JOHNTMEY(at)aol.com Guest
Posted: Mon Oct 01, 2007 9:39 am Post subject: Hot Starting Rocket |
Current thread reminds me of question of hot starting the IO-540. (cold start never a problem)
Every now and then, mine gets cranky. Won't start hot. I have an Airflow recirculating valve which seems to complicate the matter. After pumping, I can't tell if I'm wet or dry. Guess I don't know how to use it.
My best bet is to open the oil door after parking... then later re-start with no recirculation, no prime, mix cut-off, throttle 1/2 open. It usually pops right off while enrichening mixture, then will smooth-out with a short burst of electric pump. Requires lots of hand movements
Any other hints ?
JohnM N5800
Make AOL Your Homepage.
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
CalBru(at)aol.com Guest
Posted: Mon Oct 01, 2007 10:04 am Post subject: Hot Starting Rocket |
My hot start procedure from my checklist, as provided by Ron Carter:
HOT START
Mixture Closed
Throttle Closed
Fuel Pump run it until you hear it load up
Starter run starter --BTW, my starter switch is on my stick so I can hold it back Mixture to 1 inch Upon firing, full rich, throttle slowly move the mixture forward no more than one inch( while running the starter) When if fires, push it full forward and add some throttle Keep the stick full back during all this
This has always worked for me, and I appreciate Ron's telling me how to do it. Before I learned this, I jump started two times. Once at my hangar--no big deal, but once at a small airport duing the test hours. His rust bucket Nissan PU was parked between my wing and tail! You can bet I kept my feet firmly on the brakes during that episode.
Cal B.
F1 116 125 hours
cjensen(at)dts9000.com Guest
Posted: Mon Oct 01, 2007 10:45 am Post subject: Hot Starting Rocket |
I concur with the start procedure suggested by Cal but I modify it by, after flooding the hot engine, by cutting the mixture to full off. The engine will always catch as you spin the engine with the starter. As it passes from the flooded condition toward lean cutoff, the fuel mixture, at some point, it will be perfect. When the engine catches, there will be enough momentum in the engine that pushing the mixture full rich will allow the engine to continue to run. This techniques saves having to carry a ruler to measure the 1" of mixture movement.
Chuck Jensen
[Chuck Jensen] --
nico(at)cybersuperstore.c Guest
Posted: Mon Oct 01, 2007 2:16 pm Post subject: Hot Starting Rocket |
That sounds like how Continental would start, except that the mix is full rich and the throttle is advanced slowly. I believe that the Contis have a boost pump on the throttle, not sure about that at all. But the Lycs are a different beast altogether.
My theory behind intentional flooding is that I get to start from a known point in the procedure. Most failed starts I had before adopting this procedure were because I didn’t know whether it was flooded or starved and cranked the battery dead before I could figure out what to do. Since I cannot intentionally starve the cylinders of fuel, I went the other direction. Fuel pumps on until fuel spills out the overflow line, fuel cutoff, full throttle and crank until it fires (burst of power) and then lots of hand movement to keep it running. Works every time, even the 380HP geared motor in the Commander 680.
Nico
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of JOHNTMEY(at)aol.com
Sent: Monday, October 01, 2007 10:37 AM
To: rocket-list(at)matronics.com
Subject: Hot Starting Rocket
Any other hints ?
JohnM N5800
href="http://www.matronics.com/Navigator?Rocket-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
jrstone(at)insightbb.com Guest
Posted: Mon Oct 01, 2007 5:54 pm Post subject: Hot Starting Rocket |
I can't believe the heat that comes out the dipstick door when pointed into the wind. That really helps after a failed attempt.
Jim Stone
Posted: Mon Oct 01, 2007 5:57 pm Post subject: Hot Starting Rocket |
I'll give that a try.
Jim Stone
Posted: Mon Oct 01, 2007 6:05 pm Post subject: Hot Starting Rocket |
Thanks Chuck,
Jim Stone
