rnewman(at)lutron.com Guest
Posted: Tue Oct 02, 2007 8:06 am Post subject: battery cable routing |
I've studied many of the contruction logs from the popular sites and
haven't seen much on the routing of the big battery cables. I've seen
no real guidance in Van's instructions in the Finishing kit or the FF
kit.
So here's the basic question. For those that have already done it,
have you run the 2 gauge battery cables through one of your flexible
conduits from behind the baggage compartment up into the sidewall above
the wing spar? or have you made other dedicated hole for the battery
cables and kept the conduits open for all the other wires?
Also, is there a preferred side to land the battery cables on the
firewall? On our other airplanes we have always landed the wires on
the pilot side, cause it made for the shortes run to the starter,
However this plane seems to have the oil cooler taking up a lot of space
on that side.
Thoughts and pictures appreciated.
Bob Newman,
slow build fuse now attached to tail cone.
Tim Olson
Posted: Tue Oct 02, 2007 8:19 am Post subject: battery cable routing |
I have run them through conduit with the other wires on the pilots
side of the plane.
As for a preferred side, that would probably be the pilots side,
which is what the Van's electrical plans show. That's because
* That's the side that the starter is on
* That's the side that the starter contactor is on
* That's the side that they have wire covers and things made for
if you want to use them
* That's the side that the contactor is on the battery box.
And whatever other reasons.
You could do it on the other side if you wanted, but it'll
possibly mean some creative routing. The oil cooler doesn't
interfere with the starter contactor at all.
Bob Newman wrote:
kit.
on that side.
Bob Newman,
Posted: Tue Oct 02, 2007 8:47 am Post subject: battery cable routing |
Tim, As always, Thanks for your input!
Best regards,
Bob Newman
side of the plane.
Bob Newman wrote:
seen
| Quote: | no real guidance in Van's instructions in the Finishing kit or the
FF
| Quote: | kit.
above
| Quote: | the wing spar? or have you made other dedicated hole for the battery
on
| Quote: | the pilot side, cause it made for the shortes run to the starter,
space
| Quote: | on that side.
Bob Newman,
Deems Davis
Posted: Tue Oct 02, 2007 9:09 am Post subject: battery cable routing |
Some of it is very dependent on your electrical system architecture and
implementation.
eg.
1. Are you running a dual battery or dual alt system?
2. Where are you planning on placing the busses? If you put them on one
side or the other of the subpanel, it will likely influence which side
you run cable on.
I ran a #2 Battery to Starter contactor cable on the pilot side for the
reasons Tim noted. I also ran a #4 cable on the left side for the main
buss & a #10 for the Aux buss, as this is wher e I've located the fuse
blocks for the busses.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Bob Newman wrote:
kit.
on that side.
Dave(at)AirCraftersLLC.co Guest
Posted: Tue Oct 02, 2007 9:11 am Post subject: battery cable routing |
I originally intended a firewall mounted battery, so I closed up my
floorboards before I ran the cable. I wish I hadn't. The rear battery now
forces the cable up the right side to avoid going over the baggage door,
etc. That added at least 3' of cable.
Go under the floorboards and up the left side. I think there are provisions
to mount a contactor on the left side of the firewall above the oil cooler.
Plenty of room there for the cables. The starter is on the left too, so you
don't have to cross over.
I put my contactor indoors, also closer to the APU plug tie-in.
The picture is from the tunnel looking left. It would have been easy to
route the cable up the left side. Doh.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
#40394 FAA inspected, xpndr check and training today, then first flight
ASAP.
65.14 KB |
456 Time(s) |
Mike Whisky
Posted: Tue Oct 02, 2007 11:15 am Post subject: Re: battery cable routing |
I've a bunch of pictures of the conduit routing on my website
www.wellenzohn.net
It starts on in the bottom of the gallery No9
http://www.wellenzohn.net/Fuselage/index9.html
I routed three conduits to the front.
Michael
Fuselage/finishing/FWF
_________________ RV-10 builder (flying)
#511 |
MauleDriver(at)nc.rr.com Guest
Posted: Tue Oct 02, 2007 11:40 am Post subject: battery cable routing |
I'm doing a dual battery, dual alternator, split bus system. For
cabling, I'm following the lead of Van's basic electrical harness and
running my #2 and my #6 guage together along the left side using exactly
the route laid out in their installation instructions.
I've tried to do some careful planning and sizing and it looks like I
can run all the wiring between front and back using snap bushings, cable
clamps, edge grommets and the brackets included in Van's electrical
harness kit (they can all be ordered separately). I'm simply
replicating the left side on the right side too. Then I'm adding some
conduit for unforseen future cable.
Now this is all planned but not all done yet. The cables are going in
this week or so. So we'll see.
As many have said, the Van's kit is limited for many of the panels and
systems we're installing, but a very good starting point nonetheless.
Using the installation manual to guide my own custom setup seems like a
very good way to go.
Bob Newman wrote:
kit.
on that side.
Bob Newman,
wvu(at)ameritel.net Guest
Posted: Tue Oct 02, 2007 7:09 pm Post subject: battery cable routing |
I ran mine from behind the baggage compartment up into the sidewall above
the wing spar like you said. Then it makes a bend inboard and down going
under the pilot seat, under the forward floor board (under the pilot's
feet), and up the hole right aft of the firewall. Same on the right side
for other wires. This eliminates wires being visible around the NACA vent
areas.
Anh
N591VU- just broke 100hrs
Kellym
Posted: Tue Oct 02, 2007 8:56 pm Post subject: battery cable routing |
I'm curious why you would run the extra wires from the battery, Deems?
My TC aircraft has battery in same location, runs #2 to starter relay,
where lead connects to same terminal to feed the main bus, and aux bus.
The starter is only used when there should be absolute minimum draw on
the buses, and not in use when you need power for all the other stuff.
Just seems like extra wire and complexity, at first blush.
Kelly
Deems Davis wrote:
and implementation.
eg.
one side or the other of the subpanel, it will likely influence which
side you run cable on.
the reasons Tim noted. I also ran a #4 cable on the left side for the
main buss & a #10 for the Aux buss, as this is wher e I've located the
fuse blocks for the busses.
Deems Davis # 406
KCHD |
Deems Davis
Posted: Wed Oct 03, 2007 6:12 am Post subject: battery cable routing |
Kelly, the short answer is, .... I wasn't smart enough to think about
doing it that way.
Deems
Kelly McMullen wrote:
bus. The starter is only used when there should be absolute minimum
draw on the buses, and not in use when you need power for all the
other stuff. Just seems like extra wire and complexity, at first blush.
Kelly
> and implementation.
> eg.
> the fuse blocks for the busses.
> Deems Davis # 406
apilot2(at)gmail.com Guest
Posted: Wed Oct 03, 2007 7:00 pm Post subject: battery cable routing |
Honesty is admirable. I'm sure it won't make any difference in the long run. Doesn't look like I will be able to make LOE. Keeping fingers crossed at keeping schedule open for Copperstate.
On 10/3/07, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:[quote] --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
doing it that way.
Deems
| Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Kelly
>> and implementation.
[quote]>
> eg.
> Deems Davis # 406
ricksked(at)embarqmail.co Guest
Posted: Wed Oct 03, 2007 8:35 pm Post subject: battery cable routing |
Don't kid yourself....one look at his aircraft and and you'll see just how smart he is. How did it go with Mike on the transistion training Deems?
Rick S.
40185
