the owner is working weekends for the payments.
By the way, I haven't had to be towed in yet in 10 years of use with that boat. And no, I don't have a $800 fish finder. My brain is the fish finder. Just like my brain and $1,200 worth of generic instruments will replace the $7,000 glass panel avionics stack.
stick landing ....
Jeff
Afterfxllc(at)aol.com
PostPosted: Wed Oct 03, 2007 7:52 am    Post subject: Zenith building expense Reply with quote
I think his #'s are way off if you are wanting to scratch build a nice safe aircraft.... The spread sheet attached is real world #'s with the part numbers of a plane I did a builder assist on. It has aluminum brake and fuel lines and the spread sheet includes all the fittings for them also. It doesn't include the aluminum for scratch building as I used a kit. But I have been kicking around the idea of scratch building one and the best I can figure it will cost around 25,000.
In a message dated 10/3/2007 10:41:56 A.M. Eastern Daylight Time, ashontz(at)nbme.org writes:
See what's new="_blank">Make AOL Your Homepage.
Corvair_build_sheet.xls
 Filename:  Corvair_build_sheet.xls
 Filesize:  36.5 KB
 Downloaded:  2169 Time(s)
bill_dom(at)yahoo.com
PostPosted: Wed Oct 03, 2007 9:12 am    Post subject: Zenith building expense Reply with quote
This topic is baaack!
Sorry list, but some of us including myself just can get enough of this topic. So here I go.
Jeff, no matter how much someone scrounge, We all agree that putting a Lyco, Continental, Jabiru or Rotax and spend less than 30K is close to impossible, even for non average builder. The < 30K crowd are those who are going for auto conversions, specially the Corvair.
However, if you consider an auto conversion to be risky, unsafe, only reserved for miracle builders or not having a real airplane, then that's another big topic where you will find a lot of experienced builders disagreeing.
Some builders consider an auto conversion a bad way to loose one's marbles, in the same way some pilots consider flying a homebuilt plane a bad way to loose one's marbles. I knew one pilot with over 2,000 flight hours who is instrument, multi engine certified and Mensa member, who consider flying a homebuilt plane a crazy idea. When I told him that some builders have flown the Zodiac with Harley Davidson engine he rolled up his eyes so much that he saw his brain.
Andy, 2,000 for a converted Corvair is way low.
Now, I'll just run for cover.
William Dominguez
Zodiac 601XL Plans
Miami, Florida
n85ae <n85ae(at)yahoo.com> wrote:[quote] --> Zenith-List message posted by: "n85ae"
becoming a statistic. Flying is [quote][b]
craig(at)craigandjean.com
PostPosted: Wed Oct 03, 2007 9:26 am    Post subject: Zenith building expense Reply with quote
To give you a lower bound here is Bill Clapp's Corvair-powered KR2S built (with engine) for $7200:
http://www.krnet.org/krs/wc/
Now somebody will say "but it's composite".
-- Craig
ashontz
PostPosted: Wed Oct 03, 2007 9:29 am    Post subject: Re: Zenith building expense Reply with quote
No, those numbers are not way off. They're right on the money. I have spent $1,200 - $1,300 to build a rudder, the elevator, the stabilizer, and the left wing not including the ailerons including rivets from Zenith. Nothing unsafe about it. The parts are to spec per the plans. Just off the top of my head, I'd say I've used about 7 sheets of 4 x 12 6061-T6 in various thinknesses. A sheet from Aircraft spruce is about $90. So right there we're looking at about $650 for 85% of the materials required for those parts. Add in $350 for my 8' bending brake and we're up to $1,600 - $1,700.
Now if you consider those parts are identical to what would be shipped from Zenith, then that 'safety issue' is irrelavent. The next safety issue is the assembly process, in which case there is no difference between a scratch builder and a kit builder. Actually, if anything, the scratch builder may be a safer builder due to the skill set developed to actually make the parts to spec, giving the scratch builder an even better overall metalurgical best-practices understanding of the building process.
Simply by the fact that Zenith will sell you a kit (which you still have to put together) for $20,000 by definition indicates that the actual costs are a lot less. They're not doing it out of the goodness of their hearts (even though they're decent people) and selling you a kit at cost for the materials, they have to make a profit, otherwise why be in business.
ashontz
PostPosted: Wed Oct 03, 2007 9:34 am    Post subject: Re: Zenith building expense Reply with quote
Sweet!!! Love it! Thanks for the link.
[quote="craig(at)craigandjean.com"]To give you a lower bound here is Bill Clapp's Corvair-powered KR2S built (with engine) for $7200:
-- Craig
ashontz
PostPosted: Wed Oct 03, 2007 9:41 am    Post subject: Re: Zenith building expense Reply with quote
I've rebuilt a lot of engines in my day. I don't think it'll be much more than that. Maybe $3,000. I'm certainly not going to skimp on safety. If I can rebuild a 4 cylinder outboard engine or a car engine for $500, I can't imagine a Corvair being that much more, they're just parts and they're readily available. About the only difference is some of the specialty items on it.
[quote="bill_dom(at)yahoo.com"]This topic is baaack!
