Jeyoung65(at)aol.com Guest
Posted: Tue Oct 02, 2007 12:20 pm Post subject: Rotax 912 UL high oil pressure |
Not sure where the pressure transmitter is located in your engine system but you may have a clogged oil filter. Jerry of Ga
See what's new at AOL.com and Make AOL Your Homepage.
dougsnash(at)yahoo.com Guest
Posted: Tue Oct 02, 2007 2:37 pm Post subject: Rotax 912 UL high oil pressure |
HI Ed, welcome to the list, a couple of suggestions
have been made about a faulty pressure transmitter.
That is a good thing to think about but it might also
be temperature related.
I'm not flying my 912UL yet but one thing I have heard
about these beasts is that they have quite a bit of
oil cooling capacity. Is it possible you are running
the oil temp too low and causing your pressure to be
on the high side?
Doug MacDonald
CH-701 Scratch builder
NW Ontario, Canada
--- Edward Micallef <edmica2(at)yahoo.com> wrote:
[Rolling Eyes] I am a new owner of a Zodiac 601 HDS
The A/C has a TTEA of 150 Hrs.. The engine is a
Rotax 912 UL # 4401716..I am used to Lyconing
engines but Rotax is new to me. Lately I have
noticed that the oil pressure is higher than what is
specified in the manual. It is supposed to be
22-72 psi , when I am turning about 5000 rpm it
fluctuate over 80psi. I can't find any thing about
it in the trouble shooting about high oil
pressure..Is there any body out there that had a
similar problem? Any help will be greatly
appreciated...Ed
Pinpoint customers who are looking for what you sell.
http://searchmarketing.yahoo.com/
Edward Micallef
Posted: Tue Oct 02, 2007 10:00 pm Post subject: Re: Rotax 912 UL high oil pressure |
[quote="Jeyoung65(at)aol.com"]Not sure where the pressure transmitter is located in your engine system but you may have a clogged oil filter. Jerry of Ga
Thanks Jerry, I will check the oil filter although it has only 10 hrs since it was changed...Regards Ed
Edward Micallef
Posted: Tue Oct 02, 2007 10:05 pm Post subject: Re: Rotax 912 UL high oil pressure |
| dougsnash(at)yahoo.com wrote: | HI Ed, welcome to the list, a couple of suggestions
on the high side?
Doug MacDonald
NW Ontario, Canada
--- Edward Micallef <edmica2> wrote:
<edmica2>
appreciated...Ed
Thank you Doug, I will check the oil temp and make a note where it it is when the oil pressure is high....Ed
http://searchmarketing.yahoo.com/ |
macleod(at)eagle.ca Guest
Posted: Wed Oct 03, 2007 7:36 am Post subject: Rotax 912 UL high oil pressure |
Edward:
I had a similar problem with my 912S a few years ago. At first the
pressure would jump from 50 psi to 90 psi stay there for a few seconds
then drop back to 50. A few hours later it would go to 90psi and stay
there. The problem turned out to be a loose connection on the sender.
NOTE: when I first checked the sender connections they seemed ok, later
after I disconnected the sender and did a good reconnection the problem
went away.
Mike
601XL waiting for Rotax FWF
| Quote: | The engine is a Rotax 912 UL # 4401716... Lately I have noticed that the oil
pressure is higher than what is specified in the manual. It is supposed
to be 22-72 psi , when I am turning about 5000 rpm it fluctuate over
80psi.
pchapman(at)ionsys.com Guest
Posted: Wed Oct 03, 2007 2:39 pm Post subject: Rotax 912 UL high oil pressure |
At 15:43 02-10-07, you wrote:
[Rolling Eyes] I am a new owner of a Zodiac 601 HDS The A/C has a
TTEA of 150 Hrs.. The engine is a Rotax 912 UL # 4401716..I am used
to Lyconing engines but Rotax is new to me. Lately I have noticed
that the oil pressure is higher than what is specified in
the manual. It is supposed to be 22-72 psi , when I am turning
about 5000 rpm it fluctuate over 80psi. I can't find any thing about
it in the trouble shooting about high oil pressure..Is there any body out
Another possible issue regarding oil pressure changes:
I found that changing to an actual Rotax oil filter, from one that is
simply compatible, seems to have increased the oil pressure somewhat.
Have others found this to be correct?
Peter Chapman
Toronto, ON
goodings(at)yorku.ca Guest
Posted: Wed Oct 03, 2007 5:55 pm Post subject: Rotax 912 UL high oil pressure |
When we first flew our 601HD with R912S, the oil pressure was LOW. It
turned out to be the pressure gauge or sender, I don't know which. It
reads 2/3 of the correct value over a considerable range (20-40 psi).
This was determined by putting a second known accurate pressure gauge
simultaneously in the oil line. My point is, don't assume your gauge
reading is correct! There may be nothing wrong with the oil pressure.
John Goodings, C-FGPJ, CH601HD with R912S, Ottawa Carp/Toronto.
Edward Micallef
Posted: Wed Oct 03, 2007 6:27 pm Post subject: Re: Rotax 912 UL high oil pressure |
To all who responded to my problem with the high oil pressure, thank you I will check each one out till I find the the right fix and of course keep you all informed..the weather is changing in the NW and I will have to check this out in between rain showers...Ed :
Edward Micallef