William Dominguez
Zodiac 601XL Plans
Miami, Florida
n85ae <n85ae> wrote:[quote] --> Zenith-List message posted by: "n85ae"
ashontz
PostPosted: Wed Oct 03, 2007 9:47 am    Post subject: Re: Zenith building expense Reply with quote
I believe I see the secret to Williams 'success' in the background of one of the pix. Anyone else catch it? It's lime green. It's a drivable early 70s VW Beetle. He doesn't just build planes, he's been farting around with this type of stuff all his life I would guess.
-- Craig
n85ae
PostPosted: Wed Oct 03, 2007 10:31 am    Post subject: Re: Zenith building expense Reply with quote
I think mid thirties is the most realistic minimum. At least for anything
that I would think about flying. Smile
Jeff
ashontz
PostPosted: Wed Oct 03, 2007 10:39 am    Post subject: Re: Zenith building expense Reply with quote
Jeff
Ok, I'll build you one and sell it to you for $35,000. Then we'll know it's nice and safe. LOL
Price-wise, what makes it safe? Because it was purchased as a kit, even though 51% of the work was completed by some homebuilder of questionable talent. Or is it the $25,000 O-200 Lycoming engine from Aircraft Spruce? I'm just curious as to the logic?
What if I was an A&P mechanic and I built the hull for $6,000 and rebuilt an O-200 I had laying around myself for another $3,000 for a total of $9,000. Would it be safe?
Last I checked, you can still find airworthy flying, fresh annualed Cessna 152s for $15,000, and that has a Lycoming in it. By the $35,000 logic, that would not be considered safe. Or, if you go by the logic that it's a factory plane and has a Lycoming, it's sfe, even though it's 35 - 40 years old.
PostPosted: Wed Oct 03, 2007 10:43 am    Post subject: Zenith building expense Reply with quote
Yarde Metals is still cheaper than Aircraft Spruce and they pack the material very nicely. You will need to purchase 5 to 8 sheet at a time in order to take advantage of their better pricing.
William Dominguez
Zodiac 601XL Plans
Miami, Florida
ashontz <ashontz(at)nbme.org> wrote:[quote] --> Zenith-List message posted by: "ashontz"
Andy Shontz
CH601XL - Corvair
www.mykitlog.com/ashontz
Read this topic online [quote][b]
PostPosted: Wed Oct 03, 2007 10:44 am    Post subject: Zenith building expense Reply with quote
All I have to say is good luck with your 5,000 build as almost every one here has said it is between 25 and 30 thousand to get a plane into the air. I never said scratch building was unsafe or some how a lesser aircraft. But you will find your 5,000 figure is going to grow to around 8 or 9 thousand and if you look at my spread sheet you will see that WW's parts are around 5,000 to do a safe conversion and the engine parts from clarks is 2,500.00 again to build a safe reliable engine conversion and that doesn't count the 150.00 nitrate or machine work. If you use falcon heads another 1,200 so just the FWF is around 8,800.00 not counting the cowling, carb, airbox etc. So I would say your #'s are off. I have built one and the numbers are what they are.
In a message dated 10/3/2007 1:33:13 P.M. Eastern Daylight Time, ashontz(at)nbme.org writes:
If you made all of the parts yourself then you can get it around 3,000. But if you buy all the parts from Clarks, WW and get your heads done by Falcon and you crank by Nitron, then you are talking about 6K to 7K. Excluding FWF.
William Dominguez
Zodiac 601XL Plans
Miami, Florida
William Dominguez
Zodiac 601XL Plans
Miami, Florida
n85ae wrote:[quote] --> Zenith-List message posted by: "n85ae"
Andy Shontz
CH601XL - Corvair
PostPosted: Wed Oct 03, 2007 10:49 am    Post subject: Zenith building expense Reply with quote
Just build it..... who care's what it costs. If you do it for 5,000 10,000 who cares as long as your happy with it. My numbers are based on what it cost's me to build one the way I want it built. You may choose to build one with less expensive things if so when your done send us a pic and a list of costs to help other builders build theirs cheaper.
In a message dated 10/3/2007 2:40:33 P.M. Eastern Daylight Time, ashontz(at)nbme.org writes:
ashontz
PostPosted: Wed Oct 03, 2007 10:57 am    Post subject: Re: Zenith building expense Reply with quote
Not to drag on, but just adding up what you have listed here, by your own account, looks more like 9,000 + 8,800 for fuselage and engine. Where's the extra $17,200? If you're not going ape with avionics, even by your own admission you should be under $20,000.
Even so, I said $5,000 - $6,000 for fuselage, $10,000 total, that's a possibility for a bare bones plane, depending on how much of the engine I do myself, and I will do a lot.
[quote="Afterfxllc(at)aol.com"]All I have to say is good luck with your 5,000 build as almost every one here has said it is between 25 and 30 thousand to get a plane into the air. I never said scratch building was unsafe or some how a lesser aircraft. But you will find your 5,000 figure is going to grow to around 8 or 9 thousand and if you look at my spread sheet you will see that WW's parts are around 5,000 to do a safe conversion and the engine parts from clarks is 2,500.00 again to build a safe reliable engine conversion and that doesn't count the 150.00 nitrate or machine work. If you use falcon heads another 1,200 so just the FWF is around 8,800.00 not counting the cowling, carb, airbox etc. So I would say your #'s are off. I have built one and the numbers are what they are.
Page 1 of 3
